Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 10-19-2010, 09:10 PM   #51
drewskiren
Lucky Teter at the wheel
drewskiren's Avatar
Re: Project Family Hauler
Awesome work, Can I have that section of your burb????
Drew
YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!)
The Bride is currently under the knife!
drewskiren is offline   Reply With Quote
Old 10-20-2010, 03:17 PM   #52
68 TT
Still plays with trucks
68 TT's Avatar
Great work so far. Keep it up.
Can't wait to see it on the road.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 10-21-2010, 05:29 PM   #53
pickup67man
pickup67man's Avatar
I can't wait either. My daughter is 2 1/2 years old. I hope I still need the family hauler when it is finished. Progress is slow. After the door is done it should start moving faster.
Travis
2005 K2500 Duramax (hauls the junk home)
1967 Chev C10 (hauls a$$)
1970 Suburban (Yukon XL 4 door)
1968 GMC 3/4 ton (sheetmetal only, chassis gone)
2005 Malibu (wife's car, still a Chevy)
New Home for Chevys (Moved in and working)
pickup67man is offline   Reply With Quote
Old 10-21-2010, 06:11 PM   #54
68 TT
68 TT's Avatar
Tell me about it. My daughters keep me so busy I get next to nothing done on the cars or house.
Before them I could build a nice car from a pile of old parts in 3 months. Now I will be lucky if it only takes 3 years. They are worth it though.
Old 10-24-2010, 10:53 PM   #55
pickup67man
I seem to work slow. Worked on it all day and it doesn't look like I did much again. Instead of modifying another latch area of the door jamb I just made one. I copied the passenger front door latch area. Installed it on the rear of the drivers side B pillar. The fourth door latches.
B pillar is not done but it is getting boxed in piece by piece.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Travis
Old 02-16-2011, 12:07 AM   #56
pickup67man
Want to say there is progress but there is not.
Plans for new garage this year will help future progress.
Need more room because here in Washington we have 364 days of rain per year and welding in the rain isn't good. 220 volts and water don't mix.
Travis
Old 02-16-2011, 12:09 AM   #57
67chevy1series
67chevy1series's Avatar
well when you MAKE PROGRESS DONT FORGET ABOUT US!
67chevy1series is offline   Reply With Quote
Old 02-16-2011, 03:15 AM   #58
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
That's great to hear you will be getting an area to work in! I know your pain, I do my share of working outside in the elements each day.
Ryan
1969 Chevy milk truck
Old 02-16-2011, 04:10 AM   #59
swamp rat
swamp rat's Avatar
Thats some great news! Um, not the 220 and water part..
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 06-22-2011, 07:13 PM   #60
jbclassix
Junk Yartist
jbclassix's Avatar
Any progress? I need some do's and don'ts for my door!!!!!!
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 06-22-2011, 08:44 PM   #61
jbclassix
Junk Yartist
jbclassix's Avatar
Seriously though, I have gone through your, frizzle fry, and rokcrln builds many many times! For your window frames did you use more than 2 doors? I would like to avoid cutting up my extra left door.
-Jeremy
Rebuilding an NP205
Old 06-23-2011, 06:04 PM   #62
pickup67man
Don't try to weld under an awning on a rainy day in Washington. (The rain lasts for 10.5 months)
Do be patient. I am fixing problem this summer with a new garage. Permits are in order for new garage and work should start by August. Still need to tear old garage down first. Then I can work inside.
Seriously, what I did on my window frame was aquire 2 rusted out suburban front doors for free and use the square window frames to build the one I needed. I did a mirror image of the right rear door. My window frame isn't permanent yet since the door isn't finished.
I used one drivers door to start, one passenger door so the body line will line up and two old rusty (and I mean rusty) suburban doors for the frames only. Combine this with the inner panel from the suburban and the hinges from a F*$d and I have a door that opens suicide, the window rolls up & down and it latches on the B pillar with the original truck hardware.
Still have a long way to go to make it look good.
Have fun
Travis
Old 06-23-2011, 06:30 PM   #63
pickup67man
Proof that I am being productive.
