Old 03-02-2011, 03:16 PM   #1
harold64
harold64's Avatar
wetter water
has anybody tried this new product? ive got to change my water pump and was wondering how good it is. its supposed to help drop your temps 40 degress. any help would be nice. hurry spring!
harold64 is offline   Reply With Quote
Old 03-02-2011, 03:39 PM   #2
bama63
bama63's Avatar
Re: wetter water
i have used this in my racecar and dually and saw marginal results,it only shows an eight degree Fahrenheit drop in a car with a 50/50 mix of water and coolant, and an eighteen degree Fahrenheit drop for a car running 100 percent water.for cars running straight water, WaterWetter provides some additional protection. This includes traditional coolant roles of reducing corrosion and lubrication of water pump seals. For cars caned on the track or driven in the summer only, a water-only engine and cooling system solution will lead to problems. However, for cars with a tradition 50/50 mix of water and trad coolant, these benefits are already present without WaterWetter
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 03-02-2011, 03:48 PM   #3
jchav62
1962 C-10
jchav62's Avatar
Re: wetter water
I used to run in the Nevada desert in my '51 pickup. We dropped a 350 in it with stock suspension. The fan set a little low on the radiator. It would get a little warm at stop lights and such. The water wetter helped it quite a bit...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 03-02-2011, 05:38 PM   #4
kieth
kieth's Avatar
Re: wetter water
Water wetter is not new, class 8 trucks require it, it makes the coolant flow better and keeps the coolant from boiling and turning to steam in the hot spots around the cylinders. In a big truck this boiling and turning to steam process leaches holes in the wet liners in each cylinder until eventually it eats through the wet liner into the combustion chamber. They have test strips that one can dip into the radiator every oil change , if it changes colors one needs to add more (DCA) water conditioner. It will not hurt a thing to have it in your truck but it will not drop the temp 40 degrees and you really do not want to drop the temp 40 degrees. If it is running really hot something else is wrong. Kieth
kieth is offline   Reply With Quote
Old 03-02-2011, 08:07 PM   #5
Rogue
Airport Bum
Re: wetter water
I have been using Liquid Kool for over 30 years, at the suggestion of some dirt track buddies.
Its like $3 a qt, I use it at every coolant change.
Living in Texas, i use a 70/30 mix ratio +QK, since we don't see frigid conditions.
It works great even in the OTM on the track.
(not point and shoot, I'm talking road coarse)
1964 Chevrolet C-10
1941 Chevrolet coupe
1962 Thunderbird
1959 Edsel Villager
1963 Skylark
Rogue is offline   Reply With Quote
