WTB: 64-66 headlight, engine wiring harness
I'm looking for a headlight wiring harness, engine wiring harness and the harness that goes from the cab to the headlight harness at the front radiator support. This is for a 1965 with gauges and not warning lights. Thanks
![]() Join Date: Aug 2004
Re: WTB: 64-66 headlight, engine wiring harness
are you on a serious budget? I ask because these are available through many vendors here on the board. also Classic Parts is a good place to shop alos.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
I have the headlight harness off a 65 or 66 Big truck, which should be the same as the smaller ones. Will get a picture for you. $25 shipped work for you?
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3 |
No, I'm not on a real strict budget, but I'm going to end up hacking both harnesses up for a motor swap. I don't want to spend much money on something that ill be almost completely rewiring anyway. Although i did find the engine harness for a reasonable price. So i may buy that harness new. As for the cab to rad support and headlight harness they want a good deal more.
Does that come with the cab to radiator support harness too? Get me a pic I'm interested either way. Thanks
It comes with the plug, but the wiring rubbed through on the radiator support from an aftermarket horn that was added. There is a 65 C10 here though I can check to see if I can grab it from. Probably would be about the same price.
