Old 02-23-2011, 07:08 AM   #1
mtchevytruck
mtchevytruck's Avatar
Amp vs volts
Another question for the masses. Found a factory tach cluster out of a 73' with an amp gauge. Plan on installing it in my 77' which has a volts gauge. Will either work with the three wire alt. and is one more desirable than the other if I have the choice?
NW Montana
1977 C10 Bonanza short bed, 2wd
350/350, lowered 2", 10" Rally Wheels
Lots more needed.
1977 C10 Long bed, 2wd, less engine
Parst truck.
mtchevytruck is offline   Reply With Quote
Old 02-23-2011, 03:40 PM   #2
Fixwhataintbroke
Enthusiast
Fixwhataintbroke's Avatar
Re: Amp vs volts
http://www.73-87.com/7387garage/inte...achometers.htm
- Cole
1979 Chevy C30 w/ carb 454.
1992 Chevy K1500 w/ tbi 350. *Sold*
1997 Dodge Ram 1500 w/ Magnum 360 *Sold*
"Good judgment comes from experience. Experience comes from poor judgment." - George Washington
Fixwhataintbroke is offline   Reply With Quote
Old 02-23-2011, 03:59 PM   #3
silvereagle07
silvereagle07's Avatar
Re: Amp vs volts
Originally Posted by Fixwhataintbroke View Post
This kinda jumped out at me from this page...
1. AMP or VOLT gauge mix-ups could cause a fire.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 02-23-2011, 04:30 PM   #4
mtchevytruck
Re: Amp vs volts
Thanks for the info! Almost started the swap today from a 72' to a 77'. Hoping to build one out of two carefully.
NW Montana
Lots more needed.
Parst truck.
Old 03-02-2011, 07:33 PM   #5
mtchevytruck
Re: Amp vs volts
Got it done successfully! More differences in clusters than I would have thought. Volt and amp gauges are not interchangeable!! Amp gauge has, in layman's terms, full voltage running through it in a continuous stream of current. Volt gauge is more like other basic gauges with a power, ground, and a feed wire that fluctuates (more or less) either positive or negative.
NW Montana
Lots more needed.
Parst truck.
Old 03-02-2011, 07:49 PM   #6
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
Re: Amp vs volts
Yeah I asked about that a while back since I had been wanting to see the difference.....even though that cluster had a amp couldn't you just take out the amp gauge and put in a volt gauge? But yeah, from the responses amp gauges were a bad thing if you wanted to put in a new one...
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 03-02-2011, 08:07 PM   #7
Altec
Getcha Pull
Altec's Avatar
Re: Amp vs volts
I wouldn't let horror stories of people who didn't know how to properly wire a ammeter, or poor factory setups from the 70's set your opinion of ammeters.
I prefer a good ammeter myself. It can tell me the same thing a voltmeter will about my battery being low, and it will give me a better idea of my charging system.
Anything is better then a idiot light though!
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Altec is offline   Reply With Quote
Old 03-02-2011, 08:20 PM   #8
mtchevytruck
Re: Amp vs volts
Altec, I agree and was hoping on installing the amp meter instead of the volt meter, but would have had to do additional wiring in the harness and maybe a different alternator?
NW Montana
Lots more needed.
Parst truck.
Old 03-02-2011, 08:23 PM   #9
72lb4x4
Re: Amp vs volts
Ammeters causing fires in these trucks is pretty much a myth unless an aftermarket meter is installed.
In reality the GM gauge is measuring the difference in voltage at 2 points in the wiring harness. One point near the battery and one near the alternator. If the voltage at the battery is higher, the gauge indicates discharge. Higher at the alt, it indicates charge. The difference is in tenths or thousandths of a volt.
72lb4x4 is offline   Reply With Quote
Old 03-02-2011, 08:25 PM   #10
78 Chevyrado
Re: Amp vs volts
Volt meters connect to the hot wire and tell you the voltage present in a system. The volt meter is a closed loop all on its own and is built light since not much amperage runs through it at all
amp meters show you the amperage draw to the battery, which means ALL system current runs through the amp gauge. the amp gauge is inline with the main power wire. amp meters are built heavy because heavy current runs through them.
Volt meters are better IMO.
78 Chevyrado is offline   Reply With Quote
Old 03-02-2011, 11:48 PM   #11
Justins76
OutOfMyMind & I'llNeverKnowWhy
Justins76's Avatar
Re: Amp vs volts
Anyone know if 73+ trucks use a shunt type ammeter?
-Justin-Out of my mind and I'll never know why
1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed
1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6
1992 Pontiac Firebird T-Top 5.0L TBI 700R4
My cardomain page
I don't like to save, it's more fun to spend!!
Justins76 is offline   Reply With Quote
Old 03-02-2011, 11:50 PM   #12
Justins76
Justins76's Avatar
Re: Amp vs volts
This may be of help to you. Use your stock voltmeter and move the terminal post as show in the link.
http://67-72chevytrucks.com/vboard/s...highlight=tach
My cardomain page
Old 03-02-2011, 11:52 PM   #13
mtchevytruck
Re: Amp vs volts
I'm not familiar with the term shunt. From what i found 1973-75 used amp meters and 76-87 used volt meters.
NW Montana
Lots more needed.
Parst truck.
Old 03-03-2011, 12:08 AM   #14
mtchevytruck
Re: Amp vs volts
Good write up. Many years are different though. The 72' cluster did not have the upper terminal cut out in the plastic or have the printed circuit for a top terminal. What I had to do was cut the post off the back of the gauge that went to the left outer hole and I then inserted a double nutted screw with a terminal and wire attached to the back side of the cluster. Then I drilled a small hole through the white cluster case and ran the wire through to the upper terminal on the back of the gauge and nutted a wire terminal on to that. Works great.
I also had a seat belt warning light, brake warning light and oil warning light (and a 4x4 light option that wasn't used) on the 77' cluster and only a brake warning light on the 72' cluster. I just swapped the wires in the harness so the brake warning would function and left the rest alone eliminating them.
NW Montana
Lots more needed.
Parst truck.
Old 03-03-2011, 01:19 AM   #15
72lb4x4
Re: Amp vs volts
That's what I described in my earlier post above.
A shunt ammeter is actually a voltmeter. In fact, I've been told that a regular ammeter is actually a voltmeter but the shunt resistor is inside the body of the meter...
Old 03-03-2011, 09:57 AM   #16
Jonboy
Slots go on anything!
Re: Amp vs volts
I added a voltmeter to the '74 tach cluster in my '74. Scot had done this previously, I just added the tach cluster. The truck originally had a clock, so he used the clock wiring to the voltage gauge. You pull the metal tabs out of the instrument cluster carrier, so there is no contact with the printed curcuit. The tabs on the back of the gauge are threaded (10-32, IIRC), and just run the 12V+ from one side to the fuse block, and ground to the other side. There is a ground strip on the left side cowl panel that can be seen when the cluster is out, that's where mine is run to.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 07-22-2012, 05:39 AM   #17
Bigb401
Re: Amp vs volts
That's not true. These gm ammeters are shunted (in parallel) to the system current and charging system. All system current does not flow through (series) the ammeter
Proud to be IBEW Local 2150
Bigb401 is offline   Reply With Quote
