Old 02-22-2011, 01:05 PM   #1
68c10owner
68c10owner's Avatar
budget swap?
Been looking for LS info and just noticed this little forum. Anyone got a low buck build? I`m thinking about a 4.8 or 5.3 for my DD 83 chevy but dont have alot of money to spend and dont need all the fancy stuff on there. Just looking for the cheapest way to do a swap. Thanks.
Anthony
68c10owner is offline   Reply With Quote
Old 02-22-2011, 03:36 PM   #2
Clyde65
Clyde65's Avatar
Re: budget swap?
4.8 will set you back $500-1000, depending on where and the mileage on it.
tune/harness will set you back around $450.00 ( waitformeperformance.com)
fuel pump/filter and regulator will set you back around $150.00
you can use the TH350/700 with an adapter from Transdapt ( flywheel) under $300.00
add another couple hundred for misc stuff
Hope this helps.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-22-2011, 03:39 PM   #3
68c10owner
68c10owner's Avatar
Re: budget swap?
Hope this helps.
Yes it helps but I was also someone would be able to say get this, dont get that, do this, dont do that. you know what I mean? I have a 700R4 in my truck now but its a 83 model and as far as I know never rebuilt. I`ll have a motor/trans ready to swap when I`m ready to do it.
Anthony
Old 02-22-2011, 04:25 PM   #4
heeroyue2002
fat old dude
heeroyue2002's Avatar
Re: budget swap?
hmm. i may do an ls swap in my 68 in the future.
1972 c-10 shortbed 350/400
build thread http://67-72chevytrucks.com/vboard/s...d.php?t=389157
1968 workhorse http://67-72chevytrucks.com/vboard/s...d.php?t=446216
Accepting part donations
heeroyue2002 is offline   Reply With Quote
Old 02-22-2011, 04:58 PM   #5
Clyde65
Clyde65's Avatar
Re: budget swap?
68, what's the fun in having all the PN's and directions?
1983,huh? you would need mounts, Dirty Dingo ( the flat plate to attach the motor to your mounts), Walbro 255 fuel pump, corvette pre filter and filter/regulator( this depends on year of motor)
tune/harness,
You could also get a FI tank for an 87 and put the pump in there.
what else would you need to know?
Clyde65
Rebuild of Clyde
support our troops!
Old 02-22-2011, 05:10 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: budget swap?
DON'T get a 4.8 - for the money, you can get a 5.3 and you'll be happier should you decide to start pushing the performance end of things
DON'T re-use a transmission of unknown quality. you don't wanna put it all the work, and smoke a 700r4 on the third time round the block. Also, if your motor is DBW, you have to change to DBC to use any of the cable transmissions
DO get your harness re-worked or have a custom one made. If your confident and have time, you can save money modding your own harness, but usually for the cost of the stock harness + mental sanity you can have one done for you. Some companies also include stuff like a fuse block etc that makes wiring easier.
DO try to get the motor as complete as possible. Makes tracking the "little things" easier when they all came attached to the motor.
DO be realistic about budget. Even on a tight well controlled project, there are always some hidden costs. Don't strand yourself.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-22-2011, 05:17 PM   #7
68c10owner
68c10owner's Avatar
Re: budget swap?
tune/harness,
Well it makes it easier for us guys who haven`t ventured into the late model stuff before. I guess that pretty much covers it except the actual install itself but shouldn`t be too dificult. The fuel system and electrical is whats going to take me some time.
With this project I`m not nessicarily looking for performance but a reliable drivetrain that has more power than my smogged out 305 and gets decent economy. I figure I should be able to get close to 20mpg with either set up. I seem to find more 5.3`s for sale than 4.8`s anyway so I`ll probably go that route. As for the tranny, they usually come with some sort of a 30 day warranty from the yards but my friend is a GM tech with 30yrs of building transmissions so I could have him freshen it up pretty cheap.
Anthony
Old 02-22-2011, 06:43 PM   #8
Clyde65
Clyde65's Avatar
Re: budget swap?
I understand where you coming from
I am a computer tech, so if I can doit....ANYONE can!
I will agree with BR3W, if your going 4.8, then a few hundred more for a 5.3 just makes sense. I got my eng/trans combo with 9K miles for under $1200, you just cant find them that cheap anymore.
This was my exact reason for jumping onto the LS bandwagon. IF I did the crate motor and or a rebuild, I would be at least into it $3500, so this was a fun/frustrating attempt for me.
Just 1 word of advice, get the performance tune and the custom harness, it is very much so worth the headache of doing it yourself. Having the stock converted is not going to be as visually pleasing as the custom, just doing the VATS removal and rear O2's is about all that the cheap tuners do, if your in a pinch, go ahead, but when $ allows, go performance tune. I know, I just did it, love it!
Clyde65
Rebuild of Clyde
support our troops!
Old 02-22-2011, 07:55 PM   #9
68c10owner
68c10owner's Avatar
Re: budget swap?
I`m not too worreid about the harness since I`m not the one thats going to be doing it, lol. I just need to keep it within the smog laws for cali so if a performance tune smogs ok then I`m ok with it otherwise a stock tune will do as well. I say 4.8 or 5.3 because either one will serve the purpose. I just don`t want or need the 6.0 with the 4L80E. Just a simple install for me. I`d even consider a Vorted 5.0 or 5.7 engine. I had the 5.0 in a old ex-cab and it actually ran better than any other 350 I had at the time.
Anthony
Old 02-22-2011, 09:54 PM   #10
harnalien
TruckincrazY
harnalien's Avatar
Re: budget swap?
I would go with a 5.3 just so you get more displacement and don't regret it 2 months after your swap. Budget, what's that? I had a budget of 3K for my 6.0 swap, but rapidly surpassed that. It's the little stuff that gets you (o2 sensors, block off plugs, various nuts and bolts, etc.). I just got my wiring harness in the mail only to find out that the o2 sensors and iac motor i ordered are different than what the instructions say i need. hopefully i can get those returned and get the right parts. Frustrating, but hopefully it'll all be worth it.
My build thread - '84 2wd w/ a 6.0 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=433595
harnalien is offline   Reply With Quote
Old 02-23-2011, 05:38 PM   #11
Clyde65
Clyde65's Avatar
Re: budget swap?
I am not sure about Cali law but if I am not mistaken, you have to follow the year of the motr for smog and junk. a 4.8 will get you about 300 horse at the flywheel, a 5.3 will get you about 350 or so. 4.8's can be had around here for $500-750 depending on mileage. 5.3's will set you back 1500.00 plus depending on mileage.
If you go local, ask for the entire exhaust from the rear o2's forward, when you get a tune, tell them the cats and rear O2's are there, this is a reasonably easy swap. your right the electronics( harness) and the fuel sys is the hurdles but it isnt that bad. Good luck 68c10.
Clyde65
Rebuild of Clyde
support our troops!
Old 10-08-2017, 04:54 PM   #12
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: budget swap?
Anthony;
Are there any do's or don'ts or "budget" things you've learned since starting your search on this topic?
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
