Old 02-19-2011, 12:18 AM   #1
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Manifold problem
Slight problem with my factory exhaust manifolds. They hit my motor stands. I am using my stock 6 cyl engine stands with adapter plates. The manifolds hit the stans on both sides. What will fit? Headers are out of my budget. F body, TBSS? Thanks
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 02-20-2011, 09:43 AM   #2
brian mac
Re: Manifold problem
tbss fit with no problems
brian mac is offline   Reply With Quote
Old 02-20-2011, 12:05 PM   #3
usmcchevy
usmcchevy's Avatar
I hope so, I'm trying to sign up on TBSS owners to buy some now.
Build thread
LSx Swap FAQ index
Old 02-20-2011, 07:55 PM   #4
67shortie
Green club
67shortie's Avatar
I was going to look for some SS manifolds as well, my pass side truck manifold hits the perch and the flange rubs the frame.
They are are kind of hard to come by from where I am brousing around, uness you buy new ones which I think Dorman makes too. They are over $150 each though, I wonder if I can use just the pass side and use the truck manifold for the drivers? Humm.
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears
70 SS396 Chevelle 427/200-4R/3.73posi
61 Lincoln Continental, black on black
Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln
67shortie is offline   Reply With Quote
Old 02-21-2011, 11:05 AM   #5
brian mac
I found mine on ebay by searching for "v8 blazer manifold" paid about 125 dollars a pair shipped.
Old 02-22-2011, 09:30 AM   #6
usmcchevy
usmcchevy's Avatar
Just got some on TBSSowners for $60 shipped. There is another set on there for $70 Shipped if anyone needs them.
Build thread
LSx Swap FAQ index
Old 02-22-2011, 01:39 PM   #7
67shortie
Green club
67shortie's Avatar
Want them, I will register over there and see if they are still available.
Registered, there are a few sets for sale still, thanks for the heads up USMC!
Old 02-25-2011, 04:56 PM   #8
usmcchevy
usmcchevy's Avatar
Bad news, Got the TBSS manifolds today......no go. They still hit the frame stand. A little bit closer, but still not going to bolt in.
Pics taken with bolt in rear most manifold hole.
Build thread
LSx Swap FAQ index
Old 02-25-2011, 05:11 PM   #9
Clyde65
Clyde65's Avatar
you are using stock motor perches right?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-25-2011, 06:51 PM   #10
usmcchevy
usmcchevy's Avatar
Yep, stock 6 cyl stands. Right now I'm trying to decide if I can make enough clearance with grinding both the manifold and the stand or if I should just buy some POL tubular stands.
Build thread
LSx Swap FAQ index
Old 02-25-2011, 08:27 PM   #11
brian mac
I should have stated before that I used the '73-up perches and mounts. They don't bolt in but was an easy mod for the height difference in frame rails of the 67-72 and 73-87. I had to use the tbss manifolds and the 73-87 motor mounts. I apologize for not providing all the information.
Old 02-25-2011, 10:17 PM   #12
usmcchevy
usmcchevy's Avatar
All good man. I just need to figure this out, maybe the 73+ mounts will work for me.
Build thread
LSx Swap FAQ index
Old 02-25-2011, 10:30 PM   #13
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
those manifolds are pretty thick....doesn't look like you need much off of them?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 02-26-2011, 02:23 AM   #14
andrewt2
andrewt2's Avatar
I used 6 Cylinder Stands originally, I couldnt get Truck Manifolds, or F body manifolds to fit at all without cutting and griding on the engine stands. I've since removed them for v8 stands because I didnt like how far back the motor sits with the 6 cylinder stands.
andrewt2 is offline   Reply With Quote
