Old 02-12-2011, 06:06 PM   #1
JMARQUEZ_13
JMARQUEZ_13's Avatar
how to take apart upper a arm
This is my first lowering job and want to know how to remove a arm so i can put in a 3inch drop spring?
Josh
1968 C-10 Shortbox
JMARQUEZ_13 is offline   Reply With Quote
Old 02-12-2011, 07:59 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: how to take apart upper a arm
Don't touch the upper arm.
Remove the lower shock bolt
Unbolt sway bar clamp (if your truck has a swaybar)
Put a floor jack about an inch below the lower control arm
Pop the lower ball joint loose
Remove the spring
reverse to install.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 02-12-2011, 10:40 PM   #3
crakarjax
crakarjax's Avatar
Remove the spring
reverse to install.
A man of few words.
A few tips:
- chain the spring to the frame unless you are brave like me, or it may fly out at you (but probably not)
- replace the lower ball joint while you are at it, and the upper if it needs it
- if you have air tools, get an air hammer and a ball joint pickle for it, you'll break it free in literally a minute (took me about a half hour when I did it the good old fashioned way)
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
