Old 12-08-2010, 12:57 PM   #1
way2lo2
way2lo2
way2lo2's Avatar
Corvette C6 ZO6 Calipers and Pads New Front and rear $1200
$1200 This is a full set of brand new 6 piston front and 4 piston rear Calipers and pads.
The pic I've added is an identical front setup that I did on a drop spindle for 71-72 truck. You will be getting for brand new, never used , never mocked up, brand spankin shiney new!!!
way2lo2 is offline   Reply With Quote
Old 12-08-2010, 01:09 PM   #2
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: Corvette C6 ZO6 Calipers and Pads New Front and rear $1200
I might be interested pending the knowlege on how you made them work on a 71-72 spindle.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 12-08-2010, 01:26 PM   #3
way2lo2
way2lo2
way2lo2's Avatar
pretty simple actually, cut the caliper mount off, milled the back of the spindle flat, drilled and tapped it for a bracket. I used readily available and inexpensive aftermarket hubs.
Old 02-27-2011, 12:56 PM   #4
Joemomma1
Joemomma1's Avatar
Do you sell a kit for just the front?
Joemomma1 is offline   Reply With Quote
Old 06-26-2011, 05:39 PM   #5
kvn1011
Kvn1011
kvn1011's Avatar
i
bump,
just curious on front kit, also
kvn1011 is offline   Reply With Quote
brakes, calipers, corvette, z06, zo6
