Old 02-15-2011, 01:47 PM   #1
wldcat10
wldcat10's Avatar
Truck starts to shake when going 25-30mph???
Ok I have a 2 problems. (#1) I was driving my '70 lwb c/10 on saturday and it started to shake when I was going about 25-30mph. I pulled over and couldn't really figure it out what was wrong? So I got back in and did the same thing again around 25-30mph, if I speed up it kind of lets off and if I slow down the shaking slowly starts to fade out. Not sure what it could be? Could it be that my shocks need replacing? (#2) Noticed that a had a small spot on the concrete where something was leaking under my truck. It was a very small leak from the speedometer cable was. So I tightened it and it stopped. Now my speedometer needle jumps back and forth between 30-50mph on the gauge. What can I do/adjust so that it doesnt leak and I dont have the speedometer needle jumping all over the place. Any help is appreciated, thanks!!!
1970 CST/10 LWB 350
1984 Blazer
wldcat10 is offline   Reply With Quote
Old 02-15-2011, 01:58 PM   #2
dcasalena
dcasalena's Avatar
Re: Truck starts to shake when going 25-30mph???
hopefully the shake is something as simple as a wheel out of balance. Maybe threw one of your balance weights?
dcasalena is offline   Reply With Quote
Old 02-15-2011, 02:20 PM   #3
wldcat10
wldcat10's Avatar
I am going to be getting an alignment and new tires hopefully this friday. Could it be shaking like that because it needs an alignment?
1970 CST/10 LWB 350
1984 Blazer
Old 02-15-2011, 02:22 PM   #4
bajaracing
bajaracing's Avatar
if not the wheels, check the driveshaft support (usually it's a vibrating shake) just an idea..
bajaracing is offline   Reply With Quote
Old 02-15-2011, 02:26 PM   #5
Lee H
Lee H's Avatar
Shaking could be caused by several things including wheel balance, tire defects, worn out suspension components, mis-adjusted wheel bearings, etc, or any combo of. Tell the alignment shop about the shaking. They will do an inspection and advise of problems.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is online now   Reply With Quote
Old 02-15-2011, 02:30 PM   #6
JOHNORO
oldschoolblazer@yahoo.com
JOHNORO's Avatar
I agree that you might have lost a wheel weight.
You might also check your tires to see if any of them have separated
just run your hand along the top of the tire to see if you feel a Lump.
JOHNORO is offline   Reply With Quote
Old 02-15-2011, 02:36 PM   #7
wldcat10
wldcat10's Avatar
When a buy new tires and get the alignment, do they check/replace wheel weights if needed?
1970 CST/10 LWB 350
1984 Blazer
Old 02-15-2011, 02:50 PM   #8
JOHNORO
JOHNORO's Avatar
Most shops that mount your tires will also balance them.
(but there usually is an additional fee)
Old 02-15-2011, 02:59 PM   #9
C low
C low's Avatar
my 67 would shake at 30 to 40 having a few trucks with a two piece drivelines i knew it was the carrier berring the berings are usally good but the rubber that supports them rots good luck hope this helps
C low is offline   Reply With Quote
Old 02-15-2011, 03:00 PM   #10
justtime520
justtime520's Avatar
Hey bro it sounds like your driveshaft. I would pick up some new u joints. I got mine from oriellys on grant and silverbell. They always have them in stock. Put them in and made sure the drive shaft was sitting right on the carrier bearing. After doing that, no more shake.
justtime520 is offline   Reply With Quote
Old 02-15-2011, 03:03 PM   #11
wldcat10
wldcat10's Avatar
I'm gonna go see if its the wheel weight that's missing first by taking it in to get them balanced after I get my new tires. I hope that's all it is!
1970 CST/10 LWB 350
1984 Blazer
Old 02-15-2011, 03:08 PM   #12
justtime520
Hey bro also check out your hole front end and look at all the boots. wait is it shaking from the front or rear.
Old 02-15-2011, 03:12 PM   #13
wldcat10
wldcat10's Avatar
Feels like its shaking from the front passenger side.
