#226 |
69' Chevy Stepside
![]() Join Date: Mar 2008
Re: Project -underfunded - '68 shortstep/carb'd LSx/200-4r build
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver |
#227 | |
A guy with a truck
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#228 |
Truck and auto performance nut
actually my trans builder provided the cable. It had all the various adjustments and a square OEM style plastic mounting point which wound up fitting my TCI carb bracket perfect. I have a Lokar throttle cable and was going to use a Lokar carb bracket but decided to go with this TCI one to keep the trans happy. Also mounted an adapter to the carb linkage that changes the linkage ratio for the TV cable. The TCI bracket isnt fancy but it works great. WOT has the tv cable about 1/4" away from its stop. I'll get pics of it all.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#229 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Looking really good buddy!
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#230 |
thanks!
#231 |
OK...here's some of the latest pics.
heater cores lower pipe busted loose so I decided to pull the heater box apart: ![]() ![]() some of the stainless steel brake line going in: ![]() ![]() and the trans builder supplied TV cable, TCI carb bracket, and Lokar throttle cable: plan on reversing the throttle return springs. ![]() ![]() ![]() ![]()
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken Last edited by 68GMCCustom; 04-16-2012 at 03:32 PM. |
#232 |
That is some facny set up there. Hope it works good for ya. Cant wait to here that thing running.
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle |
#233 |
Still Learning
Hey your cab looks like it's in really great shape. Don't look like it's gathered any rust at all. Where did you pick up the brake lines? Those look really nice.
#234 |
thanks 85burb, it even had a Lokar carb bracket...but I decided function was better then beauty. :lol;
thanks mcbassin, it was redone back in the 90's. I found one bad spot in the heater box area that had been repaired. I plan on doing body and paint in a year or so, and just patch things as i go until then. I wound up going with Inline Tube for the brake lines and stuff. I ordered the hardware (fittings, clamps, etc) yesterday...forgot about it when I ordered the full brake line set. Guess I thought they were included. ![]()
#235 |
6>8 Plugless........
![]() Join Date: Sep 2007
Very nice progress! It is looking great!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#236 |
Still Learning
What fittings and clamps were not included? Where did you order them? directly from inline? thanks
#237 |
Shoot you mean it was fancyer??? I still have my factory everything.
#238 |
mcbassin...when you buy the lines...your just buying the lines. They sell their clamps, fittings, and brass T's all separately. Would up spending another $95 on all mentioned plus a rear s.s. flex brake hose and S&H.
85burb...it had this carb bracket in until I got to looking at the TV cable I had and what pieces I had and didn't have (would have needed whats called the kickdown bracket to go with it) and by mixing what I had I didn't need to buy anything else. The TCI bracket is deff. sturdier and Lokar cables are built nicely. here's what the Lokar bracket looked like. I should mention...my TV cable had both the slider type attachment and the black plastic clip-on, both using the barrell type cable lock...and after having a failure... I have a thing about plastic in my linkages. Also, I left some length on that TV cable for now...just so if I do decide to move/change something I'll have the length to do it. http://lokar.com/interior_pages/prod...es/srk4000.jpg ...and here's how it would be w/the kickdown mounting bar on the bracket http://lokar.com/interior_pages/prod...00-drawing.jpg edited the pics to urls.....someones not allowing the linking...
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken Last edited by 68GMCCustom; 02-10-2011 at 10:48 PM. |
#239 |
The pics did not show up. They just look like red Xs. Why do some pics look like that?
#240 |
irritates me when sites do that...here's a pic from Summit.
![]() TV cable adds a second bar that drops down...making an upside down V sort of.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken Last edited by 68GMCCustom; 02-10-2011 at 10:54 PM. |
#241 |
Oh i see. Looks nice. Yes it is just about the worst thing when pics dont show up. Like the ones you really want to see like some one just put new motor in and it looks like a tiny box with an stupid red x in it. Really blows the hole moment.
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle Last edited by 85burb; 02-10-2011 at 11:06 PM. |
#242 |
Pulled about a mile or more of electric tape off of my trucks external (under hood) wiring harnesses today. What a mess! Looking at the wire it looks like someone bought new harnesses (except rear harness)... then hacked them all up!
![]() I cut out a bad patch in the rear lighting harness and soldered/heat shrinked in some new wire then wrapped with friction tape. I have the harness installed now but not locked down. I know....I know...I'll try to post the pics tomorrow. ![]()
#243 | |
#244 |
nothing exciting...but heres the pics:
repairing 2' of the harness for the rear lighting. Spliced, soldered, shrink wrapped, over-shrink wrapped, and then friction tape wrapped: ![]() ![]() ![]() ![]() some of the wiring mess after I pulled it all apart: ![]() ![]() ![]() the new "news".........inline tubes brake line fittings, T's, and rear s.s. flex hose should arrive today, a few new tools (3/8" TAP to fix a bung + 1/4" NPT TAP cause I don't have one) on Monday or Tuesday...and.....B&M Truck Megashifter on Tuesday or Wednesday. I decided I didn't want to wait for it and fight the column shifter at the track. ![]()
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken Last edited by 68GMCCustom; 04-16-2012 at 03:33 PM. |
#245 |
If you want when you are done with your wires ya can come help mine out... Looks really good. Wifes truck had a floor shifter and i loved it. Want one in the burb but the hole 4x4 shifter is in way.
#246 |
Oh no......wiring is certainly not my calling.....since I'm color blind!
![]() Didn't really want to have to spin the coin for a shifter...but it was necessary for track use. I installed the O2 sensors for the UEGO gages and routed the cables into the cab. Looks like I'm gonna leave the MSD box under the hood as its too much harness to bring into the cab. Got the starter wires wrapped and routed, and then roughed up and spray bombed semi flat black under the dash to cover all the blue...since I'm going in with all black carpet and trim. It will look good enough with everything in... until I pull it all apart again to paint it properly in a year or so. ![]() ![]()
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken Last edited by 68GMCCustom; 04-16-2012 at 03:34 PM. |
#247 |
Looks great. Wireing is deff not my calling. I start out doing good job then get in a hurry and just do it to get it done. You should see under my dash..... Scares me sometimes. Do you think they gave you enough uego wires. I have like a 10 foot coil of it zip tied to my steering colum under dash.
#248 | |
Still Learning
So if you don't mind me asking, what does a "complete" SS brake line setup cost you from inline? I'm at the point of needing to decide what to buy. I appreciate your help. |
#249 |
well the full s.s. brake line set is $185. I don't have the invoice in front of me...but I think I spent another $75 or so on a rear s.s. hose (got the 2 front s.s. hoses with my CPP brake kit), all the brass T's, all the fittings, and all the clips... + S&H.
So....something like $250-$260? Making it $300 or so with all 3 (2 front-1 rear) s.s. hoses plus the s.s. line set and all the hardware.
#250 |
more parts in.....shifter, brake fittings, and a couple of TAPs and TAP wrench.
Now I can finish fuel system, brake system, and engine/trans linkages. I'm also working on the electrical....so it won't be long before I can prime this thing up and light the fire!
