#326 |
![]() Join Date: Jul 2007
Re: Chucks SWB Fleetside
Yeah just make sure it looks like the rusty one with a thick wall around the hole. I didn't even look at it before all this.
Chuck 68 ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
#327 |
thats sucks chuck! the trucks comin along nicely i need to get my truck to were your at...
#328 | |
Lucky Teter at the wheel
If the old one is the one that I had on it, it is brand new. The water pump failed on the drive back from Colorado and so I had to replace it. Less than 2000 miles.
Drew YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!) The Bride is currently under the knife!
#329 |
Thanks Drew. I remembered that you had replaced it but didn't know how many miles it had on it. I wire brushed it a little and the surface rust came off easy. So I figured it must not have been that old. I put the fitting back in and painted it. Put it on too. Just need to touch up some paint and its done. I put my balancer on the shaft and it looks like the timing tab is too far from the balancer. I'll have to do some research.
#330 |
well that is just pure luck! time to turn in the new one and get some money to dump in to the truck!
#331 |
Well I learned that the original harmonic balancer was an 8''. I got a 6 3/4''. So when I put it up to the shaft the tab was farther away from the balancer than I wanted. I ordered a tab for 6 3/4''. I got the advice from some members here in the engine and drivetrain section.
#332 |
Took the bad cast water pump back today and got my money back no problem.
#333 |
good to know every thing went smoothly!
#334 |
VA72C10
![]() Join Date: Mar 2008
cool! Glad they didn't hassle you.
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#335 |
Me too. They were pretty cool about it. The guy just looked at it and said it was a bad cast.
#336 |
any progress?
#337 |
Sorry to say no. I have been trying to sell some parts to help fund this project.
#338 |
as have i haha well good luck to you! ill be waiting for more progress
#339 |
Step Brother
Nice truck build Chuck.....If it is going to be a power steering truck, I would love to have part numbers or measurements of the pulleys if possible!.....Or if you could snap a picture, I have two five gallon buckets of GM pulleys that I can go thru if I only knew which ones I need!!...lol....Thanks George
#340 |
Thanks George. I got these off my 350 w/ ac. have some #s
1st pic Inner crank 2 groove a little less than 6 3/4'' wide 3744043BA 2nd pic Outer crank 1 groove a little less than 6 3/4'' wide 3751232 3rd pic those together 4th pic water pump 2 groove 5 3/4'' wide 3995646AH 5th & 6th pic ps pulley 5 3/4'' wide 3770509-CE
#341 |
6th pic
#342 |
Step Brother
2nd pic
Outer crank 1 groove a little less than 6 3/4'' wide 3751232 That's the one I need to look for!!....That helps me alot!!...Thanks for your time once again Chuck!! |
#343 |
no problem George. I might be able to look for it next week if you don't have one.
#344 |
Step Brother
#345 |
Moving at a snails pace. But moving. I got the fuel line on. I Hooked up the gas pedal linkage. I got the Harmonic balancer and lower pulleys on. I also got an electronic dist. and some rear wheel wells. I got the parts off of the board. I haven't got the wells yet though. Their new Goodmark ones.
#346 |
VA72C10
Hey, progress is progress!!!! Looking great!!!
#347 |
i have the same distributor!
#348 |
Nice build chuck, I was wondering if you could direct me to a step by step process in shortning a 1969 LWB box .
#349 |
67cheby
![]() Join Date: Sep 2008
try searching for a build by Purpedo...i think he had some pretty good pics on doing this , also Drewskiren just did it on his crew cab he has some good pics also
#350 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Coming along nicely buddy!
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
