Machine shop wows.
Just got a call from the machine shop and he quoted me $584 for the head work!!! I think I got an ok deal on the block ($800) but man thats steep. He said that everything was worn, the exhaust had started warping the side. and that it need hardened seats.. Id be concerned about being ripped off, but hes pretty respected around here... Man what a damper it puts on things.. This is only for a 250. It better outlive me damnit! lol
66 Gmc 1 ton. Long Step 351e V6 69 1/2 CHEVROLET (now a shortbed) LONGBED! ![]() ![]() 61 Shortbed Fleetside 1/2 ton.. in progress Next a 50-53! MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=447926 Last edited by BadaSs_Cal; 02-09-2011 at 06:41 PM. |
#2 | |
Re: Machine shop wows.
yes. It will be brand new when I get it back.. thanks for the comment made me instantly feel better. He did my father in laws 350 head and it was $400. But I dont think it needed as much as mine did.. you know because its only 30 years older. LOL.
66 Gmc 1 ton. Long Step 351e V6 69 1/2 CHEVROLET (now a shortbed) LONGBED! ![]() ![]() 61 Shortbed Fleetside 1/2 ton.. in progress Next a 50-53! MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=447926 |
My machine shop did my 250's head for $150, new valves, pressure test, redid the seats, cleaned, reconditioned the springs etc, surfaced it and removed a valve cover bolt broke off in it.
---| 1967 GMC Stepside |-- 250 L6 .030 over ---| 1985 Porsche 944/1 |--- Build Thread: '67 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=378640 Last edited by LandonL; 02-09-2011 at 07:14 PM. |
![]() Join Date: May 2005
I did a ton of valve jobs- 3 angle, knurl guides and surface heads for $125 a set 15 years ago. Replacing guides was 10 for the first five for any other. Lokks like I could make a living in a maching shop these days.
wow! Man u got a killer deal. I looked around a bit, it seemed the average around here was about $300. but I went with them because it was the only place I could get feedback on. Im new to any of this, so I guess this I can put in the hat as a learning experience. Im sure it will be worth it once I crank it over.
quality machine work costs.
luckily, the chinese have not figured out a way to do this sort of work locally. yet. |
Who's got steelies?
![]() Join Date: Feb 2006
I had a pair of small block head done last month. It was about $250 for the pair & they look brand new.
![]() ![]() ![]() ![]() ![]() ![]() How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
the boat guy
I've heard several times that a cheap set of aftermarket aluminum heads for a sbc is only a couple hundred bucks more than having a set of doublehumps redone.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
I couldnt find a place I could rely on for a redone 250 head. Didnt wanna cheap out and get the 200$ autozone one. I prefer quality over cost.. however I have a price limit.. $1200 bucks from 12bolt was way out of my range... and I just needed a stocker. O well, Ill take it to a buddy afterwards and have it confirmed the shop did everything they said they were going to do... and drive it like an old lady.
I have pics of my entire six silly build, but here a pics of the head after it was redone. He had painted it a cast iron grey to keep it from rusting after he got done hot tanking it.
In the pics I had already painted it orange. ![]() ![]()
---| 1967 GMC Stepside |-- 250 L6 .030 over ---| 1985 Porsche 944/1 |--- Build Thread: '67 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=378640 |
VA72C10
![]() Join Date: Mar 2008
I'd also consider looking at new heads at that price. You could sell the originals to someone wanting to go 100% original (before paying for the machine work) and get a nice set of the summit vortec style heads or skip white heads for just a little more but with much better performance...
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
The Older Generation
I was just quoted $250-300 to completely re-do my 327 heads. New guides, hardened seats, trued, etc, etc. If they were camel hump I would probably do it but not for run of the mill heads. Now I'm looking. LockDoc
i had a set of SB heads done 7 years ago & it cost $597.00,with unleaded fuel of today, you need to put harded seats in the exhaust side, i also had bronze guides installed,new springs for the lift on the cam in which it good for a .525 lift cam & they replaced some valves, clean & check the heads for cracks, it depends on what you want done to the heads, & what it going to cost you,i want stainless steel valves & that would have been another $140.00.Head & block work is not cheap & you could be in the $1500.00 to $2000.00 range, time for a good crate motor for &1500.00 to $9000.00 more power ARHHH, ARHHH, ARHHHH
#15 |
Around here a complete head rebuild on pair of small block heads that needed valves,seats,and guides ran about $300 25 years ago.To me that price sounds about right for the Bay Area. It needed planing and all. $150 sounds crazy cheap.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 02-09-2011 at 08:58 PM. |
#16 |
This board is the home of $200 powder coated frames, $100 sandblasted cabs and swb, big blocks for 5K. I'm expecting to hear some people only pay a nickel per gallon for gas Everything costs $500!
71 GMC 1500 LWB |
#17 |
I did buy the valves on mine separate so they weren't necessarily included in the cost. $150 was just his charge on labor, no parts included.
---| 1967 GMC Stepside |-- 250 L6 .030 over ---| 1985 Porsche 944/1 |--- Build Thread: '67 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=378640 Last edited by LandonL; 02-09-2011 at 09:16 PM. |
#18 |
Not to steal the thread or anything. How much would a set of new heads cost? What would be better machining them out or buying new?
1969 Chevy c20(Miss Hackjob) |
#19 |
Cruzin
that ol 250 should last you for a long time in my op. the inlines are one of the most reliable motors ever. I had some 350 heads completely redone this year and it was around $275 and i thought that was high
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
#20 |
Grandpa in the rustmobile...
lol hub
you can get summit vortec heads for $650, thats what I did..
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#21 |
Wow I just read all of your build.. thats good stuff there. still gives me hope yet. Thanks again.
#22 |
Still Learning
I run a Machine Shop not engine shop but aerospace and I can tell straight out it is very expensive to get anything made. There is a lot more that goes into it than just the guys hourly wage. Our rates average around $100 an hour. so go figure. If you think you got your moneys worth that is all that matters.
I can remember when my engine guy could hot vat, line bore, .030 over, and install cam bearings and valve job for around $300 on a SBC. That was back in the late 80s and early 90s I'd bet the same job is around $500-700. Good luck! |
#23 |
![]() Join Date: Dec 2007
Replacing valve seats can get expensive. Sounds about right. If he stands behind his work, I'd say its worth it. Quality machining is not cheap.
Headwork $600 Block machining $800 Gaskets, etc. $200 Confidence in your engine? Priceless..... Last edited by 5150.4.67; 02-10-2011 at 01:45 AM. |
#24 | |
Watch out for your cornhole !
![]() Join Date: Jun 2003
And that is why crate engines are so popular. 1700 dollars at the dealer will get you a 100 percent new 4 bolt main 350 engine. With warranty... When a guy gets to adding up all of the costs, he's really got to make a decision as to which direction to go with his hard earned dollars. If someone wants a stock engine, crate is a great value.
#25 |
Thanks guys this makes me feel a whole lot better about the whole thing. Like I told the wife last night, I could of took the easy way out and went with a crate V8.. But imagine when I pop the hood and all the old timers start grinning ear to ear. Even my machinist was excited when I told him it was an inline I was bringing in. ( but maybe thats because he knew it was a gold mine... lol) Well as soon as I get it back I post up some pictures.
66 Gmc 1 ton. Long Step 351e V6 69 1/2 CHEVROLET (now a shortbed) LONGBED! ![]() ![]() 61 Shortbed Fleetside 1/2 ton.. in progress Next a 50-53! MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=447926 Last edited by BadaSs_Cal; 02-10-2011 at 09:12 AM. |
