Old 02-07-2011, 03:45 PM   #526
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: ** YOUNG FRANKENSTEIN** The truck Chevrolet should have built.
The bed is looking great!
Ryan
1969 Chevy milk truck
Old 02-07-2011, 04:16 PM   #527
67chevy1series
67chevy1series's Avatar
Originally Posted by drewskiren View Post
Nice one Barney.
Pretty stinkin funny.
man you guys remind me of my uncles ....always crackin jokes!
67chevy1series is offline   Reply With Quote
Old 02-08-2011, 08:02 PM   #528
drewskiren
Lucky Teter at the wheel
drewskiren's Avatar
Got my tailgate and cowl panel in primer so they won't rust. Look at that tailgate, it is bare - no bondo work yet. So fine!
Drew
YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!)
The Bride is currently under the knife!
drewskiren is offline   Reply With Quote
Old 02-08-2011, 08:24 PM   #529
Dieselwrencher
That is a super nice tail gate! Are you going to cringe when you have to drill holes for the trim?
Ryan
Old 02-08-2011, 10:59 PM   #530
67chevy1series
ryan thats a good one! man that tailgate is clean!!!!! 68 tail gate......
Old 02-09-2011, 12:02 AM   #531
VA72C10
VA72C10
VA72C10's Avatar
Super nice gate!!!
Old 02-09-2011, 02:04 AM   #532
drewskiren
drewskiren's Avatar
Started on the gas tank install.
Earlier when I was mocking up the bed, I noticed I would need to lower the gas tank one inch in the front. I wasn't sure how to accomplish this until I started in on it tonight. I went out to another parts truck and cut the strap bracket off and welded it to the bottom of my existing one. A little paint later and one side is taken care of. The other side bolts the strap to the frame. I couldn't find a bolt long enough to extend an extra inch so I cut the head off, cranked the heat up on the welder, and welded a 1 inch bolt to it. Having a welder can make anybody a genius. I used a 1.5 inch thick rubber body biscuit as a spacer between the gas tank and the frame and a half inch rubber spacer on the side of the frame to get the gas tank off of my rearmost cab mount. Still have room for my filler neck to clear the frame rail. Whew !
Drew
Old 02-09-2011, 02:16 AM   #533
drewskiren
drewskiren's Avatar
Next was the charcoal canister and some little electronic gizmo connected to it.
The canister mounted to the hoop shaped driveshaft carrier bearing mount that I chopped off long ago. I went back and cut the mounting tab off of the hoop, made a few modifications to it, and welded it to my new driveshaft carrier bearing mount. The gizmo used to mount to a frame/bed mount that I also chopped off. Hmmmm, now where can I mount this little sucker? How about that new extra long bolt I just made. I cut the little mount tab, flipped it around 90 degrees and welded it back together, then ran a nut down my long bolt, slipped on my newly modified mount tab and put another nut on top of that.
Drew
Old 02-09-2011, 02:59 AM   #534
VA72C10
VA72C10
VA72C10's Avatar
Nice work! Looks almost like factory
Old 02-09-2011, 02:46 PM   #535
ajgriffin
ajgriffin's Avatar
Sandblaster with good air pressure is the bomb!
I know I'm a little late, but how did that Eastwood's soda blaster work for you? I'm thinking about getting that combo sand/soda blaster they have, but am not sure if I would get the results I'm after
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together
ajgriffin is offline   Reply With Quote
Old 02-09-2011, 04:58 PM   #536
drewskiren
drewskiren's Avatar
It worked great. I have used it twice now, but the first time I didn't have enough air compressor. Now I have a very large 220 Ingersol Rand and it worked great. The thin original paint came off so fast it was ridiculous. The bed that had original paint and a roll on bedliner was a lot slower. I used 2.0 cutting abrasive, a very powdery sand. Never tried soda.
Drew
Old 02-09-2011, 11:30 PM   #537
drewskiren
drewskiren's Avatar
AIR RIDE
It is snowing again in Memphis and that means the whole town shuts down. What that means for us is more time to work on our patient!
I hung the driveshaft to see how much room I have to mount all of the Air suspension mechanicals. Not much, but I have it figured out. I started making brackets to mount the compressor, valve body and air tank. Daughter wanted to watch an old James Bond movie, so we are done tonight.
Drew
Old 02-09-2011, 11:36 PM   #538
jbclassix
Junk Yartist
jbclassix's Avatar
If it makes you feel any better, I have been working in the garage for 30-45 minutes, and then go in and warm my hands up in the kitchen sink!
Somewhere on your truck you need to put a piece of tape that says "Abby"... maybe your ECM.
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 02-09-2011, 11:36 PM   #539
Dieselwrencher
Nice work!
Ryan
Old 02-09-2011, 11:45 PM   #540
drewskiren
drewskiren's Avatar
Abbie... Abbie who?
Abbie Normal...... and the ensuing tirade. Hysterical.
I'll get my youngest on that, she'll come up with something good we can stick on there.
