Old 02-21-2011, 11:59 PM   #1
67chevy1series
67chevy1series's Avatar
tailgate metal layers sperading what can be done to fix?
me and jasonbird have both talked about our projects through pms and both have a common issue in our 67 tailgates the 2 layers are spreading. what can be done to fix that jason's and mine are in good condition and are original to the cab or truck so it would suck to have to throw them away so what can be done to fix this?
any ohthers that have this problem go ahed and ask any questions that may have not been asked on this matter...
thanks for soon to be help!
67chevy1series is offline   Reply With Quote
Old 02-22-2011, 12:33 AM   #2
jerry moss
Born Psycho
jerry moss's Avatar
Smile Re: tailgate metal layers sperading what can be done to fix?
check with your local fab/metal shops and see if any of them have a spot welder. we used to have one in the metal shop back in high school-long before you were born and not too many years after your truck was built,lol. you can clamp it back together, drill out the original spot welds, use a flat piece of brass as a backing and mig weld the holes you drilled-the weld won't stick to the brass. i use an old brass proportioning valve since it is flat and fairly thick to absorb heat.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 02-22-2011, 12:34 AM   #3
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Got pix? I am not fully comprehending your problem, unless that you're writing about is a separation of the metal at the base of the tailgate. I'm thinking that if that is what you mean, then there is some corrosion within and between those pieces.
Member Nr. 2770
Old 02-22-2011, 12:43 AM   #4
67chevy1series
well here are pics
Old 02-22-2011, 12:47 AM   #5
threeonthetree
threeonthetree's Avatar
the only way to fix it properly is to drill out all the spots separate grind the first piece clean then re weld...
Smoking Tires Since 1992
1969 c10 AKA SIN
1985 SSWB TRAZER
(super short wheel base)
threeonthetree is offline   Reply With Quote
Old 02-22-2011, 12:47 AM   #6
jerry moss
Born Psycho
jerry moss's Avatar
either way i posted earlier will work.
jerry moss
Old 02-22-2011, 12:51 AM   #7
threeonthetree
i'd just leave it to be honest put a ton of rust converter in there or something.
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 02-22-2011, 12:54 AM   #8
threeonthetree
jerry i dont understand what your doing with the brass
? just using it to absorb heat?
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 02-22-2011, 01:01 AM   #9
67chevy1series
well guys when time comes i will try the answers above thanks
Old 02-22-2011, 01:04 AM   #10
threeonthetree
rick haha just drill some holes clamp it down and weld it if its buggin you that bad!
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 02-22-2011, 01:07 AM   #11
05crewcab
05crewcab's Avatar
you could maybe sand in between the pieces real good, JB Weld it and clamp the snot out of it?? Not ideal, but it might work in a pinch.
I am thinking of doing that as I don't have a welder...
1971 C-20 350/350
05crewcab is offline   Reply With Quote
Old 02-22-2011, 01:07 AM   #12
67chevy1series
no it isnt buggin me that bad. me and jason were just lookin to see hwat can be done and now no need to wait for replys we can always come back and look at this
Old 02-22-2011, 01:09 AM   #13
threeonthetree
really the only way i see fixin it right is to drill the all the spots out and re weld them all. after you clean up the inner pieces. lots of work for a cheap tailgate i guess
where you saying there's a differences between 67 and the rest tailgates?
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 02-22-2011, 01:10 AM   #14
67chevy1series
that a good idea to.. we have a mig welder but it is acting up and we will rprobably need a new gun so that takes care of that and i am just gonna get ,my truck running and driving, then take care fo its cosmetics
Old 02-22-2011, 01:12 AM   #15
threeonthetree
im pretty sure my tailgate is doing this to i just didnt wanna screw with it.
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 02-22-2011, 08:56 PM   #16
67chevy1series
i am guessing that there are alot of tailgates that have this..
Old 02-22-2011, 09:12 PM   #17
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
My tailgate isnt, its rust free and paper thing full of dents
John
1999 Toyota Tacoma 4x4
Old 02-22-2011, 10:00 PM   #18
67chevy1series
oh yea...AFTERMARKET! haha just jokin john i hope i never have to buy any after market body panels for any of my cars and trucks in my life unless they are from GM
