#1726 |
![]() Join Date: Jan 2008
Re: What did you do to your truck today!
Got the engine back in and running Tuesday night, took it for about a mile ride and put it back in the shop. Wednesday, took the complete rearend out, trailing arms,shocks and springs, and trailing arm crossmember. Today, I mock it all back up with the Porterbuilt crossmember and trailing arms, figure the coil-over shock mounting setup, make a template for the C-notch, and get stuff ready for powdercoating! That's about it!
#1727 |
![]() Join Date: Aug 2009
let it warm up and pulled the poor thing outside in the freezing cold.... my poor truck now its prabably upset with me... We got so much snow it had to come out to put the wifes convertable camaro away...
Sounded so good yesterday i had to go out and warm it up and move it around some more... giggle giggle like a kid with a new toy... Last edited by bigdogboxers; 02-24-2011 at 08:08 PM. |
#1728 |
Got my 2/4 drop installed. This weekend I will have the exhast all done. I will post pic's. It was a bit of wind so when I will get new pic's when it gets better outside.
----------------------------------------------------------- Erik My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626 1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647 RUST!? Thats just mother natures way of telling all of us.....MINE!!!! |
#1729 |
RAT1968 '68 Cab/'71 Parts
It's cold around here. I just stopped by the shop for a minute (at my daughter and son-in-law's place around the corner)
and installed the new air cleaner the Little Woman gave me for Hallmark Valentine's Day. It's coming along. Another six or ten years, I should be done.
M17 Coarsegold, CA RAT's shiny now. But always a rat. Last edited by magwakeenercew2jh; 02-24-2011 at 06:45 PM. |
#1730 |
Sofa King Crazy!!
^^^ That looks great!!
I put my new headers on today!
You found the Tater. ![]() My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. ![]() 1972 2wd Blazer "Porterbuilt and Sloshed" ![]() |
#1731 |
C/10 junkie
^^^ Hey brand and part number are those headers? They look awesome!
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
#1732 |
It looks like Slick67 and I have the same headers. I got mine when I bought the truck and an extra cab as a "pile 'o parts". So I don't know the brand. I DO know, with my set up, I had to notch the frame just a tad for clearance.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
#1733 |
the wiring inside my truck under the dash, and charged my battery.
chevys the way to go. ![]() ![]() |
#1734 |
Cruzin
installed a fan shroud on the 67
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
#1735 |
Installed the front sway bar with ECE drop mounts and polygraphite bushings. Very nice and easy with TXfirefighers FAQ. Worked on the rear drums. Got one side done. I will finish up the other side tomorrow. Then I will be done with these PITA drum brakes.
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
#1736 |
laying low
![]() Join Date: Mar 2001
That engine is gonna be sharp Magwa.
#1737 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
I covered mine is dust but the weather looks pretty good so maybe I can get the dual electric fans installed.
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#1738 |
Finished the rear brakes, buttoned her up and drove her down to the local shop for a full alignment. My two boys drove with me and they loved it. It really does handle 100% better with the new springs and a swaybar.
#1739 |
started to make a frame for my cab..
my build thread -- (http://67-72chevytrucks.com/vboard/s...d.php?t=438604) |
#1740 |
Old Skool Club
![]() Join Date: Jun 2001
Got my chassis completely ready to go to the sandblaster. Whew! Gonna send the cross-members (engine and trans), the trailing arms and the control arms (U & L), too. Pix, later.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
#1741 |
went to load fresh pics of my new 3/4 ton to my album and found out I no longer have an album. cheers, Pat
#1742 |
yes, i do
pulled the bench seat out so i could look at the gas tank so i know what line i need to modify for my tpi conversion and make room for my buddy buckets that will be going back in. i also siphoned off about 4 gallons of gas to put in my tahoe since its running a tad low. here's a photo of the driver's floor pan. also can anyone tell me what these lines do or what they are for??
ERROR 404....... SNAPPY COMEBACK NOT FOUND ![]() _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
#1743 |
yes, i do
oh and i found the gas pedal pad under the old bench seat so i reinstalled it on the gas pedal
#1744 |
Finished welding up the c-notch, and boxing that rear section.Welded lower coil-over shock mounts to the rearend, and installed top crossmember and upper shock tabs. Realized I'm going to have to modify Porterbuilt crossmember for driveshaft clearance. That's it for today.
#1745 |
Got my dash panel sanded and primed along with the glove box door and reattached it, did a little slicking to the roof, looking to shoot total cab this week.
"" ![]() My restoration video....... http://www.youtube.com/watch?v=tU9fhHcDivs |
#1746 |
sharp as a marble
![]() Join Date: Jan 2007
Well, I drove my Blazer today!! Had a place to go, and drove my old girl about 75 miles. Trouble free, and the country music just a KICKIN! I had a great ride.
#1747 |
Finished a week's worth blazer fun:
Installed new intake Installed new (rebuilt) quadrajet Installed new heate core Finally installed new glovebox. (hadn't had one in years) Funny thing is I got it all done and it even runs.
Jeremy (NUBOMB) 72K5 CST 350/350/205 1951 Chevy 1/2 ton North Georgia Group "... And the first rule to being a man is you gotta spend your life doing crap you don't wanna do." Red Forman. |
#1748 |
Took out the clutch in my '67 C10 and found a 9" disk with a 10" plate. Doh
#1749 |
I buttoned up the rear end cover and added new oil (pics 1/14 before, 2/26 after). I've been able to determine that I have an Eaton H052 with a 4.10 gear ratio mostly by searching the Forum archives. One good thing about leaks, they act as an excellent applier of rust preventative to external surfaces.
Then I installed a new shock absorber on the passenger side cuz I had left it for later and later was today. Then I put 2 1/2 gallons of gas in the tank. Then I installed a new PCV valve and cleaned out the flame arrestor and crankcase vent hoses. Then I found all the air cleaner parts I had stored away and cleaned them. Then I washed away most of the crud around the fuel pump and removed all the mickeymouse fuel lines from the outlet of the line from the tank to the carb. I found no fuel filter, kinked steel lines, swollen rubber, patchwork hose clamps and so on and so forth.
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
#1750 |
well i cleaned the bed out scrubbed some mold off the paint and drove it... wish it was wrmer i need to put plugs and wires in it too.
