Old 02-20-2011, 09:06 AM   #1
RoyL
RoyL's Avatar
64-66 Automatic Brake Pedal? Other Years Fit?
I've heard only 5% of these trucks were automatics? Will other year GM wide brake pedal trucks fit? 67 and up?
Thx,
Roy
1965 Suburban
Waiting on Time and Money
RoyL is offline   Reply With Quote
Old 02-20-2011, 09:38 AM   #2
onequickchevy
onequickchevy's Avatar
Re: 64-66 Automatic Brake Pedal? Other Years Fit?
Probably easier to just cut the wide pedal off a donor and weld it on your existing. I know thats not what your asking, but thought i'd just mention it.
Slowly but surely getting it done.
onequickchevy is offline   Reply With Quote
Old 02-20-2011, 11:00 PM   #3
65Gregg
65Gregg's Avatar
I just removed the clutch pedal off of mine when I converted mine..
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 02-20-2011, 11:35 PM   #4
ConnDemned
I don't believe autos came with a wider brake pedal until 73, I know the 67-72 uses a smaller pedal. If you really want a wide pedal, you could see if you could find a newer one and take the pedal, arm and all, and replace the one in your truck. Just measure the length of the arm, the offset and see what you can find to work. Good luck with your project.
ConnDemned is offline   Reply With Quote
Old 02-21-2011, 12:57 AM   #5
Captainfab
60-66 Nut
As ConnDemned said, the early auto trucks didn't have a wider brake pedal pad. The one in my Burb is the same brake pedal as a manual trans truck. If you want a wider pedal pad, I would say some cutting and welding will be involved.
Old 02-21-2011, 09:44 AM   #6
jbgroby
jbgroby's Avatar
I have a 4 sp. hydramatci and te pedal is the same size and same location, they just did not add the clutch pedal.
jbgroby is offline   Reply With Quote
Old 02-21-2011, 12:09 PM   #7
RoyL
RoyL's Avatar
Thanks all! For some reason, I thought there was a easy swap out there for a wider pedal. The 64 C10 I had a few years ago had one, maybe they did weld it . . .
Thanks again for the info!
Roy
1965 Suburban
Old 02-21-2011, 07:13 PM   #8
duallyjams
duallyjams's Avatar
I just got home from a local junk yard that had two trucks with auto pedals one was a 60 and the other was a 66 and the brake pedal is the same in all the truck auto or stick.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 08-13-2011, 08:46 AM   #9
RoyL
RoyL's Avatar
Got a pedal from a 80-something box truck:
1965 Suburban
Old 08-13-2011, 11:11 AM   #10
ratskin
I stripped a 64-66 GMC 1T a couple years ago, and it had the same small brake pedal as my 64 Chevy Suburban factory automatic. However, the GMC pedal(stick) had the word POWER cast into the pedal. Never seen another like it! This one was like new, and now adorns my 64 Suburban. Anyone else come across these?
ratskin is offline   Reply With Quote
