02-17-2011, 07:47 PM | #1 |
71' Custom 10 (ole blue)
Is there anyway to level my truck
I was wondering if anyone made a level kit for our trucks, i wanna lower the rear alittle on my 69
71' Custom 10 (ole blue) GM Goodwrench 350 Turbo 350 Transmission |
02-17-2011, 07:53 PM | #2 |
Redefining LowBudget
Re: Is there anyway to level my truck
new u bolts and spacer blocks will do the trick
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
02-17-2011, 07:55 PM | #3 |
where can i get spacer blocks?
02-17-2011, 08:58 PM | #4 |
454 MAKES IT ROAR
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger Last edited by eightbanger; 02-17-2011 at 08:59 PM. |
02-17-2011, 09:03 PM | #5 |
I just saw them in speedway too depending on how high they where from like $11 to 18
cheap!!
02-17-2011, 09:33 PM | #6 |
What impact do lowering blocks have on cargo capacity?
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
02-18-2011, 01:06 PM | #7 |
I was thinking of lowering the rear of my 1970 too, how much of a drop do I need for it to be level with my front end, 3 in? My truck is all stock right now, just want to be the rear to be level with front.
1970 CST/10 LWB 350 1984 Blazer |
02-18-2011, 01:21 PM | #8 |
Its Topless Season!!!!
LMC illustrates that stock height 2wd trucks are 32in in the front and 34in in the rear when measured from the top of the wheel arc to level ground....so to answer your Q...you would need to drop the rear 2in to be level at 32in all around.
02-18-2011, 01:41 PM | #9 |
Thanks for the help! Are these lowering kits easy to install? Or would I be better off just taking it somewhere to get done. I like price of the lowering kit, so it would be nice if I could do it myself.
02-18-2011, 02:38 PM | #10 |
the boat guy
be sure to get lowering blocks for a 67-72 chevy truck if you have a trailing arm setup. The generic lowering blocks won't "fit" with trailing arms. It's a pretty simple project ut sometimes those ubolts don't want to come loose and may require cutting.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
02-18-2011, 02:43 PM | #11 | |
<edit> Are the axle tubes the same size on the C20? I'll see if I can grab a measure at lunch off another truck at lunch, but figures I'd ask. <edit2> Thanks Brad, I figured they might not work on trailing arms, but I'll check to make sure.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 Last edited by jimmydean; 02-18-2011 at 02:51 PM. |
02-18-2011, 04:21 PM | #12 |
67-72 parts collector,…
02-18-2011, 04:54 PM | #13 |
454 MAKES IT ROAR
Sorry about that JD, my bad, I should have checked the link before I posted it....
Not meaning to Hijack...Lolife, do you need to buy all that stuff Cast Shims, Pinion Shims? and what are they for?
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
02-18-2011, 05:11 PM | #14 |
The pinion shims are for "dialing-in" the pinion angle.
With a stock spring,... I would say no. Every truck is different.
