Old 02-17-2011, 11:45 PM   #1
JJorgensen52
Simple? What's simple?
JJorgensen52's Avatar
home-grown light upgrade
Always looking to upgrade lighting on my truck - this is an upgrade I first did on a buddies' '67 mustang coupe.
Jeep JK Wrangler headlights ('07-current) are a direct bolt in swap for the old sealed beam headlights in our trucks. Requires changing from the H4 style connector to a H13 style connector (late model fords, jeep, etc). This whole swap (using junkyard parts) cost me about $100, including silverstar bulbs.
one old, one new
new on right (crisp light cutoff and concentrated beam), old on left (wider, more scattered light and hazy cutoff)
Lows, silverstar bulbs and new housings
Highs
difference in the amount of light on the road ahead of you is absolutely night and day. Well worth the hour and a half of effort.
CURRENT
'50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build
'63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos
'66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos
'69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!)
'72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh
'99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily)
'99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs)
SOLD
'71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder)
JJorgensen52 is offline   Reply With Quote
Old 02-17-2011, 11:49 PM   #2
firedog
firedog's Avatar
Re: home-grown light upgrade
Did you upgrade the headlight wiring harness to use relays?
*SOLD*
1968 Chevy SWB Fleet
350/350 combo
Tach/tilt/buddy buckets
Bagged/18" Wheels
Black on Black
Project "Pandemic" the Farm Rat
1927 Chevy Capitol Truck Rat rod
'30 Model A Frame
Dual Carb 5.3 LS
http://www.67-72chevytrucks.com/vboa...d.php?t=804162
2007 GMC 4 DOOR 2WD
BUILT 5.3 STAGE 3 CAM 93 TUNE
LIFTED 22X12 WHEELS 33" TIRES
2023 Jeep RENEGADE
Wifes ride
firedog is offline   Reply With Quote
Old 02-18-2011, 12:25 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
THIS is the kind of info I love seeing on here.
If you haven't done the relay mod yet, do it. Your lights will be just as bright as when they were on the Jeep.
Also... silverstars are amazing bulbs for those not in the know
Old 02-18-2011, 12:28 AM   #4
JJorgensen52
No relays yet, it's in the works - need to modify the plow lights harness to better fit the truck, will add them at the same time
CURRENT
SOLD
Old 02-18-2011, 12:58 AM   #5
Cdaddy731
Very cool, can someone elaborate on the relay upgrade?
1969 Chevy C/10 Stepside
307-3 on the tree
www.GoZipTexas.com
Cdaddy731 is offline   Reply With Quote
Old 02-18-2011, 01:11 AM   #6
JJorgensen52
I am sure someone will come up with a diagram here in a few minutes, but in a nutshell:
you take 2 standard normally off relays, and hook them into the high and low beam power wires on the headlight harness on one side, and to the battery/alternator on the other.
Then you use your original high and low beam wires to trigger the relays and supply power to the headlights right from the battery (or alternator).
This serves two purposes: 1. it gives your headlights the most direct line of power they can have, allowing them to perform to their fullest potential and 2. it prevents your new, upgraded headlights from pulling too much current through the 40+ year old headlight switch and causing it to fail (or light on fire )
CURRENT
SOLD
Old 02-18-2011, 01:27 AM   #7
69sixpackbee
Great mod!
Too bad they're plastic or I'd do it in a heartbeat. Southwestern sandstorms and UV rays are not conducive to their longevity
69sixpackbee is offline   Reply With Quote
Old 02-19-2011, 02:46 AM   #8
stealthy '69
'69 Chevy SWB
stealthy '69's Avatar
very cool. I'll be looking into doing this
Matt
'69 Chevy SWB Fleet, Primer Black; Project No Name
'06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold
'08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!!
'99 Dodge Dakota R/T, Intense Blue; DD, Sold
Originally Posted by longbed67 View Post
The tig welds are not the prettiest i have seen but they do have good penetration.
Originally Posted by oldblue1968chevy View Post
There are two things in life where penetration is really important.....and one of them is welding.
stealthy '69 is offline   Reply With Quote
Old 02-19-2011, 10:54 AM   #9
SevenOne
SevenOne's Avatar
Should this mod work on the 67-72 gmc's also?
SevenOne is offline   Reply With Quote
Old 02-19-2011, 11:17 AM   #10
Andy4639
Old member
Andy4639's Avatar
Lightbulb Re: home-grown light upgrade
Can you show the upgraded connector you speak of. I would like to see the diferance between the two. I have done the light update with aftermarket lights with the relays just was thinking about the bulb upgrade.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-19-2011, 01:09 PM   #11
Shyguy
Junior Member
Shyguy's Avatar
Here you go.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 02-19-2011, 01:13 PM   #12
m6z
m6z's Avatar
great info.
