Old 02-25-2011, 05:02 PM   #1
LT1 Burb
LT1 Burb's Avatar
Front bumper question
I am wondering what the difference is between the 60-62 front bumpers and the 63-66 bumpers. I bought NOS front bumper guards (part#985502) and want to make sure they will fit 65's.
LT1 Burb is offline   Reply With Quote
Old 02-25-2011, 05:10 PM   #2
steverino66
Re: Front bumper question
I was told the bolt hole position/pattern is different
steverino66 is offline   Reply With Quote
Old 02-25-2011, 05:29 PM   #3
Clyde65
Clyde65's Avatar
I believe the 60-62 frames are a little wider than 63-66.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-25-2011, 06:32 PM   #4
LT1 Burb
LT1 Burb's Avatar
The reason I ask is because they don't fit my repop 66 bumper but they fit on my 65 bumper. Also the instructions show they go at the frame location w/o drilling the bumper, is this correct for 64-66.
Old 02-25-2011, 06:35 PM   #5
Clyde65
Clyde65's Avatar
I am not sure where you bought your bumper guards but LMC clearly states their BG's only fit OEM bumpers.
Clyde65
Rebuild of Clyde
support our troops!
Old 02-25-2011, 07:49 PM   #6
markeb01
Senior Enthusiast
markeb01's Avatar
The mounting holes are closer together on the 60-62 guards vertically compared to the later frame. The bumper mounting holes on the later frame are farther apart vertically because the frame rails themselves are taller than the earlier design. If you’re going to mount them outboard of the bumper bolts the guards will probably interchange, although I don’t believe any NOS guard will fit on any reproduction bumper.
The “correct” placement is subject to interpretation. The 1960 Chevy Accessory Installation manual shows them mounted over the bumper bolts:
However the instruction sheet and template that came with my NOS guards 20 years ago shows drilling holes 3” outboard of the bumper bolts:
I have no information on GMC, but assume they were meant to be installed outboard of the bumper bolts since placing them over the bumper bolts visually blocks the G&C grille letters.
Old 02-25-2011, 09:58 PM   #7
LT1 Burb
LT1 Burb's Avatar
Can anyone with a 60-62 measure the distance vertically between there bumper bolts, mine are roughly 4-3/4 center to center on my 66.
Old 02-26-2011, 08:55 AM   #8
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
I am pretty sure that the 60-62 bumper is a little different shape than the 63-66, I think the ridge is lower and sticks out a little more
Old 01-01-2013, 05:28 PM   #9
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Did anyone ever get a vertical measurement of the bumper mounting hole placement for the 60-62 frame versus the 63-66 frame?
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 01-02-2013, 01:17 AM   #10
LostMy65
LostMy65's Avatar
I found the answer in this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=536716
