Old 02-27-2011, 01:51 AM   #1
Btc10
Oil pump screen installation
I bought a new melling oil pump for my 1970 chevrolet c10 350. Can somebody tell me how to install the screen on the oil pump properly?
Btc10 is offline   Reply With Quote
Old 02-27-2011, 09:45 AM   #2
truckdude239
truckdude239's Avatar
Re: Oil pump screen installation
what i do measure my oil pan to the deepest part from the matting surfaces then using a measure tape and straight edge, measure fromt eh matting sureface on the bock i set my oil screens about 1/2 off the bottom of where the pan would be
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 02-27-2011, 10:44 AM   #3
Ticker
Here's the way I do it; right on, every time.
http://67-72chevytrucks.com/vboard/s...95&postcount=3
Ticker is offline   Reply With Quote
Old 02-27-2011, 07:31 PM   #4
crazy longhorn
Fabricate till you "puke"
I like 3/8" clearance tween the pickup & the pan, & I dont like press tubes. I have only seen 1 fall on the street, ....but it cost the dude a fresh motor.I like to sand a little clearance on the tube , for a snug but slip fit, then set the depth,pull the cover off as well as remove the spring & bypass. I dont tack weld.....warm it up with a torch, & weld the tube solid with a nickle rod in your stick welder. After it cools, resurface the cover, clean & reassemble. its for sure a little overkill, but I have run the same (Z28 pump), on 4 or 5 fresh motors, with nothing but a resurface & end play check(.0025 on the end play should get you there). CrazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-27-2011, 08:01 PM   #5
Ticker
I have never seen a pressed pickup come out unless a) it was a used pickup and/or pump or b) it was not installed correctly.
If someone's worried about it, it's a lot less work to just buy the Melling Select pump for a few bucks more with the bolt-on pickups. A quick braize is also fine if you feel like you gotta.
Old 02-27-2011, 10:50 PM   #6
cableguy0
I got an engine for free that was practically brand new because the pickup fell out of the pump. The last pump I installed the pickup practically fell into the pump. This was a 98 tahoe with vortec engine. All brand new melling stuff. I always run a good tack weld and they wont ever move. Just makes me feel better.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