Doug
Looking for a 67-72 short bed driver.....
m6z is offline   Reply With Quote
Old 02-19-2011, 01:29 PM   #13
RPBurris
RPBurris's Avatar
Sooo....where can you buy the relay? this sounds like a great easy upgrade that i would like to do. Is it a over the counter part? can i swipe it from the jeep when i find my headlights?
1969 Chevy K20 Longbed
RPBurris is offline   Reply With Quote
Old 02-19-2011, 01:54 PM   #14
Warrens69GMC
Warrens69GMC's Avatar
Autozone carries the 4lug relay and a 5 lug relay for less than 5.99ea.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 02-19-2011, 02:04 PM   #15
msgross
msgross's Avatar
very cool upgrade, thanks for sharing... pics of the entire process would help some of the guys...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 02-19-2011, 02:05 PM   #16
Warrens69GMC
heres a ebay listing for the 7" round conversion kit-
7" round Conversion
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 02-19-2011, 02:20 PM   #17
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
I'll be saving this page so I can do my k20 and my nova.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 02-19-2011, 02:33 PM   #18
Lippyp
English Chevy Owner
Lippyp's Avatar
LMC sell a ready made conversion harness with the relays etc, just plug it in. Top of the page, tbh by the time you've bought the relays, cable and connectors it won't be much cheaper and this is very neat. http://www.lmctruck.com/icatalog/cb/full.aspx?Page=69
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 02-19-2011, 09:02 PM   #19
JJorgensen52
7" round Conversion
One of the reasons I chose the Jeep lights over the after market lights is that the Jeep ones have a much better seal, I've had water get in the aftermarkets too many times. Also, both the overall build quality and the light pattern of the Jeep ones is better.
Also, for those who have state safety inspections, the aftermarket lights are not actually legal (and I have been gigged for it). The Jeep headlights are SAE and DOT approved for road use.
These are the connectors that the new headlights use.
http://www.repairconnector.com/produ...or-Socket.html
Other than soldering the new connectors in place, it's just like changing a lightbulb. The Jeep lights even have the same lugs cast into the housing as sealed beams so you can't install them wrong side up. My wiring (because it's a plow light harness) looks different than the factory stuff, also.
That said, I can tell you the following:
On the factory bulb, when you pull the connector off the back and look at the socket, you'll see three slots, two vertical on each side and one horizontal on top. The driver's side vertical is ground, the top is low beam and the passenger's side vertical is high beam.
On the new connectors, black is ground, red is low and green is high. (I always test just by sticking the stripped wires into the old connector first, to be sure)
CURRENT
SOLD
Old 02-20-2011, 09:47 AM   #20
Dave
DND Trucks
Thanks to all for the info, this is a really useful install.
Dave is offline   Reply With Quote
Old 02-20-2011, 09:50 AM   #21
Longhorn Man
I'll never buy those china made low dollar headlights again. I have never seen any that were any better than a mini mag light. They claim to be DOT, but I'm willing to bet you won't get converson lights with a real DOT cert for less than $60 a piece.
The relay will, but the jeep headlights are 7 inches... GMC has smaller lamps.
Old 02-20-2011, 09:01 PM   #22
pritch
pritch's Avatar
Hey-I got a set of those Jeep lights just sitting out in the garage.
(I wonder if my wife would notice we traded)
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 02-20-2011, 10:57 PM   #23
Sir Fisher
Sir Fisher's Avatar
sweet, thanks for the info
1970 Chevy K20 Custom Camper
1996 Chevy Impala SS
2008 Chevy Avalanche LT3
2003 Honda Accord EX
2001 Hewes Redfisher 16 Fighting Lady Yellow
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=324118
Sir Fisher is offline   Reply With Quote
Old 02-22-2011, 01:05 AM   #24
mr48chev
mr48chev's Avatar
The Jeep lights will throw a better and more consistent light pattern than most of the aftermarket lights.
I can say from experience that relays are a must if you upgrade the lights on these trucks. I killed several dimmer switches before installing the relays.
Jeep Cherokees from the mid 80's have a bracket on the right inner fender with several of the common cube relays that is easy to get. I took as much wire as I could get with the set I got.
I went through several sets of H4 lights that had the clear lens and etched reflectors and was never satisfied with them. I finally went with these. http://cgi.ebay.com/ebaymotors/7-H60...Q5fAccessories With the 55/100 White bulbs you can't outrun them on high beam. They run pretty close to the Cibies I had in the 48 years ago.
That seller is excellent to deal with too and his lights are first rate.
I might just be hunting an unsuspecting Jeep though.
Old 02-22-2011, 09:01 AM   #25
Cibie Bobis. That's all I needed to hear. Best alternative to landing lights ever. If those lights throw a beam like those,I'm sold!
