Old 02-13-2011, 01:13 AM   #1
krue
Designated A-hole!
krue's Avatar
How much scratch?
Am I gonna spend to drop an ls in my 70 truck?
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 02-13-2011, 11:52 AM   #2
Hart_Rod
Hart_Rod's Avatar
Re: How much scratch?
$3K -$6K depending on parts selection.
Hart_Rod is offline   Reply With Quote
Old 02-13-2011, 01:20 PM   #3
krue
Designated A-hole!
krue's Avatar
5.3l, 4l60e, not looking for a hot rod, just a daily driver.
www.daveramsey.com
Old 02-13-2011, 02:41 PM   #4
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
With out running down all the receipts, I am close to 35-3800, And it still doesn't quite run. Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 02-13-2011, 03:22 PM   #5
Clyde65
Clyde65's Avatar
If you are going 5.3/4l60e around here, motor/trans alone will be 1800.00. then probably about 500.00 for misc stuff.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-13-2011, 07:29 PM   #6
harnalien
TruckincrazY
harnalien's Avatar
Depending on how much you can do yourself, and what you start off with, you are looking at anywhere between 1500 and 5000. I am at about 4500 for everything and still do not have all I need. It's the little stuff that adds up quick. I have to stop sometimes and ask myself it it's really worth it. Hopefully I'll have the answer in a couple of months.
My build thread - '84 2wd w/ a 6.0 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=433595
harnalien is offline   Reply With Quote
Old 02-14-2011, 01:10 AM   #7
Notch1988
Notch1988's Avatar
It can vary a lot. Your biggest one time expense will be the motor/tranny itself. And then the money choices come into play...
mounts - fabbed at home or bought from various suppliers
exhaust - manifolds or buy some new long tube headers
wiring - modify your own for free (assuming your motor came with it) or buy a new harness/pay to have yours modified
fuel - use existing tank with an external pump or get a new tank with intank pump
gauges - new electronic gauges or adapters for your old ones (mainly speedo here)
cooling - radiators, tranny coolers, oil coolers, power steering coolers... what do you want to run?
maf or speed density and the programming to go with it... either way the PCM needs to be programmed to remove VATS, rear O2's if deleted, EGR if deleted, etc. Maybe you want to do it yourself with EFIlive or HPTuners... more expenses.
Best bet is do some research, make a list and pick away at it.
Notch1988 is offline   Reply With Quote
Old 02-20-2011, 05:49 PM   #8
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Here's roughly what mine cost so far:
$150 Dirty Dingo mounts
$1000 (need to get yet) exhaust
$600 - new long tube headers
$450 wiring & PCM programming
$150 TAC & pedal
$500 fuel - new tanks & pumps & lines
$800 gauges - Autometer electronic gauges
$1000 cooling - radiators, tranny coolers, oil coolers
Need to get yet - maf or speed density and the programming to go with it
$2500 for cam and motor / block work
$2800 for motor and tranny
$1000 in other misc parts for A/C, fuel lines, etc etc
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 02-22-2011, 11:33 AM   #9
1tonjimmy
1tonjimmy's Avatar
My swap ran about 5400.00
1tonjimmy is offline   Reply With Quote
