Old 01-13-2011, 03:50 PM   #51
ms2335
ms2335's Avatar
Re: LS swappers, post up your pics!!
About to get my 2002 5.3 ready to go back in the truck.
65 Chevy C10 Short Fleet BBW 6.0L/4l80E
68 Chevy C10 SWB 6.0L/4L80E
84 Chevy C10 SWB 5.3/4l60E QA1 Suspension
ms2335 is offline   Reply With Quote
Old 01-23-2011, 11:10 AM   #52
rob32472
Here is a pic of my swap....
rob32472 is offline   Reply With Quote
Old 01-23-2011, 07:31 PM   #53
rob32472
The pic is a bout a month old I have added the three piece engine cover and is really looks good will post some pics when I can......
Old 01-25-2011, 11:43 PM   #54
RocketKing
RocketKing's Avatar
Before
After
Rex
RocketKing is offline   Reply With Quote
Old 01-27-2011, 11:28 AM   #55
RocketKing
RocketKing's Avatar
Originally Posted by Puglia10 View Post
looks great! what steps and products were used?
I cleaned nearly every thing with Purple Power, water, soft bristle scrub brush, rag and elbow grease. It was amazing how well it cleaned, just don't leave it on too long before washing off with water.
I used Duplicolor Chrysler Silver Met. on the water pump, a/c, pulleys, tranny and accessories.
I used the high heat Duplicolor primer on the engine and then ordered Corvette Torch Red in a aerosol can, then finished up with high heat clear gloss for the shiny.
I used Rustoleam Industrial Semi-Gloss black on the metal parts and gloss black paint made specifically for plastics...I will get the name and edit later.
I used a flat black high heat for the exhaust manifolds, can't remember the name...maybe VHT or something like that.
All of the paint was bought off the shelf from O'Reilly with the exception of the Torch Red which they ordered for me and had the next day.
Gotta be careful witht the GM colors special order spray cans, the paint flows reeeal thin. Better to take your time with multiple coats to avoid runs. IMHO
Rex
Old 01-29-2011, 12:03 AM   #56
RocketKing
RocketKing's Avatar
Originally Posted by mac72 View Post
If you find time I'd like a couple looking straight down at them thanks in adv. Mac
Here ya go...
Rex
Old 01-29-2011, 10:06 PM   #57
RocketKing
RocketKing's Avatar
Thanks & your right about that left one being tight at the heater hoses.Can you tell me what yr & model those manifolds came from?
They are 2000 Trailblazer SS
Rex
Old 02-04-2011, 01:51 PM   #58
85burb
85burb's Avatar
Got her in new home. Running and drivin. Still have to tune and clean up wireing but am daily drivin. Even in snow today. That was fun. Even idled cold in gear buy it self. I love the looks i get at stop lights....think the truck shaking my scare them.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 02-11-2011, 11:45 PM   #59
awhite4557
awhite4557's Avatar
1971 Chevy SWB, 2001 5.3 / 4L60E, CPP motormounts / adapter plates, sanderson headers, speartech tune/re-wire.
1950 Chevy 3100 Ramp Bed 1-ton
http://67-72chevytrucks.com/vboard/s...d.php?t=749386
1965 Chevy Step Side
1971 Chevy Short Wide Bed
http://67-72chevytrucks.com/vboard/s...d.php?t=277191
1971 Chevy C-30 1-ton
1971 Chevy Chevelle
1972 Chevrolet C-30 1 ton
2005 Dodge Ram 2500 5.9 Cummins
2017 Fleetwood Pace Arrow 35M motorhome 350 Cummins
2020 Jeep Wrangler Unlimited Rubicon
awhite4557 is offline   Reply With Quote
Old 02-15-2011, 05:59 PM   #60
Hart_Rod
Hart_Rod's Avatar
My new one, LS1/T56...
