Old 02-08-2011, 08:18 PM   #1
72 tigger
72 tigger's Avatar
Tach question
Bought a gauge cluster with a Camaro tach- the guy said it worked when he pulled it. The metal plate on the back of the tach has a 12V terminal & a COIL terminal stamped on it. I hooked a 12V lead to the 12V terminal & ran a lead from my HEI TACH terminal to the COIL terminal- it doesn't work. Does it need to be grounded? Any ideas? Thanks for your help! Kirk
72 tigger is offline   Reply With Quote
Old 02-08-2011, 08:29 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Tach question
if it is bolted to the inst panel, and the panel installed in the dash, then it should be grounded. If all the lights work properly, then it is grounded.
Sounds like a bum tach if all the above is true
Old 02-08-2011, 10:14 PM   #3
VA72C10
VA72C10
VA72C10's Avatar
Re: Tach question
The camaro tach I had before had a ground terminal also. I believe there is a thread on here with the terminals marked.
Old 02-08-2011, 11:11 PM   #4
PT'S 70 CST
"GO DAWGS"
PT'S 70 CST's Avatar
Re: Tach question
If you tried to test the tach out of the cluster then 12 volt hookup, HEI and a good ground. I am with VA72 I think it has a ground terminal and if not you can use alligator clips to ground it to the backing plate will be fine. That is the way I test all of my loose tachs.
PT
70 CST SWB
70 NOVA
93 Indy 500 Pace Truck (SOLD)
94 SILVERADO SWB 5/7 drop
2000 Silverado swb
2005 Nissan Altima 3.5 (Surprisingly very fast)
2004 GMC Yukon XL Denali
BATESBURG, SC. 29006
29006
Some of my restorations
http://www.snapfish.com/snapfish/thu...NAME=snapfish/
Restored Tach tins 8 cyl - 6 cyl
http://67-72chevytrucks.com/vboard/s...d.php?t=518185
Contact info(Not my paypal address) DAWGSFAN227@YAHOO.COM
God Bless Our Troops
PT'S 70 CST is offline   Reply With Quote
Old 02-08-2011, 11:45 PM   #5
VA72C10
VA72C10
VA72C10's Avatar
Re: Tach question
Here's the pic showing the ground I was thinking of
and Gringoloco's thread on it...
http://67-72chevytrucks.com/vboard/s...d.php?t=251017
Old 02-13-2011, 09:58 AM   #6
72 tigger
72 tigger's Avatar
Re: Tach question
I tried the tach again but ran a ground to the ground post & it works great! Thanks VA72C10 for the info!
Old 02-13-2011, 10:14 AM   #7
VA72C10
VA72C10
VA72C10's Avatar
Re: Tach question
Cool! Glad that got it working!
Old 02-13-2011, 11:34 AM   #8
Longhorn Man
Re: Tach question
sweet... glad I was wrong!