Drew
Old 02-10-2011, 02:23 AM   #541
VA72C10
VA72C10
VA72C10's Avatar
Nice. Going to be a cool bus
Old 02-11-2011, 12:19 AM   #542
drewskiren
drewskiren's Avatar
We worked on Gnande's Olds 98 today trying to get it through inspection. replaced the battery, headlight switch, and flasher unit. Now it starts, has lights, and turn signals. Maybe we can get a tag for him tomorrow! He was grinning ear to ear.
We undercoated the bed and cab bottoms with Eastwood products and I think we are ready for the rain.
Drew
Old 02-11-2011, 12:22 AM   #543
VA72C10
VA72C10
VA72C10's Avatar
That should be nice and durable now!!!
Old 02-11-2011, 12:34 AM   #544
drewskiren
drewskiren's Avatar
I fabed up all of the mounts for the air systems and welded them onto the carrier crossmember and the ABS bracket. The tank squeezed in there and fits like a glove. The compressor is just shy of hanging below the frame. We also cleaned up the transmission and will paint it later.
Drew
Old 02-11-2011, 02:06 AM   #545
drewskiren
drewskiren's Avatar
Originally Posted by BlackTopMotors View Post
Love your thread, you have some amazing skills!
Originally Posted by Newtz67 View Post
Somehow I've missed this thread until now. I just spent about an hour reading through the whole thing. Amazing! Subscribed!
Originally Posted by VA72C10 View Post
sweet!!!
Originally Posted by Dieselwrencher View Post
Nice work!
The more I see this build the more I want to build one for myself....especially when I keep looking at the completed pics of the 50th anniversary one...
Originally Posted by 67cheby View Post
Sweet
Thanks for the pics....looking good!
Originally Posted by mcbassin View Post
Hey, that frame looks great! you are kicking some serious tail on this build! Keep the pics coming!
Originally Posted by 67chevy1series View Post
i dont think gm painted there frame this well nice job drew your lucky you can run all the rims that we cant because that frame!
Originally Posted by Pop's C-10 View Post
looking good hometown
Originally Posted by 69CST-V View Post
You make it look so easy. I find myself reading your build instead of building mine. LOL Great job.
Drew, it looks great, nice job.
Nice!!!
Originally Posted by Airborne70GMC View Post
This build totally rocks I had thought about this idea abround 15 years back when I was single and had less bills(ha ha ha). It is a great idea and Completely RULES. Keep it going and Hang tough. God bless.
Originally Posted by Mr Chevy View Post
Hey Drew I just looked at your build thread for the first time today. Awesome work. I cant wait to see your truck finished.
Your work has inspired my son and I to get back out in the garage and finish up his 1970 C-10
Originally Posted by jgh64pkup View Post
Great build subscribed
Originally Posted by LEEVON View Post
:pve it, and have always had a soft spot for that Fesler-built crew...
Looks good from here
Nice work Drew! Thanks for the update with pictures. I can't wait to see the sandblasting pics. I just did some of that a while back.......fun.
Looking good guys
Are you sure my schedule wasn't right....you're really moving on the truck right now...you might be done before your target date if you can keep this pace up
Looking great!!!
Very nice! It's great the whole family gets involved!
Originally Posted by extremesounds13 View Post
Looks great!! I can't believe how fast you work!
wow looks clean! if i had a metal floor i would have hoped it would be this nice....
Looks good! I'd say since it isn't perfect according to you and you plan to use it, I'd line the underside and the top.
Super nice gate!!!
Nice work!
Thank you everyone for the positive reinforcement!
Drew
Old 02-11-2011, 02:23 AM   #546
mcbassin
Still Learning
mcbassin's Avatar
Nice work as Always Drew! You keep us inspired.
Old 02-11-2011, 12:04 PM   #547
wwhijr
SUPERscrapMAN
wwhijr's Avatar
WOw this truck is too nice. I think you should give it to me so you aren't tempted to be prideful or anything like that.
Christine 1987 Chevy S10 2.8l 5 speed 600k miles! still chugging along - wifes ride
Old Smokey 1990 Chevy K1500 Suburban 6.2L Diesel - Banks sidewinder
The WarBeast 1994 Chevy Suburban K1500 - Semi retired at 400K miles
The BLueOx 1994 Chevy Suburban. K2500 454 Used on a daily basis.
wwhijr is offline   Reply With Quote
Old 02-11-2011, 02:35 PM   #548
drewskiren
drewskiren's Avatar
Would you take it off my hands? I'd be so grateful.
Drew
Old 02-12-2011, 11:27 AM   #549
drewskiren
drewskiren's Avatar
Bought my quarter inch plate today to start on the rear suspension 4 link. Also going to start to pull the engine from the donor truck.
Drew
Old 02-12-2011, 01:40 PM   #550
classicchev
classicchev's Avatar
Progress looks great BTW
67- 72 Parts collecter
classicchev is offline   Reply With Quote
