02-07-2011, 12:04 PM | #76 |
Vintage 4x4s
Re: 67 gmc 4x4
Bob B, would you have a picture of the correct mount in your truck? I'd like to compare with mine.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
02-07-2011, 02:35 PM | #77 |
Re: 67 gmc 4x4
Great truck. I have my 68 apart for a complete frame-off restomod. If you have any questions or need pictures let me know.
Erl
1968 GMC 305 V6 3/4 4x4 Stepside 06 Corvette Daily Driver Dallas TX |
02-07-2011, 09:48 PM | #78 |
Re: 67 gmc 4x4
Jud, have you been doing anything else to your truck? I'm surprised that they did not move your thread over to the 4x4 section also.
Erl, thanks for the offer to help. You have a great truck. I love those LWB stepsides. I will let you know if I need any other pics. --Clint Last edited by 75gmc454; 02-07-2011 at 09:48 PM. |
02-07-2011, 11:31 PM | #79 |
Re: 67 gmc 4x4
Rick here are the pics of the back of the truck:
When I started looking more closely I noticed that the top was white: Here is a better pic of that butchered motor mount: And here is what that tall mount is doing: |
02-07-2011, 11:47 PM | #80 |
Vintage 4x4s
Re: 67 gmc 4x4
Clint,
It looks like my valve cover is about 3/4" from the firewall at the closest point. I'd still like it if Bob or Erl could post a pic of what the original mounts look like. It seems like your crank pulley has three grooves! Mine has 2. I'm going to update my thread a little now, we'll see if it gets moved. Jud
02-08-2011, 12:09 AM | #81 |
Re: 67 gmc 4x4
Sounds good Jud. That third pulley is for the A/C. That is the one that is very close to that crossmember.
I took that cowl piece off to clean all of the leaves out and get those drains open. It was loaded with leaves and trash. |
02-08-2011, 01:02 PM | #82 |
Re: 67 gmc 4x4
Guys, I will post some pictures when I get a chance in the next day or so. Sorry, I have been busy. I'll also explain the pulleys. Bob.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
02-08-2011, 10:09 PM | #83 |
Re: 67 gmc 4x4
That sounds good Bob.
I think I have found what the problem is. Someone has put shims under all rear mounts for some reason. That caused the A/C pulley to rub that front crossmember. Then someone welded those tabs on the drivers side motor mount to raise the front of the engine. I am going to start over by finding the right mount and taking out all of those shims and see what happens. I drove the truck today, and I cannot get the front drive shaft to stop turning. I have the truck in 2wd and the hubs unlocked but it still turns. It is not the front axle because I jacked up the truck and they are unlocked. The problem is with the transfercase. Any ideas? |
02-09-2011, 12:17 AM | #84 |
Chevy Enthusiast
Re: 67 gmc 4x4
Very nice truck, cant wait to see the restoration!
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
02-09-2011, 12:50 AM | #85 |
Re: 67 gmc 4x4
thanks for the pics tail gate isnt bad at all you should see if you could wet sand the blue off of the roof and get some trim on there!
02-09-2011, 03:24 PM | #86 |
Re: 67 gmc 4x4
Here are some motor mount pictures. My truck is completely apart, but going back together now. So, everything is exposed and available for photos.
Erl
02-09-2011, 07:27 PM | #87 |
Vintage 4x4s
Re: 67 gmc 4x4
Thanks Erl, love your truck by the way! Are the rubber mounts original? Could you get a closeup photo of them and measure the thickness?
Also, your PS pump bracket is welded like mine, is that one that you had custom made? I assume the original PS brackets were not welded. I don't think the ram assist on my truck is factory since the bracket was welded.
02-09-2011, 09:42 PM | #88 |
Re: 67 gmc 4x4
Thanks for posting those pics. Yes Erl your work looks great. Everything looks original on your truck. I see now I must find some of those mounts. I would also like to find some original radiator hoses. Mine has those hoses you can use for different applications.
Posted via Mobile Device |
02-09-2011, 09:56 PM | #89 |
Re: 67 gmc 4x4
Jud, thanks for requesting the pics. They have answered some of our questions.
