Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-21-2011, 11:59 AM   #1
69trk
69trk's Avatar
bigs n littles
I found a set of 15x6.5 van rally wheels and i'm wondering what size tire would look best on the front and rear. If i buy these i will try to find some 15x10 truck rally's for the rear. Truck has a 2.5" front drop with a 4" rear drop.
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 02-25-2011, 10:58 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: bigs n littles
225 70 looks pretty good.
R/
Hart_Rod is offline   Reply With Quote
Old 03-03-2011, 08:58 PM   #3
68longhorn
68longhorn's Avatar
Re: bigs n littles
this is my brothers truck, 15x6.5 in the front with 225/70 and rear tires are 31x10.5 on 15x7 rims
1986 Custom Deluxe 10
1978 Caprice 2 door - sold
1937 Chevrolet 2 door sedan - project
68longhorn is offline   Reply With Quote
Old 03-05-2011, 06:59 PM   #4
69trk
69trk's Avatar
Re: bigs n littles
If i go with a 225/70 up front, how tall should i go on the rear?
1.58- 60'
11.37- 1/4 @115.81
Old 03-06-2011, 09:43 AM   #5
68longhorn
68longhorn's Avatar
Re: bigs n littles
as big as you want! On the 71 we found a junk set of 31x10.5 for test fit and they were just what we wanted.
Old 03-11-2011, 12:17 PM   #6
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: bigs n littles
i had 225 70s on the front and 275 60 et streets on the back
both sat at just under 28 inches tall
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 03-11-2011, 01:13 PM   #7
dougminton
dougminton's Avatar
Re: bigs n littles
Dale, did you buy 4 6.5 inch rallies. If so I'm interested in buying the other two for the front of mine.I'm gonna run 29x14.5s quick time pros on 15 x11 in the rear.
The TEAL GMC build thread is HERE
1972 GMC SWB
454 oval ports
TH400
fastest 1/4 mile time so far
13.05 @ 104
If you think you have too much horsepower
you obviously have a traction problem !
dougminton is offline   Reply With Quote
Old 03-12-2011, 10:40 PM   #8
69trk
69trk's Avatar
Re: bigs n littles
I have 3. But the guy that has them has them posted on craigslist for $75. And i think he has 4 left. I talked him down to $10 apiece. Type in rally or ralley, can't remember how he had them posted...
1.58- 60'
11.37- 1/4 @115.81
Old 03-13-2011, 06:05 PM   #9
bigboybodry
bigboybodry's Avatar
Re: bigs n littles
I have a 1970 gmc with a 16" wide rim with a 31/10.5w/15 under it with a stock width rear end. The only thing I did is install a wheel tub and a custom offset rim 10" to the inside.
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ
bigboybodry is offline   Reply With Quote
Old 03-13-2011, 08:39 PM   #10
dbmx66
Re: bigs n littles
15x4 rims with 25x5s in front, 15x15 rims with 33x19.5s in rear
dbmx66 is offline   Reply With Quote
Old 03-14-2011, 04:47 AM   #11
low&slow
Re: bigs n littles
Probably a dumb question, but I've never under stood tires and rims to well. How does your 10.5 inch wide tire fit on a 16 inch wide rim?
low&slow is offline   Reply With Quote
Old 03-14-2011, 10:22 AM   #12
team39763
Re: bigs n littles
I believe that 10.5W tire is over 15 inches wide.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs.
Best time so far 11.8@XXXMPH
team39763 is offline   Reply With Quote
Old 03-14-2011, 11:23 AM   #13
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: bigs n littles
I would drive this truck all around the place without the front end....
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 03-14-2011, 12:48 PM   #14
bigboybodry
Re: bigs n littles
That is the largest tire we can run in our class and by putting it on that wide of wheel you are blowing out the sidewall put the max down on the track
