![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
InstInstrument Panel Wiring Question, What is This?
Ok, I replaced the old dash "after" removing the instrument panel,radio,ash tray,defroster vents and glove box lid. I damaged the glove box liner removing it. There is single wire leading to a single twist in bulb/socket. All the other twist in single unit bulbs are energized off the circuit board/sheet. The bulb socket in question was white instead of black like the others. It also had "Strange" steel clip molded into the top of the twist in socket. What is this and why is it engineered like that? I busted it also removing it from the panel.
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
Member #1049
Re: InstInstrument Panel Wiring Question, What is This?
That wire is actually a fiber optics cable designed to transfer light from the bulb to your shift indication on your steering column.. normally all the light sockets are filled even though your temp gauge is mech..
454 MAKES IT ROAR
That bulb isn't for the shift indicator it's way to big, the bulb in the shift indicator is tiny and has it's own built in housing in the column, it also has nothing to do with your dash as you can see yourself it does not match, the only things I can suggest is that it maybe the light to illuminate your heater control panel or it was some PO add on/mod that is no longer in use. Where is your glove box light by the way? the bulb in the pic does not match that either but could be some sort of PO modified version of a glove box light...just guessing.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger Last edited by eightbanger; 02-19-2011 at 10:25 AM. |
Livrat is correct. That light with the fiber optic cable gets plugged into your dash and the cable provides the light to your gear indicator on a non-tilt column.
Eightbanger is correct too although he is talking about a tilt column.
-Scott- |
![]() Join Date: Apr 2010
Livrat is correct, it is a fiber optic cable to send light to shift indicator on non tilt automatic columns. It take the light from that bulb which should be on when light are turned on.
Firefighter
Livrat is correct, that is for the indicator on a non tilt column, tilt has a wire that plugs into the fuse box and has its own bulb in the column.
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() |
#7 | |
454 MAKES IT ROAR
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
Thanks for the replies you guy's!
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() Last edited by Ironangel; 02-19-2011 at 07:10 PM. |
#9 | |
