Old 03-04-2011, 03:21 PM   #1
pryorstemmed
4wd Enthusiast
pryorstemmed's Avatar
How can you tell if it is a true SWB 4x4?
Hello, looking at a 71 SWB (badged)Cheyenne 4x4. It does not have a SPID and the seat has been recovered, so I doubt there is a build sheet there. The frame has been painted black. The vin starts with CKE141 so it is a 1/2 ton. I have not checked the vin on the frame yet, will that do before I buy. It also has a 350 that was stated to be original. Is there anyway to tell if it is a true SWB? It has Cheyenne emblems but the interior has been customized, so the door panels and headliner are not original. I remember a thread that said to check the holes for the headliner and look for factory oval openings. It has the rear cargo light and a chrome/stainless tailgate handle. Any other things to look for? Thanks for any help guys and gals.
*1972 Cheyenne Super SWB K10 Original Paint 350/350 AC (Added) Tach/Tilt
*1972 Cheyenne Super SWB K10-Buckets/Tach/Tilt/Wood Bed/Manual Throttle/Marker Lamps
*1972 Cheyenne Super Custom Camper K20 AC/Tilt/Aux Tank/Aux Battery/Wood Bed
*1970 Olds 442 W-30 M-21 4-speed
*1978 Ford F250 4x4 Ranger-Explorer-Camper Special Marti Report: 1 of 1
*1986 K30 Silverado Crew Cab 502/TH400
*2002 Silverado LT 2500 Duramax Long bed Crew Cab 4x4 107K original miles
*2022 RAM Bighorn 1500 Waldoch edition ...Daily Driver
pryorstemmed is offline   Reply With Quote
Old 03-04-2011, 03:50 PM   #2
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: How can you tell if it is a true SWB 4x4?
The only way with no documentation is to check the frame vin under the cab on the frame rails to see if it matches the truck vin besides checking for any sectioning of the frame. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 03-04-2011, 03:54 PM   #3
Gene
Gene's Avatar
Just like Trevor said, the only real way to see if it's a true shortbed is to check the frame for sectioning, really good welders and fabricators will be able to hide the section where the frame has been removed, but I havent seen one yet. I am building a truck now that used to be a longbed but now is a shortbed 4x4. There will be no way to see that it has been converted because I used an actual shortbed frame other than the cab v.i.n. and the frame not matching.
Gene is offline   Reply With Quote
Old 03-04-2011, 04:03 PM   #4
pryorstemmed
4wd Enthusiast
Thanks Trevor and Gene, that is what I thought. Is there a certain spot on the frame where they were cut more often? Also, if they switched the frame and it is not a true SWB, how much does that affect the cost? He wants around 12K and it is in great shape, no rust, rebuilt and very clean engine, custom interior that I do not like and great hugger orange paint. The only problem is the bed floor is beat up. I do not mind that, I will still use the bed for hauling wood so a spray in liner will do. 12K is pretty high, but with a new interior and removal of the chrome roll-bar will make this a killer truck. I will try to get pics when I test drive it as soon as the weather gets better.
Old 03-04-2011, 04:24 PM   #5
Gene
Gene's Avatar
I would say it if they switched the frame it shouldnt effect the price any at all or very little unless it's priced as a numbers matching truck, but unless it's a VERY nice truck 12k sounds pretty high to me. If it has been cut it will be under the cab on the flat part of the frame somewhere, and there will also be some frame cut off the very end of the frame rails.
Old 03-04-2011, 04:31 PM   #6
pryorstemmed
4wd Enthusiast
Thanks Gene, I will check those places. It is a very nice truck, and has four "best of show" trophies from known shows that come with it. Still not sure if it is 12K nice, I am gonna offer him 8k and might go up to maybe 10K.
Old 03-04-2011, 04:36 PM   #7
That's a '72 VIN with the C before the K. That trim on the tailgate handle is Cheyenne Super. But,they can be switched,also have been and now are reproduced,too. Usually,on a frame shortening there is a splice under the cab,so the rear cab mount will be relocated and no longer factory riveted. Original SWB 4wds will always be worth more than "created" ones
Old 03-04-2011, 04:39 PM   #8
pryorstemmed
4wd Enthusiast
My bad, it started with a K, not C. And I will check for the splice and factory rivets. Thanks again Special-K!
Old 03-04-2011, 04:42 PM   #9
bruceman1968
bruceman1968's Avatar
Check to see if the model number still on the firewall in grease pencil.
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
Old 03-04-2011, 04:49 PM   #10
pryorstemmed
4wd Enthusiast
Yeah I checked that and it has been repainted, no factory marks I also have to look at the rivets on the drivers side VIN plate to see if it has been taken off.
