Old 02-17-2011, 10:02 PM   #1
FL71C10
Can I run motor with no driveshaft installed?
I'm working on getting the motor on my truck running. Can I run it without a driveshaft without trans fluid leaking all over the floor?
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 02-17-2011, 10:25 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Can I run motor with no driveshaft installed?
Yes.
You might jack the rear of the truck up a bit so no fluid comes out of the back of the trans though. Sometimes if the fluid level is high enough, some will drizzle out. If you put the back of the truck about a foot higher than the front you'll be covered either way.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 02-17-2011, 10:50 PM   #3
67chevy1series
67chevy1series's Avatar
this is good to know mem and my dad plan on starting my truck but not driving it and i dont have a driveline so it will be started without a drive shaft...
67chevy1series is offline   Reply With Quote
Old 02-18-2011, 12:05 AM   #4
68anniversary
I have a plastic plug I put in the rear of mine. I've never ran it with it in though. I use an old yoke as I have several. They may still sell the plugs at most auto parts stores but I haven't checked. I wouldn't trust it to leak without something plugged
68anniversary is offline   Reply With Quote
Old 02-18-2011, 12:10 AM   #5
FL71C10
I was going to put it in gear as well and see how the transmission sounds.
Old 02-18-2011, 12:21 AM   #6
67chevy1series
looks like great minds think alike!
Old 02-18-2011, 12:34 AM   #7
ls1nova71
ls1nova71's Avatar
You can start it with no driveshaft, but I wouldn't put it in gear with the engine running with out the driveshaft. Without the yolk there is nothing supporting the output shaft of the transmission, it will move all over the place and could possibly damage the trans.
ls1nova71 is offline   Reply With Quote
Old 02-18-2011, 12:40 AM   #8
FL71C10
Good info, thanks! That's the kind of thing I want to avoid. No point running the transmission to find out if it's any good and then destroying it by being dumb!
Old 02-18-2011, 01:01 AM   #9
67chevy1series
what if the yoke is in?
Old 02-18-2011, 01:04 AM   #10
FL71C10
Then it will fly off and wreck the bottom of your truck AND the transmission.