Hole in yard from buried treasure
The treasure that I found
These are the puddles from the nonstop rain. Didn't go away until May
Even when the puddle was gone the ground was mush. This is from the bobcat.
New position of the garage
This was the fun I had. 6 trips for a total of 45000 lbs of 1 1/4" minus to firm up the ground.
Travis
Old 06-23-2011, 10:39 PM   #64
jbclassix
Junk Yartist
jbclassix's Avatar
MMMMM, bet that dump trailer wasn't even there behind that D-max! Thanks for the info on the doors. I'm wondering how far I can get with the two pick-up doors... Good luck on the garage!
-Jeremy
Rebuilding an NP205
Old 06-24-2011, 12:09 PM   #65
68 TT
68 TT's Avatar
...These are the puddles from the nonstop rain. Didn't go away until May
Glad you are making progress on the shop.
It still hasn't really stopped raining for more than a few days. By last weekend we already have 30% more rain than we typically get in a whole month.
Old 06-24-2011, 04:02 PM   #66
pickup67man
And you are on the drier side of the hills.
Drove the other truck on a poker run and to a show last week. I'm rethinking the heater/defroster delete I did. Also the drag radials out back. Paper towels for a defogger sucks and hydroplaning with the family isn't fun. The suburban will be all weather friendly so I can drive it more than 2 days a year.
Travis
Old 06-24-2011, 04:06 PM   #67
pickup67man
It slowed me down a little but thats what happens with an extra 12,000 lbs. On one trip the gravel alone was 9300 lbs!!!
That worries my wife because I can haul lots of other junk home with ease. Just look at the back yard, toys everywhere.
Travis
Old 06-26-2011, 11:16 AM   #68
68 TT
68 TT's Avatar
...Drove the other truck on a poker run and to a show last week. I'm rethinking the heater/defroster delete I did. Also the drag radials out back. Paper towels for a defogger sucks and hydroplaning with the family isn't fun. The suburban will be all weather friendly so I can drive it more than 2 days a year.
I know what you mean. Wait until the drag radials wear down a little more then try to drive it in bad weather. They wear down really fast on the street.
Old 06-26-2011, 04:24 PM   #69
pickup67man
How pathetic am I? The drag radials have been on the truck for 10 years and I raced it once in 2001. The rest of the time has been on the street and they still aren't worn out. I need to drive it more so they will wear out, then I can get new tires and the Coys I want. Wife can't argue about the purchase if it is needed.
Travis
Old 06-28-2011, 03:13 PM   #70
68 TT
68 TT's Avatar
Wow, you really know how to baby a set of tires Mine wore out to zero tread depth in two months on the street.
They work better at zero tread depth until you hit the non-tread compound layer but are not street legal or safe if the roads are even damp let alone wet.
Go have some fun and wear those tires out so you can get the Coys.
Old 06-28-2011, 09:31 PM   #71
rondog4416
rondog4416's Avatar
hey pickup67man are you just off Steward in Puyallup?i'm over off 162 and 410, hope to meet ya sometime
rondog4416 is offline   Reply With Quote
Old 06-28-2011, 10:33 PM   #72
pickup67man
Yes, downtown Puyallup. Apparently I went by your house a week ago on my was back from the Kingsmen run in Orting. I hope to drive it more this year.
Travis
Old 06-29-2011, 12:31 AM   #73
swamp rat
swamp rat's Avatar
Where did you find out about the run? find a flyer? There was a lot of classic cars on the road saturday. Thanks!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 06-29-2011, 09:09 PM   #74
pickup67man
Don't remember where I found out about it. Have been doing that run for 10 years. Missed 2008 only because my daughter was 2 months old and I still had bucket seats in truck. It is Saturday on Fathers Day weekend, poker run starts in Tacoma and was 50 miles long. My speedo is way off so that is a guess.
Travis
Old 06-29-2011, 09:17 PM   #75
pickup67man
Hey swamprat I must have been near your house when I found my gas guage was also having issues. Was at Sprinker at a poker run stop and my engine sputtered. Almost died on Pac Ave. My fuel pressure started jumping and I stopped at the Gas Boy around 166th.
Travis
