Old 02-06-2011, 07:03 PM   #1
Leadfoot Lambert
Leadfoot Lambert's Avatar
Is this stock?
I'm trying to figure out what is stock on my front suspension and what has been changed. I would like to order all new bushings and ball joints, tie rods etc. Its a 65 short fleet 2wd, it has a disc brake setup on it that I know is not stock but I don't know if the whole front suspension has been swapped for a 73 and up or if they just swapped the spindles. I know the power steering box has been changed but I don't know what that came from either. take a look at the pics and let me know what you think.
65 Chevy short fleet 350 5 speed, soon to be LSX powered
65 F100 short fleet
91 Heritage softail
94 Fatboy
11 Softail Deluxe [wife's bike]
13 Streetglide
http://www.youtube.com/watch?v=yMFMw...eature=mh_lolz
Leadfoot Lambert is offline   Reply With Quote
Old 02-06-2011, 07:24 PM   #2
hotrod66
hotrod66's Avatar
Re: Is this stock?
no its not its the front cross member from a 73 - 87. the 73 -87 most of the parts are the same for toughs years ,i would shoot for a 84 when buying parts. i know some of the rotors are different ,some of the spindles are longer than others were the rotor mounts on. so if your going to get new rotors bring your old ones with you same thing for the brake calipers .
Between saying and doing many a pair of shoes are worn out
hotrod66 is offline   Reply With Quote
Old 02-06-2011, 07:32 PM   #3
Leadfoot Lambert
Re: Is this stock?
So the whole crossmember and upper and lower control arms are 73-87? what about that pitman arm? It looks odd to me the way it's at an angle mounted to the frame.
65 F100 short fleet
91 Heritage softail
94 Fatboy
13 Streetglide
Old 02-06-2011, 07:38 PM   #4
k1rodeoboater
Re: Is this stock?
it's definitely a 73 to 87 crossmember in there. You can tell because the brake lines are on the front rather than the rear. The A Arms are also from that year range too.
...and yeah something doesn't look right with that arm....
k1rodeoboater is offline   Reply With Quote
Old 02-06-2011, 07:46 PM   #5
hotrod66
hotrod66's Avatar
Re: Is this stock?
it all looks to be the same year (73-87 )
Old 02-06-2011, 07:58 PM   #6
hotrod66
hotrod66's Avatar
Re: Is this stock?
the pitman arm looks to be the same year as 73 -87 but you must think the gear box don't belong on the truck look at how the gear box is mounted . they make a kit to mount it the correct way ,so you don't end up like me with a cracked frame rail because the previous owner mounted it wrong.
Old 02-06-2011, 08:04 PM   #7
Leadfoot Lambert
Re: Is this stock?
who makes the mounting kit? linky?
65 F100 short fleet
91 Heritage softail
94 Fatboy
13 Streetglide
Old 02-06-2011, 08:13 PM   #8
k1rodeoboater
Re: Is this stock?
captainfab here on this board makes one...I'm sure he'll be by soon...
Old 02-06-2011, 08:44 PM   #9
hotrod66
hotrod66's Avatar
Re: Is this stock?
i ordered mine from classic parts i don't remember the brand.
Old 02-07-2011, 02:53 AM   #10
Captainfab
60-66 Nut
Re: Is this stock?
Your entire suspension appears to be of the '73-'87 style. And yes that idler arm is the '73-'87 style also. You can narrow down the year a little by looking at the hos fittings on the steering box. If the fittings are inverted flare, then the box is a '69 to about 1980. If it had metric sized fittings with an O-ring, then it is about 1980 to '87. I know this just ID's the box, but the chances are gppd that everything came from the same donor. One other thing is that somewhere in the mid 80's GM offered a light duty brake rotor. They were 1" thick as opposed to the standard 1.25" thick rotors.
Old 02-07-2011, 03:49 AM   #11
padresag
Re: Is this stock?
that brake hose in your 1st picture doesn't look to good either
ron
padresag is offline   Reply With Quote