If you dont want that power steering I'll buy it. Lol Posted via Mobile Device |
02-10-2011, 12:32 AM | #90 |
Vintage 4x4s
Re: 67 gmc 4x4
Clint, there are some additional photos here in post 26. You may want to prevent him from scrapping them: http://67-72chevytrucks.com/vboard/s...=437680&page=2
02-10-2011, 05:29 AM | #91 |
Re: 67 gmc 4x4
I think I know what the problem is on the 4X4. The original V-6 motor mount used on all trucks with manual transmissions is part #2391949, and it has not been availble for some time. It looks to me like someone substituted a different mount. Here is side and bottome views of my left mount:
02-10-2011, 05:40 AM | #92 |
Re: 67 gmc 4x4
Here are pictures of the side and bottom of the right side motor mount:
02-10-2011, 06:00 AM | #93 |
Re: 67 gmc 4x4
I agree the engine is setting too high in the 4X4. Look at the A/C vacuum can on my truck, and see how close it is to the valve cover. It looks like the P.O. had to remove it for clearance. BTW- that bracket that goes around the upper radiator hose is for an AIR (smog) pump. V-6's in 1500's with manual transmissions sometimes came with them.
02-10-2011, 06:25 AM | #94 |
Re: 67 gmc 4x4
All '67-'69 GMC V-6's in pickups came with a 2 groove pulley on the crank hub (these engines do not use a harmonic balancer). The first groove closest to the engine is for the alternator and water pump, the second groove is for the power steering pump and water pump, if equipped. There is a second single groove pulley bolted on the front for the A/C compressor. This pulley is smaller in diameter than the 2 groove pulley. Back to the motor mounts, I have been told there is a particular transmission mount that will work as a replacement. I don't have a part number for it, but you might try asking on the '60-'66 GMC V-6 website forum. I believe that is where I heard about it. Hope this helps you guys out. Bob.
02-10-2011, 10:21 AM | #95 |
Re: 67 gmc 4x4
Thanks Bob for those pics and info. Your truck looks like it is very nice. It is a great color also. I can see exactly what I need to do.
I knew my truck had a smog pump because the manifolds are drilled for the air tubes. I can see where the vacuum canister was mounted on the side of the air box. I will do some searching to see if I can find the right mount to substitute. Clint Posted via Mobile Device Last edited by 75gmc454; 02-10-2011 at 10:24 AM. |
02-10-2011, 08:16 PM | #96 |
Re: 67 gmc 4x4
The 'tin can' style vacuum canister has a little stamped steel bracket on it. The replacement is a plastic ball shaped canister that has the bracket molded on it. The plastic canister is still available.
02-10-2011, 10:39 PM | #97 |
Re: 67 gmc 4x4
Thanks Bob. I think the canister on my truck still has the tabs on it. I can check when it gets warmer.
We got about 5 inches of snow yesterday. Here are a few pics of the 67 and since we are now in the 4x4 forum, Ill post some pics of my other 4x4's in the snow. Here is the GMC parked in front of the house: When it was snowing. Here is the 58 and the 73: Here is my 72 Last edited by 75gmc454; 02-10-2011 at 10:42 PM. |
02-10-2011, 10:54 PM | #98 |
Chevy Enthusiast
Re: 67 gmc 4x4
Nice! I'll take that 58 off your hands.
02-10-2011, 11:04 PM | #99 |
Re: 67 gmc 4x4
Thanks. Man I searched for a while before I found a napco truck. Not very common around here.
02-10-2011, 11:06 PM | #100 |
Young Gun
Re: 67 gmc 4x4
I'm not really sure about the lwb trucks but I see that lmc does offer 4 leaf rear springs for the half ton 67-68 and a 5 leaf for the 3/4 ton. I havent ever owned one. Well not yet anyways.
1968 chevy c10 soon to have 454 and turbo 4006 1970 custom/20 4x4 454/sm465/np205 around 7 inches of lift with 36's. 1992 2wd sierra 5.7 with edelbrock intake, headers, and a Chip. Posi rear with 235/75/15 tires. Soon to have a few more upgrades 2003 ccsb 1500hd |
