Old 07-08-2003, 05:41 PM   #1
WB72
Before and After
WB72's Avatar
95 Vortec heads / 7004R
Are 1995 steel Vortecs any good? I can get a set rebuilt for $ 500 Canadian. Are there any good casting numbers that I should look for?
What are the valve sizes?
What is the Max Lift for the stock springs?
What year and model of 700R4 should I be looking for?
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 07-08-2003, 06:11 PM   #2
bigjimzlll
bigjimzlll's Avatar
1996 was the first year of the good vortecs
10239906...96-up...350.........."Vortec 5700", "L31", 64cc chamber,
170cc intake port, 1.94"/1.5" valves
12558062...98......350..........L31 Vortec, truck, 64cc chambers, 1.94/1.5, 170cc intake port
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 07-08-2003, 07:42 PM   #3
lukecp
Formerly yellow72custom
lukecp's Avatar
Max lift is a debated issue....some sources say .450", others say .470"-480". Myself, i have no clue what the max lift is, but i would proably stay it safe and run about .450" or less.
For your 700R4, i would look for a '87 or newer model. In '87 they made alot of changes to the tranny, and beefed it up quite a bit. The older modles are supposed to be weaker and more finicky. They used the 700R4 up to '93 i think, and some models were called the 4L60. After '93, the tranny was converted to computer operation and became the 4L60E.
Good luck!
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