Hart_Rod is offline   Reply With Quote
Old 02-24-2011, 01:19 AM   #61
shrunken66stroker
shrunken66stroker's Avatar
Here's mine. It's only mocked up at this point but it will be an LS2/Tremec RS500 when it's done.
shrunken66stroker is offline   Reply With Quote
Old 02-25-2011, 10:54 AM   #62
eagleuh1
eagleuh1's Avatar
Mine, 68 C20 with 2005 5.3 and 4l60e. I think the truck intake is pretty, with its makeup on. It does its job just fine, so its not getting changed. HartRod, your building a nice collection of 67-72's. Like this one too.
eagleuh1 is offline   Reply With Quote
Old 02-26-2011, 07:31 PM   #63
60apache
60apache's Avatar
finally got mine done
60apache is offline   Reply With Quote
Old 02-27-2011, 12:14 AM   #64
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
eagleuh1....what hose fitting is that you are using for the steam line to connect to the heater hose?
looks good 60apache! What accessory drive/compressor backet is that?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 02-28-2011, 11:22 PM   #65
60apache
60apache's Avatar
qwikperf.com sanden
Old 03-01-2011, 08:33 PM   #66
eagleuh1
eagleuh1's Avatar
Its a flush and fill tee, that I drilled a hole in and forced a barbed hose fitting through and jb welded to seal it to the cap. I can take the cap on and off the tee, hose is held on with FI hose clamp. This goes in one of the heater hoses up high on the inner fender. Works good for cheap fix.
Old 03-02-2011, 04:54 PM   #67
68GMCCustom
my radiator had a extended fitting (out about 1.5-1.75in) on my 4 core radiator on the rad cap side, just above (or below, can't remember) the top trans cooler line. I opened it up and when I shine a light into the hole I can see it on the front side of the radiator so its going straight into the main portion of the radiator and not the trans cooler. It took a 1/4" NPT fitting as I recall. Anyway...my steam vent line is now plumbed to the radiator at a point higher then the fittings exit from the motor.
and fyi....on the LS2 in our TrailBlazer SS, the steam line attaches to the radiator line as yours does...though it is to a T in a metal pipe, like an a/c hose...thats well below the steam vents exit near valley pan level.
Kurt -
Old 03-02-2011, 09:17 PM   #68
85burb
85burb's Avatar
That is the same place i put mine. Also the same place the 07 chevy Z71 4x4 i used to drive for work put the steam line right from the factory.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 03-21-2011, 11:18 PM   #69
nacho55
I like them all it Looks like some very clean swaps you guys have done. I have a question has anyone used solid mounts to mount their motors or transmissions I built some for my ls swap but am reconsidering now that i have the motor back out from the mocking up proccess on my ls/s10 55 truck project.
nacho55 is offline   Reply With Quote
Old 03-22-2011, 09:42 PM   #70
52 Rat
52 Rat's Avatar
Here is a link to my build project. I went with a lq4 6.0L and a T56 six speed.
http://67-72chevytrucks.com/vboard/s...d.php?t=418432
My build project http://67-72chevytrucks.com/vboard/s...=1#post4158671
52 Rat is offline   Reply With Quote
Old 03-23-2011, 12:34 AM   #71
tre5
tre5's Avatar
What is that billet piece behind the throttle body and where did you get it. The motor I have has an open hole right there and I need to get that piece.
Follow me on facebook and Instagram. Tre 5 Customs
My '49 http://67-72chevytrucks.com/vboard/s...d.php?t=673809
Customer build: 67 Blazer Roadster http://67-72chevytrucks.com/vboard/s...d.php?t=443105
Customer build 1980 C10 http://67-72chevytrucks.com/vboard/s...49#post7210949
tre5 is offline   Reply With Quote
Old 04-08-2011, 04:15 PM   #72
jb1016
"Oh well, it's a driver."
jb1016's Avatar
HR, you got a build thread for this one? Or are you just driving it?
Old 04-08-2011, 05:53 PM   #73
Hart_Rod
Hart_Rod's Avatar
I haven't started one yet, but plan on it soon. I purchased the project from another boardmember who had done most of the work to it. I plan on pulling it back apart and finishing the chassis and then putting it back on the road.
Old 04-09-2011, 01:10 PM   #74
jb1016
jb1016's Avatar
Cool, I'll be all over that. I'd give my left....uhh, pinkie....to have an ls/6-speed combo.
Old 04-09-2011, 11:51 PM   #75
68GMCCustom
OK...its finally all together (but never finished).... so here's the "semi-final" pics.
'09 LY6 crate motor (new) with VVT removed and a cam/springs/p-rods upgrade, GMPP LSX intake, Holley 750HP Street, MSD 6LS-2, Dynatech '70-'81 Camaro 1 7/8"x3" LSx swap headers, built 2500 stall 200-4r, and more:
Kurt -
