Old 02-17-2011, 07:12 PM   #1
Italia
Italia's Avatar
Posi Rear End????
first of all.... my truck spins both tires when i do a burnout. i have been reading that a way to tell if your rear end has posi is to jack up the rear and spin a wheel. if the opposite wheel spins the same way.... then its a posi rear end. if the opposite wheel spins the opposite direction then it is NOT posi traction. so out of curiosity i jacked up the rear and spun the wheel.... the opposite wheel spun the opposite way.... so that would indicate NO posi right??? but both wheels spin while burning out and clearly leaves two tire marks and gets a little sideways.... i am confused now.
also what was the stock rear end on a 62' Chevy??? mine has 10 bolts and i dont know what gears.... thanks guys!
62' Chevy C10 Shortbed, 350, 700r4
FRANKIE
Italia is offline   Reply With Quote
Old 02-17-2011, 08:53 PM   #2
kirtzen
kirtzen's Avatar
Re: Posi Rear End????
Posi, if the opposite rear wheel spins in the same direction. A open diff. will have the opposite tire spin in the other direction and a limited slip will some times leave the other wheel standing still and slowly start turning in the same direction.
kirtzen is offline   Reply With Quote
Old 02-18-2011, 04:04 AM   #3
Heater63
Heater63's Avatar
How long have you had the truck?
Is this a new condition, or has it always spun both tires? If its always spun both tires, you have a posi, don't worry.
If it's a new thing, just started leaving "scratch" with both tires, you can have an open diff that is failing and about to go boom.
If it's a new truck to you, you probably need to change the gear oil anyway, so pop the diff cover and have a look.
292 + TKO500
Heater63 is offline   Reply With Quote
Old 02-18-2011, 09:36 AM   #4
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: Posi Rear End????
Jack up the rear end. Out of park or gear. Turn a rear wheel. If they turn in the same direction its posi. If they turn in the oppisite direction its non posi.
1960-1966 Chevy/GMC Pickup Truck Specs & Engine/Trans/Axle ID's
http://67-72chevytrucks.com/vboard/s...d.php?t=327764
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 02-19-2011, 01:04 AM   #5
Captainfab
60-66 Nut
I've had open diffs spin both tires before. I don't know how to explain it, but it can happen.
The rear end in your truck is a GM55T which was used from 1955 thru 1962. The most common gears in those rear ends is 3.90's
Old 02-19-2011, 04:39 PM   #6
Italia
Italia's Avatar
Thanks captainfab and pro street... Great info...
FRANKIE
Old 02-20-2012, 04:27 AM   #7
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I'm pretty sure that's what I have in my 65 on a 62 frame with torsion bars.
It will leave two tracks when I stomp it.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 02-20-2012, 09:22 AM   #8
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
kinda had this same issue with my 65... in the winter it acts like a posi... both spin, and it starts corkscrewing around like a posi will do... jacked it up turn one tire, the other turns the other way... jacked it up the other day with one tire still on the ground, and out of gear, and the rear is locked like a posi.... ???? gotta scratch around on the diff and find the code, unfortunatley there was no build sheet..
Old 02-20-2012, 11:06 AM   #9
bob-n
an old dirt track trick "back in the day" was to open up the bore on the spiders to allow them to twist under heavy load, thereby locking up like a posi. That could be what is happening to yours.. it way have worn in and now binds just enough to lock it up properly.
bob-n is offline   Reply With Quote
