Old 02-18-2011, 01:06 AM   #1
mudmizer
mudmizer's Avatar
Any help/ideas of bouncing puller??
I have been trying to get the bounce out of my puller and have had a some success, but anyone have any help/ideas.
Rear is locked solid for the pulls. Rear axle has ladder bars. Hitch runs solid to the frame just under cab rear. Front springs are clamped to reduce spring wrap with torqe arms to the center of the frame. Running 35 inch BFSs with 60 psi. Truck runs in 4500-5500lb class and I weigh 5480lbs. I am not allowed to hang any weight on the front even if I droped weight somewhere. I have gotten a few 1st, but more broken parts than places. The biggest problem is it's short wheelbase. Due to the hop I have to get on and off the gas and I loose momentum. I'm thinking of a shorter tire for less side wall. 33s?? have 4:56 gears.
68 4x4, 454, 4 speed, disk brakes both ends,
Sold my 69 SS396 Elcamino when young & stupid
mudmizer is offline   Reply With Quote
Old 02-18-2011, 02:10 AM   #2
rayfinseats
Re: Any help/ideas of bouncing puller??
How about limiting straps on the front end? I'd play with raising or lowering the hitch. Get a slow motion side video? I'm an old drag racer.
rayfinseats is offline   Reply With Quote
Old 02-18-2011, 07:14 AM   #3
royo
royo's Avatar
Have you put any heavy weights on the front yet
nickle and dime
royo is offline   Reply With Quote
Old 02-18-2011, 07:50 AM   #4
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
I've never done any pulling to say so (do stuck trucks and tractors count?) But relating to test hill at the dunes, most people get bouncing like that because of tire pressure. Why 60 psi? COuld you try 30 or so and see if you get better results? With less pressure you'll increase your traction too...
Good luck and that's a nice truck you've got!
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
Old 02-19-2011, 12:53 AM   #5
mudmizer
mudmizer's Avatar
I'm not allowed to add weight in my class, so I can't hang any. My hitch is ajustable and I have wanted to try that, I'm running it at 26" now thats the max allowed. If I drop the height then I will drag more of the sled than carry it. I run 60 lbs on the tires because I have tried various pressures and the lower the pressure, the more sidewall flex and bounce thats why I'm thinking a shorter tire = less side wall flex/spongyness and less hop. I should then be able to run less pressure. I have tried limiting straps on the front, actually chaining it down by pulling the axle to the frame about three inches of compression. With only about 5 pulls a year around here it is hard getting it dialed in.
Here are a couple from the side, if they will help diagnose.
http://www.youtube.com/watch?v=3NgkO...embedded#at=42
Old 02-19-2011, 12:27 PM   #6
chas350
Frame flex/twist?
"I'll Procrastinate Tomorrow"
quote by LEEVON
71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's
70 K20 long fleet
98 G3500 work van
chas350 is offline   Reply With Quote
Old 02-19-2011, 02:17 PM   #7
tomtuna1978
looks like most of the hop is comming from the front susp. .... do u have the stock leif springs up there ? if so do the rules say tht you can 4 link it ? id try that and/or some 56 in springs or diff shock valving. also i ws thinking with all that bouncing the floats in the carb must be bouncing also ... and maybe swpping to fuel injection would help with the (if thats cusing sputter and or fuel slosh) bouncing. thats just my 2cents
tomtuna1978 is offline   Reply With Quote
