02-16-2011, 03:16 PM | #1 |
2in drop or 4/6 inch drop??? i got a question!!
i have a 68 gmc swb 2wd, that im restoring and i want it to sit low and pretty level for the most part. but i dont want it so low that it will drag on speed bumbs etc, because when it gets on the road its going to be a daily driver. so how should i lower it??, 2in drop or?
02-16-2011, 04:09 PM | #2 |
Re: 2in drop or 4/6 inch drop??? i got a question!!
Check out our no limit 72 build. I did a 4/6, spindle and springs in front, and springs, blocks, and an adjustable panhard rod in the back. It sits pretty level, and I have no problems bottoming out.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! |
02-16-2011, 04:28 PM | #3 |
02-16-2011, 04:30 PM | #4 |
hey heres my truck 2 1/2" & 4 " sits level and rides like a caddy
02-16-2011, 04:55 PM | #5 |
Happy to be here
Are you going to convert to discs? I suggest convert and run drop spindles. Much safer and will not change your ride.
Posted via Mobile Device |
02-16-2011, 05:20 PM | #6 |
probably 3/5 is what you want..all you need is the lowering coils/shocks and your done beside an alignment. Sits just right. any lower for front your gonna have to convert to disc brakes/you could get drop spindles..for rear any lower than 5" you will need shock relocaters/adjust panhard bar. But if money aint an issue..what I heard best handling results would be go with the disc brake conversion and get those lowering spindles like 2" and get the 2" drop springs/and you could go 6" drop coils rear with the mention above i wrote. and you will be fine. Well bump stops may still hit alil just go real slow...thats all.Or you could just say bye to the coisl and get bags and you can dump it and raise it and be happy. haha
02-16-2011, 07:01 PM | #7 |
Nice Stance Fldawg,
Is this 2.5 drop spindles and 4" drop coils or drop coils on both. Where did you buy from. |
02-16-2011, 07:21 PM | #8 |
it's drop spindles and rear coils , there from Mcgaughy's and i purchased the from supension online he's a guy that deals on ebay really nice guy and good price
02-16-2011, 08:43 PM | #9 |
ya im thinking drop spindles and lowering springs or somthing for now, il bag it later when i get cash =]
02-16-2011, 09:49 PM | #10 |
02-16-2011, 09:59 PM | #11 |
Tot Roddin'
Click on Project Blank Slate in my signature for the complete install and review of a 4.5/6" drop kit on my '69.
The 4.5/6" has a slight rake but the ride is amazing. If you are planning on using your truck to haul things I would recommend not going lower than a 5" rear drop, unless you are going to c-notch the frame with a bolt-in notch.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 02-16-2011 at 10:00 PM. |
02-17-2011, 04:32 PM | #12 |
