70Custom10
Valve cover Hole questions
So im looking at a new set of aluminum valve covers on ebay cause I like that raw aluminum look but Im on a budget. The ones I have now are orange painted Chromes and leak like nobodys business. The ones I like have no holes in them but they offer a pair for the same price that have one hole each. what are the pros and cons of running valve covers with or without the holes in them. Are the ones without just designed to be drilled where i need them? As always thanks for the advise everyone.
#2 | ||
"I ain't nobody, dork."
Re: Valve cover Hole questions
With no holes... how do you add oil? (unless you have an early 327 or a 283 with oil fill in the manifold) Or run a PCV?
Gary
running a good PCV system is great for the longterm health of your engine
They are probably spewing oil because you dont have a proper pcv/breather system and crankcase pressure is through the roof. You need the holes. Breather in one side Pcv in the other.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
Grandpa in the rustmobile...
Buy the ones with holes already.
You can drill holes with a holesaw (I did) and the hole was bigger than advertised (1 1/4" but the 1 1/4" breather still leaked around the edges) You need pcv/breather.
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
70Custom10
I currently have a set of crappy chrome covers that have 3 holes total. Breather, Pcv, and filler. The ones that I WANT to get have no holes but I just want to make sure im not shooting myself in the foot by getting them. I just hate all the clutter but Im not going to sacrifice the health of my new motor for aesthetics. By the sounds of things Ill be ordering the Holed covers tonight.
#7 | |
1.22" is 1-7/32" or very close to 31mm Lenox 30912 step drill bit has 1-7/32 (not cheap) Greenlee 36489 Punch 1-7/32 (not cheap) From talking to others - use 1-1/8 to get base opening and then bring it to finish size with deburring tool. http://www.deburringtools.com/deburr...thhandles.html //RF
"The Beast" 1975 Chevrolet C20 longbed 350/700R4! with 3inch body lift Dual Flowmasters Super 40's! TBI retrofit completed (2007-07-29) ![]() New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17) |
yeah i have a set like that! i just punched a hole in it with a dremel and matched them to the ones that i currently had! works great!
68 C10 LWB 2/4 drop 406/th400/3.73posi 04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD |
Baffles??? Do the ones with holes have baffles inside below the holes. If not you'll need some. Otherwise your pvc will suck up a lot of oil and you'll be burning oil like crazy!!!
70Custom10
Yep they have baffels
70Custom10
Since were on the subject what are your thoughts on Neoprene valve cover gaskets?
It looks like you are looking at White Performance. If so, get there Neoprene and stud set. It works great and you can a good torque feel with the long stud nuts.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
70Custom10
Actually I havent heard of them. Ive just seen people mention neoprene gaskets in other forums and around. Ill check them out though.
70Custom10
| Bookmarks |
| Tags |
| holes, valve covers, venting |
| Thread Tools | |
| Display Modes | |
