02-15-2011, 09:23 PM | #26 | |
VA72C10
Re: Project Budget Build
Also, whatever you decide...there has been a $20 off anything over 100 coupon posted on the site...think it ends soon but it's worth looking into...
Looking for a 67-72 swb or blazer project in or around VA. |
02-15-2011, 10:01 PM | #27 |
70Custom10
Well Today was amazing! It was 70 degrees here and I got all kinds of stuff done! I got to wear shorts for the first time in 4 months, I got the bike started and went for a ride after not even maintaining the battery since october. I got my rear brake line plugged up so I can at least move it until I get all of the rear lines replaced. I went to the Hot Rod Institute and talked to the guy whos building my motor. I test fit my headers on his truck (66' lwb) He agreed that to use these headers I would have to notch my frame. Not ideal but it works for now. Then I hopped back on the bike rode home and notched my frame a little bit. Before and after pics below. Then I actually got to drive my baby for the first time in a few months! Let me know what you think of the new headers.
02-15-2011, 10:17 PM | #28 |
Formerly- 1972SuperCheyenne
Headers look like they fit great. I wouldnt worry about that little notch at all. Looks good!
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
02-15-2011, 10:30 PM | #29 |
70Custom10
Sorry those are the old ones. The collector and about 2 inches of pipe were all blown out beyond repair. They fit perfect but I dont know what make they are and I cant find them. Heres a pic of the old and new together.
02-15-2011, 10:32 PM | #30 |
70Custom10
Heres the new ones installed.
02-16-2011, 01:19 AM | #31 | |
02-18-2011, 03:56 PM | #32 |
70Custom10
Well I picked up my cam today. After spending some time at "The Speed Center" (our local hot rod shop) I settled on an EPR mc1713. The guy tells me this should make the truck sound real nice and getbup and scoot just fine. Well see. Anybody currently using that cam?
.050 duration intake 223 Exhaust 223 VALVE LIFT Intake 447 exhaust 447 Ill recap what I have for the motor now too. Its a 79' 4 bolt main truck motor, with stock heads fresh valve job, hardened valve seats and new exhaust valves. Block is bored. 040 over. I have an edelbrock performer rpm aluminum intake and im planning to run an edelbrock 1406 carb. Flat top (eyebrowed?) Pistons. Also Have HEI and Im going to be doing an MSD 6A Box Is there a way to calculate horsepower without using a dyno based on the specs I've given? Finally, now that I have a new cam should I change the springs? They're all very tight. Thanks in advance everyone!! Posted via Mobile Device Posted via Mobile Device Last edited by blazerboy_4life; 02-28-2011 at 01:42 AM. Reason: added stuffs |
02-28-2011, 01:42 AM | #33 |
70Custom10
So I ordered the carb (Edelbrock 1806) and water pump today. Hopefully Ill pick up the motor from the machine shop tomorrow. Just need to pick up push rod bearings and plugs and wires and It should be fired up by the end of the week!! According to "Desktop Dyno" I should be pushing 300hp and 400 ft lbs of torque. No idea how accurate that is but it sounds good.
03-01-2011, 12:04 AM | #34 |
70Custom10
Well I just talked to the machine shop a little bit ago and they said I can pick up the motor tomorrow morning! I also came across a coupon in the back of a maxim magazine while at work the other day for a welder from Harbor freight for $89! its a 90amp 110v wire feed Chicago Electric. Also Also came across a 27gal 5hp air compressor on craigslist for $90 so In a few weeks (weather permitting since I have no garage) Looks like I should be well on my way to making some good solid progress! Ill post pics of the motor as it comes along.
03-01-2011, 01:43 AM | #35 |
cam's mighty small
03-01-2011, 02:14 AM | #36 |
70Custom10
03-02-2011, 03:13 AM | #37 |
70Custom10
Well I picked up the motor from the machine shop today. Didnt realize it but the heads didnt have the rockers on them any more and one of my pistons looked exactly the same but was different than the rest. That is I had 7 cast flat top pistons and one aluminum... Ill be heading back to the shop to pick up the correct parts tomorrow morning.
03-03-2011, 02:11 PM | #38 |
70Custom10
So I picked up new pistons yesterday. http://www.jegs.com/i/Sealed+Power/844/H617CP/10002/-1
I have 78cc heads so it should run pretty nice. The guy at the machine shop estimates that i should be sitting right around 380hp and just north of 400ft lbs of torque with my setup. I now have all the parts I need and The hot rod institute will be building my motor starting this afternoon. In fact Im leaving now to go drop off my new water pump, new HEI distributor, and aluminum alternator bracket. Pics coming soon! |
03-04-2011, 02:13 AM | #39 |
70Custom10
Carb Came in today. Edelbrock 1806 electric choke. The motor is half assembled as of this evening. Ive got to pick up a few random bolts im short on and maybe I can get this thing done by tomorrow night... Well see.
03-05-2011, 01:27 AM | #40 |
70Custom10
Well Im missing some head bolts so the build is on hold until monday when I can go pick up the new head bolt kit. Until then heres a look at what shes starting to look like. Its gonna be chevy red/orange and all aluminum.
03-06-2011, 11:02 PM | #41 |
70Custom10
This is off topic a bit but today I came across a 69' Belair with a 327, 3 on the tree, and factory air and and I couldnt say no... Of course at a price of
$340 who COULD say no! Theres no dents to speak of almost zero rust and all of the chrome seems perfect! Ill be trailering it home in a couple days. I have no idea what I plan to do with it. I may flip it so I have more cash to put into my shortbox but for the price I couldnt let it get crushed. Thats what he was going to do with the car if he didnt sell it by today. Pics coming soon. |
03-11-2011, 02:02 PM | #42 |
70Custom10
03-11-2011, 02:36 PM | #43 |
70Custom10
Just scored some rally wheels too off craigslist. Cant wait till tomorrow!!
03-11-2011, 03:05 PM | #44 |
PROJECT 7DEUCE
Was that the 1st fire up? If so did you guys break in the cam?
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
03-11-2011, 03:25 PM | #45 |
Just caught this build, nice buy for the price.
Kerry My build thread. http://67-72chevytrucks.com/vboard/s....php?p=3657823 1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears 1988 Chev Extendacab 2010 Honda VT1300CS Sabre 2005 Buick Rendezvous wife's ride |
03-12-2011, 01:24 AM | #46 |
70Custom10
No that was the second time. We dont have a way to run it on the engine stand inside for as long as it takes to break in the cam so we started it a couple times for 30 seconds each and I will break it in tomorrow morning when its in the truck. I was told to run the motor for 20min at 2000rpm. Sound right?
03-12-2011, 04:42 AM | #47 |
PROJECT 7DEUCE
Sounds right to me..
03-12-2011, 05:31 AM | #48 |
Been reading your thread, awesome deal on the trucks! Good to see you making progress. I have that same welder you were talking about from harbor freight. works good, but i've not used it for anything but tacking in panels and exhaust, don't think they're made to do heavy stuff like a frame.
I feel you on the working outside, i'm a shade tree mechanic myself! Post us some pics of the completed engine in the truck when you get it in!
Raymond 1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper. My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594 The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939 Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402 |
03-13-2011, 02:30 AM | #49 | |
70Custom10
03-13-2011, 03:28 AM | #50 |
Let me see what you're capable of with it, you're welding skills may be better than mine! I've started my build thread, you'll have to check it out sometime!
Tags |
70', build thread, custom, first time |
