Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 67-72
Closed Thread
Old 02-17-2011, 11:45 PM   #1
JJorgensen52
Simple? What's simple?
JJorgensen52's Avatar
home-grown light upgrade
Always looking to upgrade lighting on my truck - this is an upgrade I first did on a buddies' '67 mustang coupe.
Jeep JK Wrangler headlights ('07-current) are a direct bolt in swap for the old sealed beam headlights in our trucks. Requires changing from the H4 style connector to a H13 style connector (late model fords, jeep, etc). This whole swap (using junkyard parts) cost me about $100, including silverstar bulbs.
one old, one new
new on right (crisp light cutoff and concentrated beam), old on left (wider, more scattered light and hazy cutoff)
Lows, silverstar bulbs and new housings
Highs
difference in the amount of light on the road ahead of you is absolutely night and day. Well worth the hour and a half of effort.
CURRENT
'50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build
'63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos
'66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos
'69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!)
'72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh
'99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily)
'99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs)
SOLD
'71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder)
JJorgensen52 is offline
Old 02-18-2011, 12:28 AM   #2
JJorgensen52
Re: home-grown light upgrade
Originally Posted by firedog View Post
Did you upgrade the headlight wiring harness to use relays?
No relays yet, it's in the works - need to modify the plow lights harness to better fit the truck, will add them at the same time
CURRENT
SOLD
Old 02-18-2011, 01:11 AM   #3
JJorgensen52
Originally Posted by Cdaddy731 View Post
Very cool, can someone elaborate on the relay upgrade?
I am sure someone will come up with a diagram here in a few minutes, but in a nutshell:
you take 2 standard normally off relays, and hook them into the high and low beam power wires on the headlight harness on one side, and to the battery/alternator on the other.
Then you use your original high and low beam wires to trigger the relays and supply power to the headlights right from the battery (or alternator).
This serves two purposes: 1. it gives your headlights the most direct line of power they can have, allowing them to perform to their fullest potential and 2. it prevents your new, upgraded headlights from pulling too much current through the 40+ year old headlight switch and causing it to fail (or light on fire )
CURRENT
SOLD
Old 02-19-2011, 01:09 PM   #4
Shyguy
Junior Member
Shyguy's Avatar
Here you go.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline
Old 02-19-2011, 01:29 PM   #5
RPBurris
RPBurris's Avatar
Sooo....where can you buy the relay? this sounds like a great easy upgrade that i would like to do. Is it a over the counter part? can i swipe it from the jeep when i find my headlights?
1969 Chevy K20 Longbed
RPBurris is offline
Old 02-19-2011, 01:54 PM   #6
Warrens69GMC
Warrens69GMC's Avatar
Autozone carries the 4lug relay and a 5 lug relay for less than 5.99ea.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Warrens69GMC is offline
Closed Thread
