Old 07-05-2003, 10:54 PM   #1
Terry S
Question motor mounts don't line up
I'm in the process of dropping a rebuilt 350 into my '72. When I took it out, the old motor mounts fell apart in my hand, so I bought new ones.
The problem is that I can't get them to line up with the towers now. I can get one or the other, depending on how I rock the engine back I forth. When I put one bolt in (just started) the other side of the engine is about 1/16th of an inch too high to get the bolt started. I spent three hours on this tonight, and no amount of prying, heaving or cussing has made this thing fit. It's like the towers are too close together or something.
Any tips to make this go easier?
I can do all things thru Christ, but he evidently doesn't want me to beat that Camaro light to light....
Terry S is offline   Reply With Quote
Old 07-05-2003, 11:00 PM   #2
Smooth68
Smooth68's Avatar
Can you post some pics of the mounts and towers?
Smooth68's Web Site
WTB 64-66 project or frame/cab, SWB or LWB...I have the fever! Whatcha got??
'68 Short Step - Shaved Body, Soon Bagged - SOLD
Driver-2004 GMC Z-71 Ext-cab
Smooth68 is offline   Reply With Quote
Old 07-05-2003, 11:00 PM   #3
LeRoy
Registered truck nut
LeRoy's Avatar
Try unbolting one of the motor mount stands. Then once the rubber mount is attached to the block rebolt the stand. Sometimes that's easier
MOUNT VERNON, WASH. STATE
Need a part? Just PM me
LeRoy is offline   Reply With Quote
Old 07-05-2003, 11:15 PM   #4
melloyello
melloyello's Avatar
yeah they are a pain the arse the best thing you can do is loossin the one side then you can get the stubborn side to line get your bolts started then you can tighten every thing up. I know it took my 6 hours to figure this out
67 C/20 camper special 350
melloyello is offline   Reply With Quote
Old 07-06-2003, 06:42 PM   #5
seacrow
seacrow's Avatar
Unbolt the towers, bolt the mounts to the engine and towers to the mounts and then towers to the frame. You will need a cherry picer but this is much much easier, except fo the PS bracket if you have PS.
71 GMC Custom. 350, 4bbl., auto. Restored in memory of my grandfather.
2008 Ford F-250 Super Duty CC King Ranch, moonroof, heated captains chairs, 6.4 PowerStroke.
2007 Suzuki Hayabusa, all black
1985 Mustang GT T-top, 5 spd. 54K orig miles.
seacrow is offline   Reply With Quote
Old 07-06-2003, 07:42 PM   #6
67cst
i love summertime
67cst's Avatar
yeah me and my dad had fun with mine also, it was a ***** but we did get it, lots of prying and swearing...and a bit of blood but shes in there nice and tight now
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 07-06-2003, 08:15 PM   #7
crazy longhorn
Fabricate till you "puke"
that style mount has agravated this crazy old man too many times! The last 3 trucks that got eng swaps, got the holes in the stands drilled to 5/8" .........the bolts fit now crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 07-06-2003, 11:16 PM   #8
Terry S
Okay, attaching the passenger side tower to the motor mount first, then to the frame worked. I still ended up having to do quite a bit of heaving on the tower to get it to line up, but that's definately the way to go.
Thanks for the advice!
TS
Old 07-07-2003, 01:18 AM   #9
Low69CST
We had the same trouble putting in my 400. We loosened one tower up from the frame and were able to squeeze it in.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
