Old 02-26-2011, 05:48 PM   #1
52MercRR
Electrical Issues!!!HELP
My son has a '72 C10 SWB. The dash, brake and tail lights quit working. I printed off the electrical diagrams from this site(Thanks). I have no power on the fuse block upper right fuse. This looks to come from the connector for the dash assembly(gray wire). What I can't tell is where this power originates from. I can't find anything that tells me how circuits are switched. The drawings show multiple wires from the light switch, but not how they are controlled through the switch, i.e. N.O., N.C., which wire connects to which at each detent of the switch when activated. Can anyone shed some light on this issue? Any thoughts are appreciated. Thanks.
52MercRR is offline   Reply With Quote
Old 02-26-2011, 06:57 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Electrical Issues!!!HELP
You checked the fuse? I think the one you say has no power is the dash light fuse. It gets fed off the tail light fuse.
If you check the electrical forum, in the FAQ thread, you'll find a photo of a fuse box that has been labeled.
Assuming I am right, once you install a new fuse, it'll probably blow. You'll need to take note of exactly when it blows to help figure out whats actually wrong.
Old 02-26-2011, 09:25 PM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
See this thread and it should be able to answer all your questions.
http://67-72chevytrucks.com/vboard/s...d.php?t=416018
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 02-27-2011, 12:53 PM   #4
52MercRR
Smile Re: Electrical Issues!!!HELP
Looked at continuity check for light switch posted by Fixit P, my switch ohms different. Headed to Autozone to try new switch(already replaced twice). I will ohm the new one in the store with Fluke multimeter before heading home. Thanks for the information sharing. I'll post response later.
Old 02-28-2011, 09:03 AM   #5
52MercRR
Finally found short on brown wire going to front side marker lights. Thanks for all the input.
