Old 02-08-2011, 09:54 PM   #1
JMac11
JMac11's Avatar
Quadrajet Beat down
Gotta Crow...... took about twice as long as it should, had one more fire than planned but I did it. I rebuilt a Quadrajet for my 84 K10 and it works better than it did before. I had paid an old timer 25 bucks to go through it last year with not so good results. Pretty sure the (insert chain parts store) kit was wrong, some of the choke linkage was wrong and the whole choke housing was loose.
I am sure that my success is based on several things.
1) Buy Cliff Ruggles book/ parts, read it twice before you start
2) Take pictures or have internet access because some of the linkage is a bear
3) Take your time
4) Be gentle
I plan to drive it for a while to base line the stock rebuild and then do some of the improvements in the book.
JMac11 is offline   Reply With Quote
Old 02-08-2011, 10:08 PM   #2
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: Quadrajet Beat down
After seeing your thread title, I was looking for another Q-jet bash thread....
These things are easy as pie to rebuild and custom tune once one LEARNS how to work on them, As you found a book there are many many how too's all over the net.
It's good to hear you were successful your first time, The more you work with them the easier they get and the better you can make them perform.....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 02-08-2011, 10:52 PM   #3
dieseldr4
JMac11, good to hear you got a handle on it.. i just had mine done by a local guy (needed throttle shafts bushed) and it is awesome now as well, well almost.. have any of you had them drip gas from the boosters at idle? mine is and i suspect the float level is a little high.. id take it back to the guy that did the carb except i always have to leave my truck with him for a week or he takes the carb and my truck sits at home for a week.. what do you guys think about the fuel dripping from the boosters at idle?
any help is appreciated,
thanks, diesel
be a site supporter
dieseldr4 is offline   Reply With Quote
Old 02-08-2011, 11:37 PM   #4
geezer#99
geezer#99's Avatar
You're right. Float is a little high!!
Old 02-08-2011, 11:45 PM   #5
dieseldr4
thank you geezer!
be a site supporter
Old 02-09-2011, 07:51 AM   #6
Restrorob
Restrorob's Avatar
^^^^ Ditto,
You can pop the top without removing the carb to lower the level a little....
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 02-09-2011, 08:26 AM   #7
andyh1956
q jet builds do best w/ a new float. over time they get heavy & the fuel they displace changes from factory float settings. another tip is during re build always install a fuel well plug it. that kit will stop the factory plugs from leaking when the carb gets hot.
andy
andyh1956 is offline   Reply With Quote
Old 02-09-2011, 09:50 AM   #8
geezer#99
geezer#99's Avatar
Ditto what Andy said. If you've never had a quadrajet apart before pull it off the motor. There's a few small screws and clips that are easily lost. Easier on a work bench.
Old 02-09-2011, 10:56 AM   #9
JMac11
JMac11's Avatar
Followed the reccomendation in the book. Ruggles suggest a large cookie sheet, I bought a drip pan from the parts house, about 3'x4'... great idea, easy to clean and store in a small shop.
Old 02-17-2011, 09:17 PM   #10
JMac11
JMac11's Avatar
Update.... Topped off last Thursday, 96 intown miles, still tweaking choke, idle mixture, idle speed, fast idle and idle up solenoid. Barely jammed 10 Gallons of gas in it tonight. I figure that a solid 10 miles to the gallon in town.
This is with an 84 K10, 700r4, 2.73 axles, and 33x12.50 tires. Engine is a L31 Short Block, Trick Flow Heads, Lunati Voodoo Cam, Performer intake, Hooker Headers and a Quadrajet.
Next up, rebush throttle plate, and some other suggestions from Ruggles book.