1970 CST/10 LWB 350
1984 Blazer
Old 02-15-2011, 03:16 PM   #14
justtime520
I wonder if it is a bearing.
Old 02-15-2011, 03:38 PM   #15
dcasalena
dcasalena's Avatar
All these suggestions are good, but I'd think they would cause a constant vibration. Except my original thought, wheel balance, which tends to only happen at certain speeds. What that speed is can vary, but is worse at some certain "resonant" rotation velocity of the misbalanced wheel.
Most tire shops mount and balance new tires for "free", which means they already included it in the cost of the tire(s). Alignment usually cost some bucks though.
Good luck1
Old 02-15-2011, 03:48 PM   #16
wldcat10
wldcat10's Avatar
Yeah might be that the tires need to be balanced. Since I'm getting new tires this week I'll be getting them balanced too, hopefully thats what it takes. I also need an alignment so that will be another thing to cross off the checklist, thanks to everyone who replied!
1970 CST/10 LWB 350
1984 Blazer
Old 02-15-2011, 03:55 PM   #17
vexvader
1967 C10 SWB
vexvader's Avatar
Yep! I have a 70 LWB and that exact thing happened to me. I would bet that it on of these tow things. Wheel out of balance or drive shaft bearing.
Let us know when you track it down.
Vex
vexvader is offline   Reply With Quote
Old 02-15-2011, 04:11 PM   #18
leddzepp
Moderator
leddzepp's Avatar
check your u-joints. i had the same exact problem at 25-30 mph. and 2 u-joints were worn.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 02-15-2011, 04:14 PM   #19
CC69Rat
CC69Rat's Avatar
Is this a shake you're feeling in the steering wheel? or more in the seat, like it's coming from underneath the truck?
Is it like a humming vibration, or a physical shake (the steering wheel moves when it shakes) . ? coming from the RH Front, I'm leaning away from the drive shaft, just my .02.
Have you hit any big pot holes on that side recently? Does it make a clunking sound when you turn to the left at 20-30 mph.. going up / down a freeway ramp or somehting?
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 02-15-2011, 04:15 PM   #20
cdowns
cdowns's Avatar
i'd check to see if the lugnuts are tight
Old 02-15-2011, 04:34 PM   #21
wldcat10
wldcat10's Avatar
The shake is more in the seat like it coming from under the truck. no humming sound that I've noticed? steering wheel is normal from what I've noticed (no power steering). I have not hit any holes or anything like that. and no clunking sound when turning.
1970 CST/10 LWB 350
1984 Blazer
Old 02-15-2011, 04:56 PM   #22
BIGBLU 72
BIGBLU 72's Avatar
My vote goes U joints! my Jimmy did this till i swapped them out! shook sooo hard that it would move my rear view mirror, then i speed up or slow down and it goes away
68 C10 LWB 2/4 drop 406/th400/3.73posi
04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD
BIGBLU 72 is offline   Reply With Quote
Old 02-15-2011, 05:26 PM   #23
CC69Rat
CC69Rat's Avatar
I thought you mentioned Front Pass side ? Yes, if it's coming from under the seat, definately in the drive shaft, U-Joints, Carrier Bearing, or Pinion angle. Is the truck lowered?
Chad
Old 02-15-2011, 05:28 PM   #24
brad_man_72
the boat guy
brad_man_72's Avatar
if it ends up being your drivesaft. Take both pieces of your driveshaft to a shop that works with drivelines. They will have the equipment and theknowlede to fix your driveshaft right, and they will be able to ballance the shaft as an assembly.
I've seen many people who call themselves mechanics mess up a driveline job because they don't have a clue how it works. It's not just a metal stick between the trans and rear end.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 02-15-2011, 05:29 PM   #25
wldcat10
wldcat10's Avatar
Yes I did say it felt like it was coming from the front passenger side. I just said I feel the shaking more in the seat than I do the steering wheel like you had asked. The truck is not lowered its all stock.
1970 CST/10 LWB 350
1984 Blazer
