#76 |
Re: West TX Z build up thread
Truck looks great I like the rallys , should run great with the new 350 update
my build 77 gmc shortbed big block, http://67-72chevytrucks.com/vboard/s...d.php?t=438237 |
#77 |
El Mero Mero Frijolero!!
Update: The mechanic is in Cancun with his family for spring break.....no biggie for me. Anyways, picked up my old set of gauges that I had planned installing in the Camaro..... Now will go in the truck.
My Toys: 1993 Ford Mustang LX 5.0 2001 Yamaha V Star 650 1984 Silverado > Build Page < |
#78 |
I have the matching tach already but its much-much bigger. I'm debating on using it but I would rather have both the tach and speedo the same size. Opinions?
My Toys: 1993 Ford Mustang LX 5.0 2001 Yamaha V Star 650 1984 Silverado > Build Page < Last edited by West Texas Z; 03-17-2011 at 04:10 PM. |
#79 |
Hopefully when all said and done it should look like this:
![]() ![]() I already have the aluminmum panel. ![]() thanks to http://www.73-87.com/ for the pics and idea
My Toys: 1993 Ford Mustang LX 5.0 2001 Yamaha V Star 650 1984 Silverado > Build Page < Last edited by West Texas Z; 03-17-2011 at 04:49 PM. |
#80 |
![]() Join Date: Jul 2010
Same size tach & speedo looks better...
#81 |
I made a mistake (well not really a mistake since I already had them) but the dash panel calls for 5" Tach and 5" Speedo...... and I have a 3 3/8" Speedo. As seen here in this picture. It looks like I will have to purchase a 3 3/8" tach to match it now because the tach in the Camaro is monster 7-8" tach I believe. ITS HUGE. haha great.
![]() One more thing, the other gauges (fuel, volts, vac, and oil) are 2 5/8" gauges....its going to look close in my opinion. I hope it comes out okay.
#82 |
Ya, I just ordered the Auto Meter Pro Comp 5161 Tach to match.
#83 |
Today I get the matching tach from Fedex. Pics to follow.
#84 |
Getcha Pull
So how are you going to make up for the smaller gauges? 5" gauges fit perfect with those accent panels. I have a pair of Pro Comp's for mine. 5" with 2" 5/8" is butter to me.
'81 K10 454/SM465 '86 S10 Blazer '95 H-D Softail '96 Integra |
#85 | |
#86 |
Getcha Pull
I do believe the widest part of the 3.375" gauges is 3.75". What if you used some aluminum plate and took a 4.5" hole saw and cut out a disc. 4.5" just so happens to be the diameter of the first step in our factory dash. Then take a 3.375" hole saw and cut the center out of the disc for the gauges to slide into. Do that, and use some aluminum strip to make the gauge clamp to the back of the dash and it will hold the gauge, and the disc in place.
Just a thought. Would be cheaper then getting a new accent panel made, you can do it yourself, and would have a added benefit of putting your tach, and speedo at a slight angle for easy viewing. Also, do you have a speedo cable in mind? The factory clip on cable doesn't fit the screw in Autometer speedo. I know there is a guy who sells the proper cable on ebay for like $15. I need to order one.
#87 | ||
I'm a little confused on what you mean. Are you saying that I would use the my same aluminum panel? Would the gauges be recessed or front mounted on my dash? Thanks for the response. ![]()
#88 |
Getcha Pull
Yeah, I'll PM you the link, and send a couple pictures of my idea.
#89 |
Altec, thanks for the pictures and link!! Its a great idea and it would work for almost no major mods at all. But after some serious thinking, I'm going to have a custom dash cut for my truck. I'm having a guy from PA cut me a custom piece tailored for my gauges.
First pic is the original pic and second one is a crappy ms paint pic that I crapped up for a mock of what I would like built. I'll keep you posted. And for those asking about Radio, Heater and AC holes and vents? Not using them.
#90 |
This is the stuff he builds. Just an example.
#91 |
Damn, thats sick. what guy in PA??!!
#92 |
Getcha Pull
That should look good!
#93 |
Well give me a few days to see if he wants his information blasted over the net. I'm still in talks with him building this piece for me. I'll let you know as soon as I hear something.
![]() Thanks. ![]()
#94 |
I was searching the net and came across this dash. It appears he is using the same size gauges as what I will be using. Worst case scenario if the dash builder is not able to fab something up for me, this will be the route I can go. Opinions?
My Toys: 1993 Ford Mustang LX 5.0 2001 Yamaha V Star 650 1984 Silverado > Build Page < Last edited by West Texas Z; 03-28-2011 at 11:36 AM. |
#95 |
Getcha Pull
'81 K10 454/SM465 '86 S10 Blazer '95 H-D Softail '96 Integra Last edited by Altec; 03-28-2011 at 02:39 PM. |
#96 |
the speedo and tach are smaller like 3 3/8" yours look like they are 5" and the others look like they might be 2 5/8"
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG |
#97 | |
No, mine are 3 3/8" and 2 5/8" as well. That's the whole dilemma about this dash situation. I should have bought the 5" but it looks like its still doable with the smaller tach and speedo.
#98 |
Getcha Pull
#99 | |
#100 |
nice work man i like your 84
Project 82 ReBoRn http://67-72chevytrucks.com/vboard/s...d.php?t=441842 |
