Old 03-02-2011, 11:00 PM   #26
87 V20 Scottsdale
87 V20 Scottsdale's Avatar
Re: How can i improve a lil bit on gas mileage
Is your truck 2 or 4 wheel drive? My 383 has been getting 10-12 mpg, depending on how it's driven.
Andrew
1987 V20 Scottsdale 383 TBI, SM465, NP208, 14FF, 4.10
1988 C1500 Scottsdale 305, 700R4, 3.08
1986 K30 Custom Deluxe 6.2, SM465, NP205, 14FF, 4.10
87 V20 Scottsdale is offline   Reply With Quote
Old 03-02-2011, 11:02 PM   #27
383Chevy
[><]Sofa King Dirty 4x4[><]
383Chevy's Avatar
You killed your mileage in the process of trying to find more. Switching to a 2bbl will almost always hurt gas mileage. Going to taller tires with a higher gear has you somewhere around the equivelant of a 2.73 gear. Your lugging your engine by having the rpms so low during cruise. Go back to the 4bbl and put some more gear in it. MId 2k rpms is where a small block likes to be. Lower rpms is not always better. If you were getting 14mpg with a 383 in a heavy truck you should have left it exactly how it was because that it real good mileage for one of these old pigs with the aerodynamics of a brick.
Prolly gonna hook the 4 back up tomorrow and find me some 3.73's
00' Chevy Silverado 1500 z71
33"s
3" lift
5-speed
Past trucks
85' Chevy C10 Step side
388 stroker
33" bfg a/t's
holley 670cfm
world product heads
14.80@92mph
92' S10/Tahoe sbc swap
383Chevy is offline   Reply With Quote
Old 03-02-2011, 11:02 PM   #28
383Chevy
383Chevy's Avatar
2 wheel
33"s
3" lift
5-speed
Past trucks
388 stroker
33" bfg a/t's
holley 670cfm
world product heads
14.80@92mph
Old 03-02-2011, 11:03 PM   #29
mongoose
mongoose's Avatar
'screaming' or not... fuel efficiency is about volumetric efficiency.. where your rpm's land is where they land 'screaming' is usually better than lugging around...
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 03-02-2011, 11:11 PM   #30
zackary027
zackary027's Avatar
i had a 83 swb with a hot sb 400 most the parst came out of my dads super street race car it had a high gear and 700r4 with a 4bbl holly 600+- and was able to get 15 must have just been that right combo of course when i got into it it would kill a tank in a hurry
zackary027 is offline   Reply With Quote
Old 03-02-2011, 11:13 PM   #31
383Chevy
383Chevy's Avatar
Well imma just hook the 4brl up gets 3.73's gears and still check for leaks just incase i appreciate it guys
33"s
3" lift
5-speed
Past trucks
388 stroker
33" bfg a/t's
holley 670cfm
world product heads
14.80@92mph
Old 03-02-2011, 11:24 PM   #32
mooseknuckles
mooseknuckles's Avatar
so you have a 2bbl 383, with a th350, 2wd with 33" tires and 3:23 rear gears? first put the 4bbl back on and give it a tune up, plugs, wires k&n filter, timing set prop. then change the tires to something normal say around 28". even 31's would be better than the 33"s. that should help some, then look for a 700r4.
mooseknuckles is offline   Reply With Quote
Old 03-03-2011, 01:58 AM   #33
pig rig
pig rig's Avatar
Originally Posted by 383Chevy View Post
So im an oxymoron? figured id post here so i wouldnt get bashed but its starting to look like it thanks for the help NOT i guess i wont post here anymore
no your statement was an oxymoron after reading all the post AFTER my post you give possible reasons why your truck is getting bad gas milage but prier to my statement all you said is you have a built motor and you dont understand why its not getting the same milage as a car that 2/3 the weight and one of the most aerodynamic vehicles gm ever built
and now with that said you pointed out one thing that needs to be fixed first. you said the filler tube hose has a crack in it
your sucking air in to the tank and you have an open system that works best closed with negetive pressure. its just like leaving the gas cap off
whats happening is your pump can suck MORE FUEL easier because it dosnt have the back pressure and by not having the back pressure it also creates a syphon
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 03-03-2011, 11:46 AM   #34
N2TRUX
Happy to be here
N2TRUX's Avatar
So im an oxymoron? ....
Just so you know...An oxymoron is a figure of speech that combines contradictory terms. Oxymorons appear in a variety of contexts, including inadvertent errors such as extremely average
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-03-2011, 03:40 PM   #35
383Chevy
383Chevy's Avatar
Right that will be fixed soon i dont have the money at the moment like i said i got it all figured out now because you guys helped thanks
33"s
3" lift
5-speed
Past trucks
388 stroker
33" bfg a/t's
holley 670cfm
world product heads
14.80@92mph
Old 03-03-2011, 04:25 PM   #36
blackbeaSSt
all you guys with 383's+ are making me feel bad about my 305 with a mild cam getting 9mpg
blackbeaSSt is offline   Reply With Quote
