Old 02-16-2011, 08:07 PM   #1
jcloud6
I Need help with rear end knocking noise
I searched the post but could not find any help with my truck rear end problem. The rear end started this loud thumping/knocking type noise. I put on jack stands, started the engine and put it in drive. With the rear wheel spinning I was able to pin point the location of the noise. Its the 1981 C10 orginal factory non-posi rear end. The oil level is good, however I did notice the rear pinon yoke had a small wobble while the rear wheels spinning. Is it possible the front and rear pinon bearing is worned out and the wobble is causing the noise?
Any assistance will be helpful
jcloud6 is offline   Reply With Quote
Old 02-16-2011, 08:21 PM   #2
LONGHAIR
Re: I Need help with rear end knocking noise
If you have a noticable pinion wobble, there is a bigger problem lurking. If the pinion is loose enough to move at the yoke end, it has definately damaged the ring gear's teeth too. There is a very precise alignment required with these parts and any "movement" causes improper wear. It will be noisy and the normal rate of wear is greatly accelerated.
Over-all not an easy fix. Simply replacing the bearings (assuming that this is the original problem) will not cure it.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 02-16-2011, 08:27 PM   #3
spudz
spudz's Avatar
your pinion nut prolly backed off and chipped some teeth off the ring gear. if you grab the pinion flange can you move it at all? Like its loose? Either way, pull the cover and look inside.. 3 quarts of 80-90 gear oil and a gasket is cheap enough.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 02-16-2011, 09:14 PM   #4
jcloud6
Spudz and Long Hair
Thanks for your prompt reply and valuable information, Base on your feedback and my limited mechanical knowledge Its probably a good idea for me to replace the Rear end. My Local cash of clunker salvage yard currently have a desent selection of C10 pickups. Since I am going to replace the entire unit I may as well look for one with posi-traction because most parts their are sold at a very reasonable price.
Thanks again
Old 02-16-2011, 09:20 PM   #5
spudz
spudz's Avatar
before you do that.... make sure that you dont just have a bad u-joint. if it was a rear ujoint it may look like its the pinion joke moving.
Old 02-17-2011, 08:41 AM   #6
James McClure
One shot, one kill.
Hay guys, just my 2 cents and a quick thought. IF the pinion is loose enough for you to see it wobble the the pinion seal should be leaking like crazy. I think Spudz is probably right. "U" joints fail a lot more often than rear ends do. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 02-22-2011, 01:10 PM   #7
Goldfinger
Goldfinger's Avatar
I've had a knocking sound i thought came from the rearend it was an exhaust leak. hope this will help.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
