Old 03-03-2011, 07:41 PM   #1
ProStreet83C10
Drag Racer
ProStreet83C10's Avatar
Need to know max rear tire size specs.
Hey guys, im looking at buying a set of cheater slicks/racing street radials and id like to know the absolute biggest, widest tire and wheel combo i can run on the rear of my truck with a stock 8.5" 10 bolt rear end. I dont want to chop up the OEM wheel tubs just yet until im ready to do a full back half/tub
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
ProStreet83C10 is offline   Reply With Quote
Old 03-03-2011, 08:36 PM   #2
jrcaprai
Re: Need to know max rear tire size specs.
Is it a fleetside or stepside ?
jrcaprai is offline   Reply With Quote
Old 03-03-2011, 10:18 PM   #3
ProStreet83C10
Drag Racer
fleetside
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 03-03-2011, 10:29 PM   #4
3r!c84
Badass
3r!c84's Avatar
Originally Posted by ProStreet83C10 View Post
fleetside
what size rim?
im running 315/35/17 with stock tub. thats about as wide as will go. 1/4inch of clearance from tire to wheel tub.
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 03-03-2011, 10:37 PM   #5
mooseknuckles
mooseknuckles's Avatar
I have 28x12x18 M/T on mine, and if I had a 10" or 12" wheel and I could find the correct tire size I could prob get a couple more inches on there with stock tubs. you may be able to get a 18" wide tire on with the correct wheel size and offset and tubbed.
mooseknuckles is offline   Reply With Quote
Old 03-03-2011, 10:45 PM   #6
3r!c84
Badass
3r!c84's Avatar
is his truck lowerd ? mine is. and 12-13 inch wide tire is about the limit on width in the wheel tubs
-00 Saturn 5spd
1/4:13:90
Old 03-04-2011, 01:55 AM   #7
ProStreet83C10
Drag Racer
so......would i be ok running a 15x10 wheel with a P315/60R15 (30'' x 13.5'' - 15'')
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 03-04-2011, 07:41 AM   #8
73gmc454
73gmc454's Avatar
Yep those 315/60/15 's will fit , I have them on my truck , the wheels should be 5" backspace , pics in my build
my build 77 gmc shortbed big block, http://67-72chevytrucks.com/vboard/s...d.php?t=438237
73gmc454 is offline   Reply With Quote
Old 03-04-2011, 12:52 PM   #9
ProStreet83C10
Drag Racer
ok, any chance those will fit on a 15x12 wheel, thats the smallest size wheel in the style i want thats made in a 5x5 bolt pattern
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 03-04-2011, 07:10 PM   #10
bigblockrock
bigblockrock's Avatar
a 315 will fit on a 12 wheel no problem but it will give you a bigger section width, about 14 inches if i recall. my brother has 325/50/15s on a ten inch wheel on his fleet and its tight but no rub.
bigblockrock is offline   Reply With Quote
Old 03-04-2011, 10:21 PM   #11
f.monroe
f.monroe's Avatar
Here is the exact size you asked about on a 12 inch wheel . This one has 7.5" of backspace.
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 03-04-2011, 11:42 PM   #12
73gmc454
73gmc454's Avatar
Nice ! Thanks for posting the pics they look great on 12" wides , I really like em any cutting on the inner well ?
Old 03-05-2011, 12:39 AM   #13
mooseknuckles
that looks goood!.....love the draglites!
Old 03-05-2011, 12:44 AM   #14
Prerunner1982
Prerunner1982's Avatar
not sure if it means anything to you but I could run 32x11.50x15s on the rear of my 82 with stock wheels and no rubbing issues. I think 33s could fit find as well.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 03-05-2011, 03:44 AM   #15
ProStreet83C10
Drag Racer
ok now...before i get all hot n bothered about these 15x12s with the tire size i posted......i need to know if any fender cutting/rolling was done or if it was a simple bolt on and drive away with fenders being left 100% OEM/stock.
Also, if i could, id like to see some pics of the closeness of tire to fender lip on top side in front as well as tire closeness to inner fender well if possible please.
Id also like to see some additional angles of pics with the whole set up, like from behind the truck and stuff like that to see how wide they are etc.
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 05-16-2011, 11:15 PM   #16
ProStreet83C10
Drag Racer
anyone else have any replies for this, im DA#M CLOSE to buying a set of rear wheels/tires for my truck in a 15x12 size with the tire size i posted above
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 05-17-2011, 12:36 AM   #17
KQQL IT
At the body shop.
KQQL IT's Avatar
If you get it to hook you may find the limits of a 10bolt axle.
And i've got a 325/50 15 hooiser D/R on a 10" wheel. 4.74b.s
Old 05-17-2011, 06:55 PM   #18
bbbc10
Diggin The SquareLife
could i fit a 17x11 wth 6" bs wth 315/35/17 wth 6" drop in rear?
bbbc10 is offline   Reply With Quote
Old 05-17-2011, 07:50 PM   #19
ProStreet83C10
Drag Racer
Originally Posted by kqql it View Post
if you get it to hook you may find the limits of a 10bolt axle.
And i've got a 325/50 15 hooiser d/r on a 10" wheel. 4.74b.s
posted via mobile device
not overly concerned bout the axle as i dont have an overly healthy sbc in it now. Only a 15 sec truck
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 05-17-2011, 11:27 PM   #20
ont_guy_38
ont_guy_38's Avatar
I have a 10 inch rim with 5 inch backspacing and 345/55/15 tires and I had to widen the tubs.My tires just and i mean just sit inside the wheelwells so i think what you want is your 315/60/15 on a 10 inch rim with 5 inch backspacing. You will have to tub with a 12 inch rim with 7.5 backspacing and if you get 12 with a 5 inch backspacing that will put your tire too far out I think
ont_guy_38 is offline   Reply With Quote
Old 05-17-2011, 11:38 PM   #21
ProStreet83C10
Drag Racer
yeah i found out id need to tub it some with a 12" wheel so i think im gonna go with a 10" wheel out back with the tire size i posted earlier. only thing that sucks is it wont look as mean as with a 12" wheel and itll only be 2" wider than whats on it now
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 05-18-2011, 12:00 AM   #22
slugish
Slugish
If this helps ,Im maxed out at with 275x50 tires & 17x9.5 rims with 4 in. bs .
Iwould guess a 10 in rim with the size of tire you are talking about would limit you to a 5.5 bs max. with stock tubs. good luck
slugish is offline   Reply With Quote
