Old 02-27-2011, 07:23 PM   #1
Boog
laying low
Boog's Avatar
hooking up the 4L60E
I have my wrecked 97 GMC with good engine/trans, etc. I have my 69 stepper with a new engine but needing a trans. So I've been thinking about using the good trans from the 97. It has to have a controller so I've looked into aftermarket units and frankly they are too expensive for me. I cannot see spending well over $1000 just to make my used tranny operational. Is there anyway to use the factory stuff and rewire it to work? I've done a lot of thread searching and haven't come up with anything yet.
I have never wanted any electronics on my 69 but I want to keep the 4.10 gears so I've been considering the OD and since I have a good one already..
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 02-28-2011, 10:54 AM   #2
Clyde65
Clyde65's Avatar
Re: hooking up the 4L60E
There is no way that I have heard or seen to do what you want w/o some controller of some sorts.
I would go for the trade if it were me.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-28-2011, 12:37 PM   #3
Fastfun
Fastfun's Avatar
I thought that the 4L60E was the same transmission as the 700R except that it was computer controlled and they have the same case.
Fastfun is offline   Reply With Quote
Old 02-28-2011, 04:37 PM   #4
MARKDTN
I thought you could use a diesel controller from mid 90s truck on this? I've not done it myself though.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 02-28-2011, 04:50 PM   #5
CSmith
Use a full manual valve body.
'69 GMC Stepside
'72 C10 Cheyenne Super
CSmith is offline   Reply With Quote
Old 03-02-2011, 12:59 AM   #6
Boog
laying low
Boog's Avatar
I remember mention of using a diesel trans controller in a thread a couple of years back but none of the particulars.
The thing is using the 4l60E you have to use a throttle position sensor along with a trans controller to make it work. Then there is the electronic speedo converter you have to buy also. Whereas the 700R4 has a TV cable and the only electrical is to the brake switch and lockup torque converter. Earlier 700's had speedo cable instead of the electronic pulse sensor. I think it would actually be a better choice for on older vehicle using a carb'd engine, costwise.
Manual valve body? I'm not sure how that would take the place of the electronics.
Boog
primer is finer
Old 03-02-2011, 02:06 AM   #7
Jerry Jones
Happy Camper
Jerry Jones's Avatar
Moved to Engine and drivetrain.
RIP El Jay! Love you brother!
Jerry Jones is offline   Reply With Quote
Old 03-03-2011, 12:18 AM   #8
Captainfab
60-66 Nut
If you don't mind doing the work, here is some info on building your own controller for the 4L60E/4L80E transmissions.
This thread was hijacked from it's original posting....
http://www.67-72chevytrucks.com/vboa...d.php?t=403384
Here is some more info......
http://mattw.dyndns.org/4L80E/
http://www.theturboforums.com/smf/in...topic=144245.0
There is more, you just have to search a little. Those will give you an idea what is involved.
And of course, as already mentioned you can use the OEM controller from a diesel truck that had a 4L80E
