Old 02-18-2011, 07:26 PM   #1
broey
Square
broey's Avatar
my 84 swb by wcdfab
Hey guys. I lurked the forum for about a year getting ideas for my truck. Now thats its done I figured I would share the build. All the fab work was done by my friends shop.
here is the truck done
Here is what it looked like when I got it from Dino.
Tons of fab work has been done to the truck. My favorite part of the truck is the rear end. Every piece was hand made by Willy(my friend with shop) from the c-notch to the four link. He also pancaked both fuel tanks 3 inches and made new mounting straps so they could remain with the truck keeping both my fuel doors functional. The 7 gallon air tank was added to the spare tire location and a custom mounting plate was made for the air manifold so it could be mounted inside the frame but still be easily accessed. He also made a really slick transmission crossmember that has a rounded edged to keep it smooth incase it catches something in the road.
notch
bed cut out
bed being filled in
bracing for rear bag mounts
fuel tanks, 4 link, supports and manifold.
clearance when frame is on ground.
broey is offline   Reply With Quote
Old 02-18-2011, 07:43 PM   #2
broey
Square
broey's Avatar
Re: my 84 swb by wcdfab
So, after the rear was complete the front was next!! I love how this came out as I have not seen another like it. Instead of getting a crossmember or z'ing the frame, Willy opted to rebuild the existing crossmember.
The original crossmember was narrowed 2 inches. The upper control arm mounts were removed and the large holes you see in the picture were then plated. Very strong. then the whole crossmember was moved forward 1 inch and raised 3 inches and welded to the frame. To match the 2 inches narrowed for the upper arms, custom mounting plates were made to connect the arms directly to the frame. The frame was also boxed in this area to keep it strong.
When I bought the truck from Dino the front end had drop spindles and tubular control arms already (score!!) So Willy was able to fab a shock tower that ran through the center on the arms leaving me with fullsize shocks! It rides so smooth.
Also a mustang rack was added and the drop spindles had to be modified to accept it at such a low stance. You can also see the bag plates he made in the last picture. They look really good with the bags mounted.
So with the crossmember done, the engine was moved forward 2 inches and raised 1 inch to clear the firewall and keep a nice gap between the crossmember and oil pan. That also helped raise the transmission pan high enough to be off the ground for the stock floor body drop. only one small tunnel was needed under the bench seat for the drive shaft.
The driveshaft did have to be stretched 2 inches though.
So now with the front done, an inch and a half was taken off the bottom of the frame, and the frame was boxed to give it the "body dropped" look.
I love my new truck and I am so happy with how it turned out. I hope you guys enjoy!
Old 02-18-2011, 07:51 PM   #3
broey
Square
broey's Avatar
Old 02-18-2011, 09:12 PM   #4
lilpoindexter
lilpoindexter's Avatar
NO WAY...I actually have that you tube vid saved as one of my favorites!
lilpoindexter is offline   Reply With Quote
Old 02-18-2011, 09:13 PM   #5
broey
Square
broey's Avatar
awesome! ha, they did that video on an iphone like maybe 30 minutes after the truck was finally done.
Squarebody Syndicate
Old 02-18-2011, 09:50 PM   #6
mooseknuckles
mooseknuckles's Avatar
awesome build!...cool truck.
mooseknuckles is offline   Reply With Quote
Old 02-18-2011, 10:14 PM   #7
bigblock73
yeller
bigblock73's Avatar
Very cool truck and build, I like it.
bigblock73 is offline   Reply With Quote
Old 02-18-2011, 10:24 PM   #8
broey
Square
broey's Avatar
thanks!
Old 02-18-2011, 10:27 PM   #9
broey
Square
broey's Avatar
thanks dude!
Old 02-18-2011, 10:48 PM   #10
muthstryker
muthstryker's Avatar
Such a cool truck. Now I really want to bag mine sooner.. lol..
muthstryker is offline   Reply With Quote
Old 02-18-2011, 10:57 PM   #11
SBTork
Garage wrench
SBTork's Avatar
sick, just plain sick.
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 02-18-2011, 11:01 PM   #12
Pop's C-10
Pop's C-10's Avatar
i love how u did tha bed floor
Pop's C-10 is offline   Reply With Quote
Old 02-18-2011, 11:05 PM   #13
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Saw this on you tube a month or so ago, great truck, great ideas!
77' Chevy SB
Dropmembered Front and Rear
5.3/4l60e combo
JNJchev77 is offline   Reply With Quote
Old 02-18-2011, 11:10 PM   #14
justpball
justpball's Avatar
Very nice bro! Love it going down the road that low...
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 02-19-2011, 12:48 AM   #15
broey
Square
broey's Avatar
Lucky for me in Phoenix all the roads are pretty smooth and I can get away with driving that low quite a bit. Its got a bit of negative camber that low though so I only drive like that in traffic when it's going slow.
Old 02-19-2011, 01:05 AM   #16
West Texas Z
El Mero Mero Frijolero!!
West Texas Z's Avatar
WOW. This made me want to bag my truck now. lol I like how you used alot of the same factory parts to give it a original look. (like the bed floor)
West Texas Z is offline   Reply With Quote
Old 02-19-2011, 01:15 AM   #17
broey
Square
broey's Avatar
Thanks, thats sort of what I set out to do with the truck, well as much as possible anyway.
Old 02-19-2011, 02:55 AM   #18
Tow Me
Glen
Tow Me's Avatar
Looks good man! Makes me want to drive my truck... but its rainy.
Glen Simpson
Severed Ties - Oregon
Roseburg, Oregon
  • 1983 Chevrolet C10 - Ginger
    Photos
Past Trucks
Tow Me is offline   Reply With Quote
Old 02-19-2011, 04:09 AM   #19
muthstryker
Are you wheels 22s? I cant tell..
Old 02-19-2011, 08:09 AM   #20
73gmc454
73gmc454's Avatar
Clean cool ride I like it !
my build 77 gmc shortbed big block, http://67-72chevytrucks.com/vboard/s...d.php?t=438237
73gmc454 is offline   Reply With Quote
Old 02-19-2011, 10:10 AM   #21
Dinos63
chevy only
Dinos63's Avatar
duude nice to see ya post up the thread!!you and willie have done a killer job on this truck, any pics of how willie section the gas tanks???
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 02-19-2011, 06:42 PM   #22
broey
Square
broey's Avatar
yeah those are 22 inch AR wheels. 10 inch wide too!!
Old 02-19-2011, 06:45 PM   #23
broey
Square
broey's Avatar
No photos of the tank being pancaked, but he took 3 inches horizontally from the tank. After doing that only one corner doesn't line up so he took a wedge out of the corner about 3 inchs long and 1/2 inch wide to match everything up. The sending unit was also shortened to match the pancake.
Old 02-19-2011, 06:52 PM   #24
squaredaway
squaredaway's Avatar
Nice truck and nice work!
1987 Silverado
6.0/4L80E
5/7 Drop, 20x8.5(245/45)/20x10(295/45) Coy C5s
squaredaway is offline   Reply With Quote
Old 02-19-2011, 06:52 PM   #25
Chlsnk
Chlsnk's Avatar
Awesome build!
***My 84 short bed build up*****
http://67-72chevytrucks.com/vboard/s...68#post3481968
Chlsnk is offline   Reply With Quote
