#326 |
VA72C10
![]() Join Date: Mar 2008
Re: Project 67 DRGNWGN - 67 Burban!!
On the wheels not being centered...that's common with bagged trucks....I ended up having some spacers made to move the trailing arms back (put in between the T/A crossmember and the t/a mount)
Or you can move the whole crossmember back the necessary amount.
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#327 |
low n' slo
![]() Join Date: Mar 2009
ah, ok, well that makes me feel better lol...thanks.
i thought i screwed something up! im thinking of switching to 1.5" blocks to keep the bags from getting that flattened out, they just scares me. that flatten out so much, the notch makes contact with the bags. so as soon as i find some 1.5" blocks to trade or buy, ill be swapping those in and straightening the bag up, then fix the shock mounts. gotta do something while the compressor is down... *edit* $10.81 and a new v belt later, compressor is running like a champ! ill get on sanding down the doors this week and also repraying the window frame and passenger side door jambs.
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] Last edited by kev2809; 02-14-2011 at 07:45 PM. |
#328 |
well mkevin i think you have the sexiest 67 suburban on the site! you need to sand them doors and install them! it must suck thats alot of roof and body......
#329 |
low n' slo
lol..im working at it. and yes, i had to take a week of from work to get the quarters and roof sanded down and painted...man that sucked!
i may have found a new way to mount my bags...im thinking of something like this.. ![]() a little hard to see but its just the bags moved along the trailing arm, then mounted to a crossmember going across the frame. still thinking about it so i guess well see
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
#330 |
thats a good idea i bet ou can do that no problem! keep up the good work kevin!
#331 | |
dave
uuuuuummmmmm!!! don't wanna burst ur bubble but, speaking from experience...the bags mounted to ur trailing arms will work for a while but in the longrun, no good....mine was that way and the driverside trailing arm started to seriously twist, bady so bad we made 6,yes 6 1/4" spacers under that sides bag to make up the difference in lift ended up doing the trianglulated 4 link much better, but lots more work just my opinion( and expereince) build is awesome otherwise checkout my build "dirty burb"
![]() Quote:
check out my build "DIRTY BURB" ![]() |
#332 |
low n' slo
well im gonna try another idea...i bought some top mounts that bolt to the side of the frame, just looking for some lowers and ill be getting on it. it basically will let me get a few inches lower, just like the above picture would...just moving the bags outside the frame rather than in between it. i need a lower bag plate that will bolt to the stock coil location, and then ill weld gussets to strengthen it up some.
in the meantime, i got the back passenger door sanded down, inside and out, and primered up. i then hung it, which probably was a waste of 3 people and 20 minutes because i have to replace that rocker lol. hopefully i can get it off without removing the door, but i will if i have to. i did the get the new rocker in as well... heres a few pics of the past couple of days of work.. ![]() ![]()
#333 |
it is lookin amazing i woulod hate to see it rain! so have you sweeped out all the dirt and threw away all the trash on the inside?
#334 |
low n' slo
lol ya..i need to hurry and get the doors and glass back in! i ripped out all the carpet seats trash a few months ago...although u probably couldnt tell with all my crap layin in there lol
#335 |
Coordinator of Synchronicity
![]() Join Date: Dec 2005
looking good Kev ... you've made some real head way
Rick 1971 Suburban ... W.I.P. Build Thread Customization is ones personal touch-- not what other people think it should be |
#336 |
lookin good kev
#337 |
low n' slo
thanks, long time no see! hows the burb coming along?
thanks! got the front passenger door sanded down and primed, also scuffed the passenger door jambs and front window frame and reprimed that also, i was having compressor problems the first time around..and hung the door! this front door is super tight to open and close...does that mean it needs new pins? ![]() ![]() ![]()
#338 |
oh that looks perfect you can now send me my burb back!
#339 |
low n' slo
lol..you cant wait...I cant wait!! im tired of all my stuff laying around on the ground lol
well, i got the driver side door sanded all up, only sprayed the inside of it first. bad news is, i ran out of primer! man this sucks..im gonna try to scrape ALL of it out of the can, or at least as much as i can. and try to spray the other side tomorrow. i guess well see what happens, because another gallon is just not in the budget right now ![]() ![]() ![]() ![]()
#340 |
Sofa King Crazy!!
Kevin....you rock! That burb is lookin sweet!! Can't wait to see some gloss black pinstriping on that flat black!
You found the Tater. ![]() My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. ![]() 1972 2wd Blazer "Porterbuilt and Sloshed" ![]() |
#341 |
kevin this burb is so awsome ! hurry up and put that door on! hahaa
#342 |
low n' slo
and its on! nothing special, but glad its on now! lighting sucked today, so the door looks ugly but its the same color as the rest of the truck (except this 4th door area, for some reason its the only section that was really shiney when i sprayed it)
#343 |
looks good now get the windows and front clip on haha
#344 |
low n' slo
lol...man ur turning out to be my motivation!
well, since i ran out of primer earlier this week i cant do anything with the rear hatch and gate, and the front clip. sooo...im hopinh i can get my friends cherry picker over and start to pull this motor, clean up and shave the firewall, paint it, then get the my new motor in. BUT, i guess well see what i can do in the next few days, thats a tough one for me to do myself right now.
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] Last edited by kev2809; 03-04-2011 at 09:38 PM. |
#345 |
Junk Yartist
Thats because the fourth door wants to get your attention! It wants to OPEN!
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
#346 | |
#347 |
looking sweet
now hurry up lol. Last edited by project 67 sub; 03-05-2011 at 02:55 AM. |
#348 | |
![]() 2005 K2500 Duramax (hauls the junk home) 1967 Chev C10 (hauls a$$) 1970 Suburban (Yukon XL 4 door) 1968 GMC 3/4 ton (sheetmetal only, chassis gone) 2005 Malibu (wife's car, still a Chevy) Project Family Hauler New Home for Chevys (Moved in and working) Last edited by pickup67man; 03-10-2011 at 11:19 PM. |
#349 |
low n' slo
lol...u guys are funny. no progress to report...kinda sucks. been REALLY tied up lately and havent done squat. i did get to move it back in the yard on to some "level" ground...snapped a few pics. im still trying to get the back hatch and tailgate and jamb sanded down and sprayed...until then, this will have to do
#350 |
Sofa King Crazy!!
Hey Kev! That burb is just sick!!! I want one so bad.......
