Old 01-02-2011, 05:05 PM   #1
ol yellow 72
ol yellow 72's Avatar
clutch fan vs. flex fan for fuel eco.
simple question im running a flex fan on my 350 with a 3 inch spacer. would i gain fuel mileage if i swap back over to a stock clutch fan setup?
ol yellow 72 is offline   Reply With Quote
Old 01-02-2011, 05:11 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: clutch fan vs. flex fan for fuel eco.
Absolutely
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 01-02-2011, 05:49 PM   #3
Restrorob
The One And Only !!!
Restrorob's Avatar
^^^^ without a doubt.....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 01-02-2011, 05:51 PM   #4
mooseknuckles
mooseknuckles's Avatar
....and maybe a little bit of hp!
mooseknuckles is offline   Reply With Quote
Old 01-02-2011, 05:52 PM   #5
3r!c84
Badass
3r!c84's Avatar
flex fans have a bad rep for falling apart and going threw the hood and rad. not so safe. id put back the stock one!
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 01-02-2011, 06:06 PM   #6
benoit454
Chris
benoit454's Avatar
yea everyone says that and we've had them for years and ran them past 7l rpms never a problem. Not to mention they cool better then clutch type. always have for me.
As for constant drag and freeing up accessories, yea they will and it will add maybe a hp or 2 if you're lucky and you might get a 1 mpg improvment if that.
IMO you want to save power and gas, get electric fans.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 01-02-2011, 06:07 PM   #7
baclay9
When buying a clutch for a clutch fan do you want the regular one or a thermal one?
baclay9 is offline   Reply With Quote
Old 01-02-2011, 06:16 PM   #8
ol yellow 72
thanks guys for a quick responce, looks like im hitting the junk yard tommorow
Old 01-02-2011, 07:52 PM   #9
dmartin1
dmartin1's Avatar
i got dual electric fans set-up and the radiator mount and all for them for 50$ all together,the front of the engine looks amazingly better,i imagine my gas mileage has rose,and they cool it great!
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline   Reply With Quote
Old 01-02-2011, 08:48 PM   #10
benoit454
Chris
benoit454's Avatar
no doubt e fans really clean it up underhood for sure. More room and cleaner.
Chris
GIT R DONE!!!!!!
Old 01-05-2011, 12:04 AM   #11
355GoldieGM
355GoldieGM's Avatar
is that a kit you got?? and if so where at?? 50 bucks is cheap for dual fans!!
BAM BAM
My Project:
http://67-72chevytrucks.com/vboard/s...ghlight=goldie
355GoldieGM is offline   Reply With Quote
Old 01-05-2011, 12:29 AM   #12
bigblock73
yeller
bigblock73's Avatar
I ran a flex fan once, never again...didn't keep the truck cool enough (and they look cheap). Put on a new stock clutch fan, NEVER had an issue. Couldn't tell a power or mileage diff with either, the peace of mind was "cool" enough for me. Elec fans are nice, but I prefer the simplicity of a clutch, and they are easier to put in.
bigblock73 is offline   Reply With Quote
Old 01-05-2011, 02:32 AM   #13
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Would you keep a stock clutch fan in the case of a LS swap? (Sorry, not trying to hijack the thread, just weave it a bit)
http://67-72chevytrucks.com/vboard/s...d.php?t=419809
http://67-72chevytrucks.com/vboard/s...d.php?t=414820
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 01-05-2011, 02:15 PM   #14
benoit454
Chris
benoit454's Avatar
I had the exact opposite happen then what jeff had....
I had my monte carlo ss and nothing changed other then the fans, ran a clutch fan because everyone said how much better it was, wrong, the thing over heated. Now don't jump in and say oh the clutch was bad, again wrong, the clutch was working perfectly and kept my old mans 86 k10 cool with a/c all day long idleing in traffic. Mine jumped up to over 250 and popped the upper radiator hose. It blew it off the thermostat housing, and it was tight. I bought a flex fan and the car would never get past 180 or so in triple digit high humidity heat idleing in traffic.
The clutch fan done good in his truck, never a problem, the clutch fan in my 88 does great too, never had a problem with it.
The monte carlo had a small narrow blade 16 inch flex fan, and cooled good driving, but not in traffic, so I tried the clutch fan and it just kept creeping up while driving until it got over 250 and we were pulling off to shut it down and it started acting funny, then bam the hose blew off. I bought a wide blade 18 inch flex fan and it never got past 180 or 190 again. I had either a 160 or 180 t-stat in it I forget which.
So honestly I think if you got a flex fan and it works great, keep it, swapping might hurt it, like it did me.
If you got a clutch fan and it works good, keep it.
If you got a flex fan and it doesn't cool good, see what size it is, and the blades, narrow or wide, if they are narrow go with wide, if it's small get the biggest you can fit in your shroud.
If you got a clutch fan that's not working good, check the clutch or change it, if it works get a big flex fan with wide blades.
That's if you want mech. fan, if not then any of the above go with electric to save fuel and drag on the engine. I have yet to swap to electric but would like to, just afraid of it not cooling enough, but I know if you get the right fans it will. If they can cool a v8 camaro with like no grille opening for air, it should cool a truck with a huge grille area for sure.
Chris
GIT R DONE!!!!!!
Old 01-05-2011, 02:23 PM   #15
bigblock73
yeller
bigblock73's Avatar
Chris, what you mentioned and I am sure you may know about...is that the fan (clutch or flex), needs to be positioned properly in the shroud. I assume this could be several peoples problems or phobias about each one way or another.
Old 01-05-2011, 02:23 PM   #16
bigblock73
yeller
bigblock73's Avatar
Never gave it any thought, I can't really give you a good answer.
Old 02-04-2011, 01:07 PM   #17
ironroad9c1
Master Hater
Always run a Thermal clutch fan. You couldn't give me a POS flex fan, they are a crutch , If you have to have a flex fan to stay cool, then you have other problems.
1997 C1500 ECSB 4.3/NV3500 8.5 3.42
"This evening, all of you bleeding hearts... why don't just go ahead and hug yourself for the next 20 minutes or so, because there's a really good chance you're gonna be offended".- Captain Owen Honors
ironroad9c1 is offline   Reply With Quote
Old 02-04-2011, 08:55 PM   #18
Shawn5488
Always use a stock fan and fan shroud, try to get a RV or snow plow prep clutch as they will engage lower and harder for better cooling.
Shawn5488 is offline   Reply With Quote
Old 02-04-2011, 08:56 PM   #19
mooseknuckles
dual electric's the way to go!
Old 02-08-2011, 01:16 PM   #20
burger
Do you have pictures of your setup? I assume you pulled this from the junkyard. What was the original application?
Thanks,
Ed
burger is offline   Reply With Quote
Old 02-08-2011, 08:40 PM   #21
johnnypop
I have dual electric fans and they work amazing... Popped a fuse once, but now I carry spare fuses and haven't had it happen since. Idling up and down 4x4 trails in 90 degree heat, romping it on the same trails, cruising down the freeway, pulling up grades... always stays put.
johnnypop is offline   Reply With Quote
Old 02-08-2011, 09:16 PM   #22
3r!c84
Badass
3r!c84's Avatar
johnnypop what fans are you using. and what relay
-00 Saturn 5spd
1/4:13:90
Old 02-08-2011, 10:38 PM   #23
johnnypop
They're dual 13.5" flex-a-lite fans, the relay is built into/mounted to the fan shroud and came with the kit... they call it the variable speed control module on their website.
