02-23-2011, 09:34 AM | #1 |
Fiberglass cowl hood problems
HELLO GUYS
HAS anyone had this problem with there hood and how did you fix it ? the problem is the back of the scoop hits the windshield when you raise The hood up If you had this happen to you how did you fix it ? mine cracked The winshield plz show picuters if you have them Thank you Jeff M |
02-23-2011, 12:21 PM | #2 |
Re: Fiberglass cowl hood problems
If you don't wanna cut up the cowl you might have to use hood pins to hold it down then completely remove it when you wanna open it... the only other thing i could think of is to put like some roller thing that would allow the hood to open then you pull it towards you then up so it puts more space between the hood and the windsheild
84 K20 Long Box W.I.P 78 Burb - parts now [Rolled] 68 c20 dump bed WHEN IN DOUBT--- FLOOR IT |
02-23-2011, 12:51 PM | #3 |
I cant see it in your avatar but I'm assuming its to tall or the rear tail is to long or who ever installed it put it to far back
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG |
02-23-2011, 01:04 PM | #4 |
Canadian Trucker
What kind of hood is it? Was it designed as a pin hood, or hinge hood? Hoods that were designed to be pinned down sometimes have a longer cowl then the hoods designed to be hinged, because it won't matter if it interferes with the windshield.
2020 Silverado Trail Boss - 6.2/10spd |
02-23-2011, 08:34 PM | #5 |
truck addict
suicide hood would solve that problem.. i have done it to many trucks using stock buick skylark hinges.. with a c10 hood you have to cut the crossbar and extend it. then just fab up some hooks for the back of the hood and figure out where you need to add a bushing to lock it in place when closed..
trucks |
