Old 02-05-2011, 09:34 PM   #1
dbaer
dbaer's Avatar
Speedo cable routing
The 71 k10 i bought has no speedo cable and the firewall has been plugged and caulked to death. Does the speedo cable penetrate the firewall or the floor? Does anyone have a routing diagram showing attachments?
dbaer is offline   Reply With Quote
Old 02-06-2011, 04:29 AM   #2
dmack91
dmack91's Avatar
Re: Speedo cable routing
Just replaced the cable in my 68 C20 yesterday. It goes through a hole in the firewall at the upper corner of the fuse panel.
On my 68, the panel runs length-wise, and I know some of the newer ones ran more vertical. The hole is about 1" in diameter, about 1/2 way between the steering column and driver's side inner fender, and about 4-5" above where the steering column penetrates the firewall.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 02-06-2011, 04:41 AM   #3
Jeffs70
Jeffs70's Avatar
here is a picture of where my speedo cable goes through with a gromit, Hope this helps. but if its not correct I am sure someone else will correct me.
Jeffs70 is offline   Reply With Quote
Old 02-06-2011, 06:30 AM   #4
JimKshortstep4x4
Here is a picture of the location where the cable goes through the firewall on a 71 K-10.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 02-06-2011, 11:51 AM   #5
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Jim is correct I believe. Mine came thru right above that wiring block.
John
1999 Toyota Tacoma 4x4
Old 02-06-2011, 02:53 PM   #6
dbaer
dbaer's Avatar
Excellent info. Are there connections anywhere along thr frame on route to the tranny?
Old 02-06-2011, 11:48 PM   #7
dmack91
dmack91's Avatar
Mine has a clip that slides on the driver's side frame and there is a loop strap that is screwed to the side of the trans.
I will see if I can post some pics.
Old 02-06-2011, 11:58 PM   #8
67chevy1series
67chevy1series's Avatar
there is also a clip on the cab that you can stick the cable through and then bend it to hold it in place....
67chevy1series is offline   Reply With Quote
Old 02-07-2011, 02:43 AM   #9
dmack91
dmack91's Avatar
Here are some pics. My old cable was 69". Options were 60 or 83. Looks like I went too long, but it works.
Old 02-07-2011, 08:56 PM   #10
brans72
Dmack is that that 80's cable?
brans72 is offline   Reply With Quote
Old 02-07-2011, 10:42 PM   #11
dbaer
dbaer's Avatar
Is that a gear reduction mounted to the transfer case or is that a stock item. One of the parts in the coffee can that came with the truck looks just like it. The PO told me it was needed for the larger tires.
Old 02-07-2011, 10:46 PM   #12
oldblue1968chevy
Yours looks extra long lol
John
Old 02-07-2011, 11:33 PM   #13
dmack91
dmack91's Avatar
I think it was 83" - that was the closest thing Napa had.
The gear it goes into (last photo) is on the TH400.
