02-05-2011, 08:51 PM | #1 |
brake kits
i just baught a truck and it doesnt have any brakes in the rear.... and i am looking to buy brakes for the back. I am wandering if someone can help me with this
02-05-2011, 09:25 PM | #2 |
sharp as a marble
Re: brake kits
Everything you would need is available from a local parts store, as long as you want to have rear drum brakes. What year is your truck
02-05-2011, 09:33 PM | #3 |
Re: brake kits
it is 1982 i just dont wana go broke replaveing all this lol...
02-06-2011, 12:51 AM | #4 |
Re: brake kits
the local junk yard will have some "Gently used" for half price ,,,, if you like to live on the edge
84 K20 Long Box W.I.P 78 Burb - parts now [Rolled] 68 c20 dump bed WHEN IN DOUBT--- FLOOR IT Last edited by Toxic Redline; 02-06-2011 at 12:52 AM. |
02-06-2011, 01:59 AM | #5 |
God is good!
Re: brake kits
Shoes for the rear are very inexpensive at the parts stores.
Mando "It takes a smart man to know when he's stupid." -- Barney Rubble My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367 |
02-06-2011, 03:18 AM | #6 |
Re: brake kits
autozone/advance/orielly/napa, etc.
- stuff for our squares are cheeeeeep. turn the drums if they have some meat left, or they are 42.00 each shoes set is are 20.00 wheel cylinders 9.00 each a full hardware kit (all springs, hold downs, etc ) is 8.00 each side. replace the rubber hose on the rear end too. 14.00 take the adjusters apart, wire wheel, and lube em up and for about 150.00 or less, you are all set in the rear - while you are at it: front rotors are 30 each calipers are 13.00 each (after core) pads are 22 front hoses are 17.00 each throw in a set of new wheel bearings 14 each side and seals 3.00 each 174.00 and the front is set. for just over 300 you are good for safe daily driving (assuming the master is good... they are cheep too, so.... while your at it....) Good luck. note; above pricing from autozone. Last edited by primrrd; 02-06-2011 at 03:21 AM. |
02-06-2011, 06:46 AM | #7 |
Re: brake kits
wow thanks for the help the truck only has the dust caps nothen else on the back the front is all there.. thank you for the help guys
02-06-2011, 02:30 PM | #8 |
Re: brake kits
Follow the link in this thread for excellent pics of what all you need.
http://67-72chevytrucks.com/vboard/s...d.php?t=444976 |
02-06-2011, 08:41 PM | #9 |
BMW & ASE Master Certified
Re: brake kits
I have all of the old parts from my 10 bolt rear... if you made the trip to houston, you can have it all. Backing plate to drum, shoes from memory are in good. Even the backing plates are laying around. I converted to C-5 rear brakes.
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress Last edited by 87chevy.com; 02-06-2011 at 08:41 PM. |
02-06-2011, 09:00 PM | #10 |
Happy to be here
Re: brake kits
Now that is what this forum is all about. Awesome gesture primrrd and Clint.
Posted via Mobile Device |
